Question about GE Profile Spacemaker Over-the-Range Microwave
I have a GE JVM2070SH001 micowave . I do not have power to the under unit lights (work,nitelight) but everything else works fine. What is the likely problem?
Yes ,I tried new bulbs .
  • Steven McFarlane Dec 07, 2012
    It is not the interior light .This is a over the range microwave,there are two halogen lights under the unit one is a night light the other is a work area light . Nether have power to them.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 114 Answers
Either the control board or the switch itself. I can't remember if that on is part of the main keypad or not. Does the unit beep when you press the light button? If it does then you need to follow the wiring to a point where you have power. Best guess...control board
Posted on Sep 23, 2014
4 Suggested Answers
  • 43 Answers
SOURCE: Oven stops after a few seconds
I like the information you give.
If the unit will work with the control Panel at a 45 degree angle it tells me you have a loose connection. The 45 degree angle puts enough pressure on the connection to keep it completed. With the Control Panel in it's normal position, the loose connection Heats and Opens the connection. After it cools connection is again made until it Heats up again. Remember Expansion, Contraction. I do not believe you have a Magnetron issue!! A Magnetron does not know if the Control Panel is at an angle.
Can you hear a slight "Click" when the unit shuts down? If so this is a relay opening. When you say you replaced the Control Board. Was this the Control Panel PC Board, or was it the Cook-Relay Control Board? A Door Switch not making solid contact can do this. Is your Door latching down solid? Check for loose connections, not open LOOSE.
Posted on Jan 28, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE JVM1660cb01 no light power
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 25, 2008
  • 582 Answers
SOURCE: GE micowave, keypad will not work
GET THE OVEN NUMBER AND SEE HOW MUCH THE TOUCH PAD COST, SOME TIMES THE TOUCH PAD COSTS AS MUCH AS MICRWAVE OVENS NOW DAYS
Posted on Aug 10, 2009
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
GE, Model# PVM2070SM1SS microwave - touch panel does not respond
GE has a special program, and your microwave is very likely a part of this program. Please contact GE consumer relations asap at 800-386-1215, at the prompt press 5. Our same microwave model has that problem. GE is replacing the entire microwave free of charge.
Jun 21, 2012 | GE PVM2070SMSS Microwave Oven
My microwave power is ok, led light ok, but dosen't work what problum?
check the door switches....i had an over the oven micowave with a bad door switch....thing is the switch cost 35.99 online and i bought a counter top microwave for 39.95 at walmart
Jan 31, 2012 | GE Microwave Ovens
I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
May 27, 2010 | GE Profile Spacemaker Over-the-Range...
JVM2070SH001
you have a bad magnetron. go to sears parts direct and you can see the price for a new one. but it may not pay tp fix.
Feb 25, 2010 | GE Profile Spacemaker Over-the-Range...
Aug 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave is not heating up the items put in it- everything else is working fine. The model is JVM2070SH001.
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 24, 2009 | GE Microwave Ovens
The micowave will not heat or cook anything
PLEASE HELP ME TO FIX THS PROBLEM....
Mar 10, 2009 | GE Microwave Ovens
Kenmore micowave oven interior light
THe microwave has to be removed from the wall and then the outer cabinet has to be removed to get to the bulb. Do not do this with the unit plugged in and do not do this if u don't know how to work on a microwave as there is a shock hazard.
Jan 26, 2009 | Kenmore Microwave Ovens
Goldstar Microwave
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Dec 18, 2007 | Goldstar MV-1501 Microwave Oven
GE Profile Spacemaker Over-the-Range Microwave Logo
91 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
