Question about Music
I have the alesis dm8 usb kit. At first everything worked well....but about 5 days later the kick pad wouldnt work! Ive changed the cables(ex:put the "kick" cable to the "crash" pad and works. I tried resetting the module to its factory settings and now the "ride" pad doesnt work. I called customer service and they told me that I have a static problem since my floor is all carpet. I picked up the kick pad off the floor and hold it in my hands while been conected to the module and I was getting the strokes right but the vol was extremely low even when the module"s vol was all the way up. I also tried to raise the kick vol all the way up but it was already at max. Please I need to know just whats goin on so I can fix it
5 Suggested Answers
  • 5603 Answers
SOURCE: I'm trying to use the pads of my Yamaha DTXplorer
Actually, ONLY TWO pins are used in the MIDI cable. The data is sent serially at a 31.25KBit rate.
You probably need to "map" the ones that aren't working into the appropriate codes to trigger the SR-18 sounds.
You need to COMPARE the codes sent from the DTX to those needed by the SR-18.
There also may be options in the DTX for type of drum kit such as "Latin" and selecting one of those may have the mapping already done.
In the literature of each device will be a list of the MIDI codes the DTX generates and those required by the SR-18.
essentially the percussion codes are NOT standardized completely between devices... but there is usually a way to "map" them to make it work.
Posted on Mar 10, 2011
sparky1500
  • 1066 Answers
you need to determine what midi note the DTXplorer is using for the snare, kick and 3rd tom, and set the SR-18 accordingly, or vica-versa. the midi notes for each instrument has to be the same.
if you cannot change the midi note in either unit to make them correspond, you can download a "midi mapper" program (i think e-drum might be one), there is freeware available if you search CNet. with a midi mapper program, you would have to get a midi/usb adapter for your computer and rouite the midi signal through a computer. midi mapping software allows you to change the midi note, when the hardware itself is incapable of doing so.
Posted on Mar 12, 2011
  • 5603 Answers
SOURCE: Alesis DM6 electronic drum kit module sound
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
Posted on May 08, 2011
KeithOB
  • 59 Answers
SOURCE: The bass (kick) drum pad
If youve already tested the signal path and it works then your likely just dealing with a bad piezo inside the kick drum. The piezo is actually what detects the trigger. You could probolly replace it yourself it not hard typically just 2 solder joints but you'd have to buy the piezo. Call the manufacturer they should provide you with whomever distributs their parts locally to you.
Posted on Sep 08, 2011
Alesis DM6 kick/bass has a really low volume-any way to make it louder?
MAKE SURE WHEN YOU ADJUST THE VOLUME YOU PRESS
SAVE , GO BACK IN A CHECK VOLUME LEVEL TO A MAX OF 16
Jan 09, 2013 | Alesis DM6 Electronic Drum Set
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
Sep 22, 2012 | Alesis DM6 Electronic Drum Set
Alesis DM7 bass drum wont work
the solder on my kik keeps breaking off. you might have sensitivity issues. it can be adjusted on module.
Jan 22, 2012 | Alesis DM7 USB Electronic Drum Kit
I'm trying to use the pads of my Yamaha DTXplorer drum kit as triggers for the sounds stored on my Alesis SR-18 drum machine. I have seen that Alesis markets a trigger module of their own which they...
Mar 09, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
Mar 09, 2011 | Yamaha DTXtreme III Drum Trigger Module
My kick sound has died out of the kit, when i press the button there isnt a sound so i assume it doesnt have anything to do with the cables or actual bass drum pad. any ideas?
My guess would be something faulty with the cable connector to the kick pad.
Source the faulty link by reconnecting the pad so that:
1. A tom pad triggers the bass drums sound 2. The kick pad triggers a tom sound 3. Don't use cable you use with the kick when searching for the fault.
This should tell you whether it's the pad, the bass drum channel or the cable that is at fault.
Hope that helps!
Mar 03, 2011 | DDrum Kit
I have a Alesis DM10 pro kit and both the 8" drums
They show the make up of this on You Tube...search for DM10 there.
Feb 08, 2011 | Alesis DMPad 8" Dual-Zone Drum Pad
I had just recieved a brand new DM6. Upon setup the kick drum didin't seem to be working. I switched the cable going into the kick drum pad with the Tom 3 cable and the pad was responsive. When I...
THERE IS A TINY SWITCH ON THE BACK OF THE MODUELE
THAT MUST BE SET TO PAD , IF IT IS IN THE WRONG POSTION YOU WILL NOT GET ANY SOUND OUT OF YOUR KICK DRUM
Jan 12, 2011 | Alesis DM6 Electronic Drum Set
A new DM7 drum set line out has very low output. It is connected with drum combo Stagg EDA40 and if combo drum inputs are used there is practically nothing to hear . With combo maximum volume there is...
The sound on all the stock kits I found to be too low. What I did was create a custom kit and altered the dynamics of all the pads and cymbals - once you're in the dynamics settings, just hit the pads/cymbals the hardest you normally would and save that setting!
Dec 29, 2010 | Alesis DM7 USB Electronic Drum Kit
Have the alesis dm6 there is no out put sound. monitor appears to be working. hooked to small amp or headphones. just fuzz. please help. little guys christmas present!!!
Two things:
Check that cables are seated, especially the one at the main module.
Second, look for a setting for "Local Control" in your user's manual; That setting should be "On" to accept the triggers from the pads.
Dec 25, 2010 | Alesis DM6 Electronic Drum Set
Music Logo
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
