Question about Apollo 1500 Single Swing Gate Operator / Gate Opener
Apollo gate 1500 problem my gate stop auto closing, it stays open until i hit the remote. I am looking for the solution
All functions of my apollo gate 1500 work normal other then the auto close feature. I just replace the main apollo board #635 and the problem is still there. you open the gate and after auto delay it will not close. At first it just did it once in a while. Now it sticks open every time it is used. It will close with the remote or the main entry panel button.
3 Suggested Answers
SOURCE: I have an Apollo 636
Correct, that board is toast. The is the one thing that any circuit board can not handle is lightning strikes. Buy a new one.
Posted on Oct 26, 2011
benmdavid
Apollo slide gate opener closes when remote is pressed, but does not open when remote is pressed again. I think it's a 7100 series. I think it needs a reset, but vacant find any reset button on the board
Posted on Dec 11, 2013
New FM502 Dual gate opener pressed remote which starts the second gate opening then the master moves a few inches stops. Hear 3 beeps 2 seconds 3-. .Conections are good to circuit board! What up!
reprogram the opening sequence in the control box
it should that the first gate opens then the second gate opens a few seconds behind it
closing is the reverse
you can program that only one gate opens
you can also program that one gate is a entrance gate where it opens until you stop it , then when you have passed through , press it again and it closes
read the operating instructions and follow the programming procedures closely
Oct 24, 2016 | Miscellaneous
I have 2005 chevy tahoe my doors all licks but my liftgate door with window stays open use to lock w all my doors? I havent check anytjing yet? I cant lock it.
Here is how it works !
Liftgate Locking Operation
The lift gate will lock any time the vehicle is shifted out of park on vehicles equipped with an automatic transmission and at vehicle speeds exceeding 5 kph with manual transmission. This happens in conjunction with auto door locks if enabled or independently of auto door locks if the feature is disabled. This ensures that the lift gate is locked anytime the vehicle is shifted out of park or when the vehicle is in motion.
The lift gate lock relay supply and coil sides receive a constant voltage through the battery voltage supply circuit and the ECC fuse. The normally closed contact is connected to ground and the control side is connected to the body control module (BCM). A lock function will occur when a door lock switch activation, keyless entry lock transmission, auto door lock function or a lift gate lock function has been received by the BCM. The BCM will then ground the control side of the lift gate lock relay. This energizes the relay and allows voltage to be applied to the lift gate lock actuator lock control circuit. Since the other side of the lift gate lock actuator is connected to the normally closed contacts of the door unlock relay to ground, the lift gate will lock. When an unlock function occurs the BCM will ground the control side of the unlock relay and the rear doors and lift gate will unlock.
The BCM also runs diagnostics on the lift gate lock relay control circuit and will set DTC B3825 as current and also send a Class 2 message to the DIC. The DIC will display REPLACE LIFTGATE FUSE to inform the driver that a fault has been detected in the lift gate lock circuit and that the lift gate is not locked. Faults that will set the DTC and cause the DIC to display the message could be any of the following:
An open ECC fuse
An open or short to ground in the lift gate lock relay battery positive voltage circuit
A faulty lift gate lock relay
An open or short to ground in the lift gate lock relay control circuit
A short to ground in the lift gate lock actuator lock control circuit
A faulty BCM
May 14, 2016 | Cars & Trucks
Rear tail gate opens then closes again by it self
obviously a problem with the auto mechanism , is there a sensor located , see your owners manual, in a particular area that has to bee kept clear and you may have inadvertantly placed something over the sensor , just guess as something must be telling the tailgate to shut , with the age of vehicle is it still covered under makers warrenty ? i'll look into the sensor thing
May 25, 2014 | 2011 Ford Edge
My gate starts to open but then stops
Need more information.
Firstly, engage the manual release inside your motor and then operate gate by hand. Pay attention to any spots that are hard to push, this would indicate some sort of mechanical obstruction causing the motor to stop. Try remove obstruction.
Secondly, measure the voltage on your battery while trying to operate the gate. If your battery drops below 11.5V the control board will shut down. If so, replace battery.
Feb 04, 2012 | Apollo 7000etl Slide Gate Opener Plus 2...
1. I have an elite slide gate opener it will open all the way and after a few sec will close. 2. With the remote the gate will not stop and stay in the open position.
the auto close has been set or the motor has been set up in reverse and it is auto reverseing,make sure the gate is opening up all the way, if it is not just help it along and see what happens.
Apr 13, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Auto tailgate warning light is on dash board but tailgate closed.
I have a similar problem, my tailgate stopped working with the outside handle and the remote but can be opened manually from the inside. I don't have an alarm so there is no problem with that but did you get a solution for the tailgate problem that I could try?
Jan 23, 2010 | 2004 Honda Accord
Apollo 1500 Single Swing Gate Operator / Gate Opener Logo
269 people viewed this question
Top Apollo Home Security Experts
Lawrence Oravetz
Are you an Apollo Home Security Expert? Answer questions, earn points and help others
