Question about Toshiba SD-V55HT DVD/VHS Home Theater System
No Sound I'm almost positive I damaged some internal components while retrieving two cd's jammed into the DVD port by my 3 year old son. I need to find a diagram of the internal components
  • Jason Dec 05, 2012
    I'm pretty sure I disconnected a wire or knocked something loose.
  • Jason Dec 06, 2012
    Do you mean the DVD laser that scans the discs? If so, why is there no sound with VHS or Radio? I must have pulled a connection loose or damaged an internal component. I really need an internal component diagram for this model.
    Sergeant:
  • 256 Answers
They mess up the lazer in the unit, it is verry costly to have it repaired, Just get a different one,
Posted on Dec 05, 2012
DVD/CD room isn't opening. Motor runs and it's sound is very strong. Firstly "CLOSED" is shown and then "LOAD" on screen. But not achieved. Thanks for you help.
The only way to approach this is someone has to open the unit and "see" what is happening---something jammed, broken or out of position.
Dec 21, 2012 | Philips LX3600D System
My pc does not see cd in uj-852
Open your chassis and blow out the dust with compressed air. Accumulated dust can make electronic components (like chips in a computer) heat up so much that they fail. Luckily, in my experience, after the dust is gone, the component will become functional once again.
Nov 21, 2017 | Toshiba Style Bay DVD-RAM Drive Kit...
Door will not open
this product seems to be an audio CD player in use with a stereo system.
Have you tried inserting a paperclip (that has been straightened out) through the tiny hole available to manually coax the tray to come out. It will pop out just a little, but it will then be unlocked and be easy to bring out, displaying the entire CD.
If you have tried that, then.....
Take the cover off (the entire case) and inspect the area where the CD is. Many of these players have no metal encasement around the CD mechanism and one can see the inner workings. The CD may have gotten askew, or the mechanism jammed. Gently try to free things up.You should at least retrieve your CD.
Put the thing back together. Use a junk cd (keep the stereo amp off) and try to load and unload it. If that fails.... Time to get a new one.
Here's a suggestion for that. Most all DVD players handle cd's. Purchasing an inexpensive DVD player might be cheaper than finding a stereo component CD player. Just use the audio out.
Good luck
---Sam
Oct 04, 2012 | NAD C521 CD Player
Need to hook up LG tv to phillips cd/4 head hi fi and RCA surround sound
Hello!
Ok: I will guide yourself through "hook up" process.
1. connect your TV set to your VCR, using 3 wires RCA cable(Yellow, red, white) to "Video1" input, yellow only! The other 2(sound channels) connect to "home theater/DVD unit. Use "aux" input.
2. Connect your DVD video output. yellow or 3 colored( green, blue, red) component cables to your TV's Video 2 or "component 1" input.
Now you'll be able to use your TV as a video monitor for your VCR and DVD.
The sound will be handled by DVD/Home theater. In case your TV is a very modern, all you can get out is: direct digital sound stream. Your home theater must be equipped with coaxial(orange) input(looks like RCA plug) or optical input. Or both. You must use proper cables to connect TV to Home theater.
sorry, but it requires some patience and thorough reading of user manuals.
Otherwise, it's "level 1" difficulty. nothing you may damage, due to installation.
Good luck,
Feel free to ask for more help, if needed.
thanks,
Alex.
Dec 14, 2011 | LG 42LC2D 42 in. LCD HDTV
Good day admin, i just wanted to know why my dvd/cd drive keeps on disappearing and reappearing in "my computer" after migrating from vista to windows 7.i have already tried all the possible...
try a newer drive
its dead now. if it can read CDDA store bought audio discs.
or the data cable port on the mobo end is bad, try another
this laptop can be 10 years old. 1st one was.
2007
what id do is ditch for used 5 year LT.
if that's no fun (is is best)
then upgrade it to newer, DVD or burner, level.
be best.,..,.
make sure the DVD internal connector has no damage
Mar 14, 2017 | HP Pavilion dv9720us Notebook
My component is in LINEAR PCM MODE when it start playing dvd/cd no sound comes out. while in CASSETTE TAPE, it has a sound. i want to know what is this LINEAR PCM, coz i notice, when i turn FM it has a...
LPCM is for digital sources ONLY. Your cassette wouldn't be digital would it? FM, being an internal source on your unidentified receiver CAN'T be wired or configured incorrectly. Crack the manual open and find out how to set the parameters for all the digital inputs, then connect and select an analog input for the tape.
Jun 24, 2011 | Audio Players & Recorders
My PlayStation 3 is stuck and jammed with a CD and won't eject it. Also it has pennies and nickels in the system. And I don't know why but it has a red light in the digital out.
I'm pretty sure the jammed CD might be directly attributed to the pennies and nickels. I would definitely be curious to know how those got in your system. As for the red light in the digital out, it could just be some internal LED that is shining a little bit of light out of the port. But yes...the change in the machine is likely causing your other problems. I would take it to a repair shop or send it in to Sony as soon as possible to avoid further or long-term damage.
May 12, 2011 | Sony Playstation 3 (PS3) Console
I cannot hear sound system play cds and videos
Every CD/DVD-ROM drive has an audio port opened. An audio cable connects to the back side of the CD/DVD-ROM and connects to the motherboard. Most MB's have two four pin audio ports, one slot white in color and a second black in color. As far as the CD/DVD-ROM not reading the disk. Make sure the disk is free from scratches; oils from you're fingers or just plain dust. Open the drawl and blow out the CD-ROM drive or buy a CD cleaner which will clean the internal laser. These days it’s hard to find a CD/DVD ROM drive with a warranty longer than 1 year. Most ppl buy a new one when it fails to read CD's.
Cheers'
Mike
Jun 19, 2010 | Intel Motherboard
My marantz DV 9500 doesnt output digital signal for audio cd anymore but outputs audio for dvd,sacd,dvd audio. Does it need servicing
Make sure your playing componet like CD player have a digital output socket. Connect this to a digital port on the amp witk a single RCA or Optical cable if output available on CD. Make sure the digital assingment in amp is set for cd function and corresponding input(example cd plyer connected on dig 4 input on amp, press menu, setup, assignment, go to cd player, make sure setting on dig 4 or change input to dig 4, go to next component to memorise setting.and exit, see manual to assist you) if still no sound take dvd cable for instance that is working and put that in dig 4 port. if that works check in cd player that settings spdif/raw/pcm is correct one for yor digital output if still no sound soun pc board faulty.
Aug 11, 2009 | Marantz DV-9500 DVD Player
I have connected my dvd player to my tv and although I can see the picture there is no sound
You have a three port yellow-red-white port. Plug the port's yellow end to the yellow plug point of your TV & DVD player both and this way red to red and white to white. I think it fix your problem.
May 16, 2009 | NuTech Nu Tech DBW-521 CD-RW+DVD Combo...
Toshiba SD-V55HT DVD/VHS Home Theater System Logo
129 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
