Question about Linksys WRT160N Wireless Router
How to fix error 302 - Linksys WRT160N Wireless Router
  • 826 Answers
To overcome this, Reset the router from the beginning. Press and hold the reset button for 30 seconds and release the reset button. Unplug the power cable from your router, wait for 30 seconds and re-connect the power cable. Now re-configure your router. Configure the router manually do not use the CD to do it............
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Posted on Dec 05, 2012
How to fix error 616-302
Automatic Solution for Novice PC Users (no manual option selections are required):
  1. Download the Dell 2130cn Printer Repair Tool
  2. Install the application after download completes
  3. Click the "Scan" button that appears on the first interface
  4. Click the "Fix Errors" icon that will appear once the automatic scan has finished
  5. Restart your system as usual
Jun 23, 2014 | Dell 2130cn Laser Printer
How to clear error code SC302, Dsm615 nashuatec
Yes, mine were successfully RESET from the error code SC:552 and SC:302. Machines runs good, but i about to wander what could be faulty inside, it took one month after error code 302 exist. Mine was exactly DSM615 same model same error code 302 (this is really 302) which resolved by reset. Hopefully machine will run good for two months.
To RESET it
1. Press Yellow button
2. Press 1, 0, 7
3. Hold Orange button for 3 seconds
4. Select MODE 5
5. Select Clear Memory (or something like it) (801)
6. Select 002-Engine
7. Select EXECUTE
8. Turn the switch off and leave it for a minute
9. Turn back machine On.
10. Done, or else there could possibly something else.
Good Luck....
Thanks for using Fixya.
Mar 04, 2013 | Office Equipment & Supplies
Quando ligo o cpu aparece erro n.302 vendor,o que eu posso fazer para consertar?
google translate
when I turn on
the cpu error appears n.302 vendor, what can I do to fix it
if you want to know what this is the error code is related to
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Aug 01, 2012 | Intel Core I7-980x 6 Core Cpu, 12gb...
Error code sc 302
Hi
This error indicates problems with the laser motor on your printer.
Have it replaced.
Mar 01, 2012 | Office Equipment & Supplies
Dishlex 302 model is displating "i30" error which
Try and remove power for few hours so that the processor resets, check if there is fault in the door switch as the error had come in, check for good pressure at the inlet, and possibility of any fault in the pump. It is best to take a full view of the functioning of the units to ensure that there are no errrors that feed back. Clean and reset.
Sep 29, 2011 | Dishwashers
Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
SC:302
Charge roller current leak
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
Router setup gets Error 302 message
Old configuration parameters are lost. Check with your service operator for a fresh config details to enable the router in gateway mode.
Oct 18, 2009 | Computers & Internet
I have application error 302
Introduction
Your Web server thinks that your URL has been temporarily redirected to another URL. The client system is expected to immediately retry the alternate URL.
302 errors in the HTTP cycle
Any client (e.g. your Web browser or our CheckUpDown robot) goes through the following cycle when it communicates with your Web server:
  • Obtain an IP address from the IP name of your site (your site URL without the leading 'http://'). This lookup (conversion of IP name to IP address) is provided by domain name servers (DNSs).
  • Open an IP socket connection to that IP address.
  • Write an HTTP data stream through that socket.
  • Receive an HTTP data stream back from your Web server in response. This data stream contains status codes whose values are determined by the HTTP protocol. Parse this data stream for status codes and other useful information.
This error occurs in the final step above when the client receives an HTTP status code that it recognises as '302'.
Resolving 302 errors - general
The 302 response from your Web server should always include an alternative URL to which redirection should occur. If it does, a Web browser will immediately retry the alternative URL. So you never actually see a 302 error in a Web browser, unless perhaps you have a corrupt redirection chain e.g. URL A redirects to URL B which in turn redirects back to URL A. If your client is not a Web browser, it should behave in the same way as a Web browser i.e. immediately retry the alternative URL.
If the Web server does not return an alternative URL with the 302 response, then either the Web server sofware itself is defective or your Webmaster has not set up the URL redirection correctly.
Resolving 302 errors - CheckUpDown
Redirection of URLs may occur for low-level URLs (specific URLs within your Web site such as www.isp.com/products/index.html) when you reorganise your web site, but is relatively uncommon for the top-level URLs (such as www.isp.com) which most CheckUpDown users ask us to check. So this error should be fairly infrequent.
The 302 response from your Web server should always include an alternative URL to which redirection should occur. If it does, CheckUpDown automatically tries the alternative URL. This in turn may possibly lead to another redirection which CheckUpDown then tries. This continues for a maximum of 5 redirections. As soon as 5 redirections have occurred, CheckUpDown gives up and reports the 302 error for your account. So you should only ever see the 302 error if 1) your Web server gives no alternative URL on the 302 response or 2) the number of redirections exceeds 5. This second condition should be fairly unlikely - and may indicate a recursive pattern e.g. URL A redirects to URL B which in turn redirects back to URL A.
You first need to check that the IP name we use to check for your account is accurate. If you or your ISP have configured something so that any access using this name should now be redirected to another name, then you need to update your CheckUpDown account to start using the new name.
If you believe that the IP name we use is exact (should not be redirected), please try accessing the current URL using a Web browser. Note carefully which URL actually gets displayed, because your browser may silently switch to a substitute URL if it receives an 302 message from your Web server. If you see any evidence of a new URL, try accessing that directly from your browser. If this works (you see your Web site as expected), then this new URL is what you may need to update on your CheckUpDwon account. If this is a temporary redirection, then you may also need to reinstate the original IP name at a later date when the redirection is no longer effective.
If none of the above help, we can analyse the underlying HTTP data streams we receive from your Web server. These can provide additional information about the new URL(s) which your Web server thinks we should be accessing. Before doing this, we prefer you to identify any deliberate changes on your side, liaising with your ISP if needs be.
302 errors should occur infrequently, because top-level URLs do not change often. If they do change, then this is typically because a redirection URL is being suggested. This pervasive change is unlikely to occur by accident, so most often we can resolve this error by updating our system records for your account following a deliberate change of URL on your part, whether this change is temporary or permanent.
Aug 02, 2009 | Dell Pentium 4, 2.26 GHz (1W391)
Error code 302 thats that mean?
HTTP 302 is not an error. It's simply a request for your browser to redirect to another URI. Browers aren't supposed to show you a message, they are supposed to simply follow the redirect. You should try accessing the router interface from a different web browser, such as Firefox.
Feb 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Linksys WRT160N Wireless Router  Logo
112 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
