Question about Whirlpool Dryers
Heating element model wed9400swo whirlpool dryer
  • 156 Answers
SOURCE: Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Posted on Mar 06, 2008
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
  • 659 Answers
SOURCE: whirlpool dryer not blowing hot air
The element is at the bottom of the unit. Usually they are located on the right bottom but when you take the housing off, you will be able to see it.
Posted on Apr 11, 2009
  • 351 Answers
SOURCE: Whirlpool Dryer not heating
There is many different things it could be! most of the time it is not the heating element. You have thermal fuses and safety switches. I bet you 10 to 1 if you locate the thermal fuse on the element cannon say 1 foot up from the incoming voltage from the wires to the heating element.
1. either disconnect power to the unit, take continuity on every fuse try the one i suggested first.
2. the same exact fuse im talking about disconnect power and connect both wires together, dont ground it out, plug power back in and then try it.
Note this is only advice and Whirlpool Parts Surplus is not responsible. Try that give us a call or hit that link and find your thermal fuse part number.
Posted on Apr 19, 2009
tbirdfan1
  • 3051 Answers
SOURCE: heating element quit working
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Posted on Oct 15, 2009
F01 Error
F-01 flashes when there is a primary control
failure. Replace the machine control electronics.
from http://www.advantagesupplyfl.com/WhirlpoolDryerFaultCodes.html
Jan 08, 2014 | Whirlpool Dryers
Whirpool dryer model wed9400swo the dryer door pops open
This usually occurs when the load is too large, causing the cloths to push the door open. If this is not the case, you should replace the door latch mechanism, which is what keeps the door closed.
Jul 14, 2010 | Whirlpool ET8CHEXSQ Dryer
Can I run my Whirlpool HD Commercial Dryer on a 120/208 supply
you should change your heating element to a 208v element. go to your local appliance service depot and ask for 208 element for whirlpool commercial dryer and they will know what your asking for.
Dec 04, 2009 | Whirlpool CEM2760KQ Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Oct 15, 2009 | Whirlpool Dryers
DRYER HEATING ELEMENT
Kenmore dryers are manufactured by Whirlpool. In many cases the part numbers are identical between model numbers. Look at the dimensions of the heating element and compare part numbers. Chances are, the parts are identical.
Jun 29, 2009 | Dryers
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer problem
dryer works but does not heat up
Mar 12, 2008 | Whirlpool LEQ9858P Electric Dryer
Mar 06, 2008 | Dryers
Dryers Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
