Question about GE PSS27SGRSS Side by Side Refrigerator
GE Profile pss27sgrss has a bad main pc board
Initially the water/ice dispenser stopped working. Then a few days later the freezer wasn't working. I hit the temperature down button and it seemed to reset itself and then worked. However, a few days later both the freezer and refrigerator had stopped cooling and now the only display that does anything shows a blinking HRS. None of the other temperature buttons work. If you listen closely, you can hear something that sounds like a system that keeps trying to start. The lights come on fine. I had a Sears repairman come out and he said it would be about $500 to fix it and since it is 8 years old he recommended just getting a new one. He said it is a bad main PC Board. Would you agree?
  • GE Master
  • 4,654 Answers
Yes I would agree that you get another refrigerator! The GE PSS27SGRSS is an Artic/Profile model and people have had nothing but complaints about the motherboard problems. I recommend you buy something that has no motherboard or electronic defrost. The best refrigerators out there are ones that have the simple defrost timer and no electronics, Thanks Sea Breeze
Posted on Dec 05, 2012
4 Suggested Answers
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
SOURCE: Where is the Dispenser Board located on a GE Profile Side-by-Side
Hallow i have a broblem with my freezer is takes waters all the time to the floor the name of the freezer is whirpool wthat can i do to soal this proplem i send this massege from greece thank you.
Posted on Jan 24, 2010
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Had the same problem. Pressed button heard a click, saw zeroes flash, then nothing. After some online search I found and solved the problem. Corrosion and condensation on the connector plug attached to the wire at the bottom of the freezer door. Remove plastic grill, pull out wire from under box. You'll find a plastic connector and possibly wet or corroded wiring. CUT POWER TO FRIDGE OFF FIRST. I cut away the white plastic connector then stripped and tied the wires together with wire caps. Taped them up too. Note which wire goes to which first. Mine was blue to blue, black to black, and red to white. Problem solved.
Posted on Sep 04, 2012
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice & Water Dispenser Suddenly Dysfunctional; LED lights, too!
Cory, you sound like you have a bad water valve as well as a bad control board for your dispensor. If you've had any storms in your area in the past 4 - 6 weeks, it's very possible that the storm took both parts out.
We have parts for GE as well as mots other major brands, so please give us a call with your complete model number and we will get your parts out to you right away!
We hope this solves your problem and we look forward to being able to assist you with future issues.
Have a great evening.
Nov 05, 2009 | GE GSS22JF Side by Side Refrigerator
How do I remove the ice/water access panel on GE Profile fridge? The ice dispenser, water dispenser, and all lights stopped working.
First, open door to freezer, while pushing in on the ice dispenser trigger look at the lights in the freezer and see if they go dim, if they do then the "main board" on back of frig is defective. This is a common problem with these boxes. Its somewhat uncommon for the ice, water and light to go out at the same time, its possible, but not common.
Another way to tell if main board is bad is when you do as stated above and you hear the evap fan stop then main board is for sure bad.
Let me know what you find out. If main board then I will need model & serial number to give you the right part number for main board.
If none of the above occur, then advise and I will tell you then how to pull dispenser apart.
Oct 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
PSS26SGRD GE side by side
could be just the board on the dispenser only. not the main board or mother board.
just a little bit hard to replace because of the problem on how to open the front dispenser.
tnx 4 using fixya,
drcool
Oct 21, 2008 | GE Profile¿ 26.5 Cu. Ft. Stainless...
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
GE PSS27SGRSS Side by Side Refrigerator Logo
83 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
