Question about Vizio M420sv 42 Razor Led Edge Lit Inch Class
Vizio M420SV remote will not turn tv on or adjust volume
Neither the fios or vizio remote will turn the tv on or off or adjust the volume
  • 14 Answers
SOURCE: I can't turn my TV off with the Verizon FIOS universal remote.
Try the following codes. I know you stated that you were given codes so ignore any that you already have tried:
Verizon FIOS
Vizio 0891, 0912,1783
Alternative Codes
1758, 0178, 1756, 0128, 0117, 1017, 1078, 0030, 0056, 0205, 1292, 0057
Posted on Apr 01, 2009
  • 4 Answers
SOURCE: code for Vizio tv
Unfortunately, those remotes only take a 3 digit code. I bought 2 new remotes, which do take 4 digit codes, but the code(s) for the Vizio do not work (or partially). I found that the 4 digit codes for the Goldstar and LG work better than those provided for the Vizio, but still not as good as the original Vizio remote.
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Posted on May 25, 2009
antn
  • 15 Answers
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Posted on Jun 11, 2009
SOURCE: Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
Posted on Sep 07, 2009
Vizio 42 inch smart tv Model # M420sv
You have to check the audio settings of your tv. There would be n option which allow you to choose the option between internal speakers or external speaker. You have to choose it as external speakers of amplifier.
If you wish to get some more details then check the following link
http://electro-medical.blogspot.com/
Jul 22, 2016 | Vizio M420sv 42 Inch Class Edge Lit Razor...
I LOST MY REMOTE TO MY 39INC VIZIO FLAT SCREEN T.V. MODEL D390-BO HOW DO I CHANGE CHANNELS AND ADJUST VOLUME MANUALLY?
Unfortunately, the Vizio D390-B0 only has a Power and Input button on the TV. You need a replacement remote (XRT020) or a universal remote with the code for Vizio that was programmed 6 months after the TV was released. The D390-B0 documentation suggests that the TV was released in 2014.
I hope this helps.
Aug 14, 2015 | Vizio Televison & Video
My Vizio 42 M420SV Powers on the back off.
Suspect number one is of course the power supply board in the set, if look there look at the filter caps for ones like these:
Dec 04, 2012 | Vizio M420sv 42 Inch Class Edge Lit Razor...
Can't get full screen on Vizio VA19LHDTV10T
This is either due to some incompatibility or change of format of picture. Also the color system should be same like PAL/SECAM etc.
Aug 03, 2012 | Vizio VA19LHDTV10T 19 in. LCD TV
VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Jan 13, 2010 | Vizio VW42LF 42 in. LCD HDTV
Verizon FIOS
Alternative Codes
Mar 31, 2009 | Vizio L32 32 in. LCD HDTV
Vizio remote control not working
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Code for Vizio tv
It looks like your remote takes a 4 digit code. Try the following codes:
Feb 27, 2009 | Vizio VW37L 37 in. LCD HDTV
Vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Oct 02, 2008 | Vizio VX37L Television
Verizon remote won't work
I am a Verizon tech and the remotes we use work for Vizio sets just fine. If for some reason the remote wont work and he tried 3 different ones then it has to be your set. I set FIOS up all day and have no trouble with those TVs
Mar 09, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio M420sv 42 Razor Led Edge Lit Inch Class Logo
225 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
