Question about Microsoft Windows XP Professional
Computer wouldn't wake up, now erratic screen
Wouldn't wake up with moving mouse, hitting key, etc. I shut it off and when I turn it back on, I get a very colorful, flashing screen. I shut it off, I get a Microsoft Windows hibernating screen and it turns off. Have tried several times, for different lengths of time.
This happened last week, but worked the third time I turned it on. Not so today. I would appreciate any thought you may have on my delimma.
  • Microsoft Master
  • 787 Answers
Try this:
Unplug the computer.
Remove the battery.
Leave battery out for at least 60 secs.
Replace battery and plug it back in.
Try to turn it on.
Posted on Jan 12, 2009
I put my Dell Dimension 9200 XPS 410 into sleep mode after connecting a wireless keyboard and mouse and the only way to wake it is to hold the power button in until it shuts off and then switch the power...
I would say it is in the Hibernation Mode To get it out of this mode you need to go to your Control Panel, open "POWER OPTION'S" and deselect the Hibernation mode then reboot.
Sep 26, 2013 | Dell Dimension 9200 PC Desktop
I have a vaio PCG 4L1L. Well I just booted it up normally and when it went to the screen were I pick a profile the touchpad mouse wouldn't move or the keys wouldn't work. It doesn't seem to be...
You may have a virus in the system, to check you will need external mouse and keyboard to run a full scan of your system with your anti-virus, go to www.download.com Type: malwarebytes anti-malware and run a full scan.
May 06, 2012 | Sony Computers & Internet
The power went out here at work and my acer desktop wouldn't log into anything (ie email, internet) when the power came back on. So I clicked shut down and it turned off but now it won't turn back...
try taking out all peripherals like mouse printer keyboard leave screen pluggged n then press and hold the power button for 2 minutes then plug in your mouse and keyboard and see if it boots hope this helps
Sep 14, 2011 | Acer Aspire™ T180 PC Desktop
New Toshiba labtop. Computer went into sleeping mode How do I bring back desktop screen?
Try to move your mouse/touchpad or press any key on the keyboard. If the machine doesn't wake up, push the POWER button to wake it up.
Jun 13, 2011 | Computers & Internet
My elan touchpad is not working. the mouse will not move unless i plug in an external mouse
There is a FN + Key (F9 for me) Hotkey to disable the elan touchpad on ASUS Laptops.
This might be the problem if someone activated it by accident.
Also the correct drivers might be missing.
You can get the latest drivers on ASUS Homepage
http://support.asus.com/download/download.aspx?SLanguage=en-us
Mar 20, 2011 | ASUS Computers & Internet
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
Cursor moving erratically
Sounds like your internal mouse maybe be malfunctioning and due to the pressure on the spacebar is causing the erratic movement.
To fix this you can enter your BIOS with the F2 key at startup.
Continue through until you find some input options to disable the internal mouse.
Jan 23, 2009 | Toshiba Tecra M1 PC Laptops
Monitor Turns Black - Won't turn back on when moving mouse
It is probable that the ROM system, called BIOS (Basic Input/Output System), is set to not wake your computer by moving the mouse or pressing a key on the keyboard.
I do not know which BIOS your computer is running so I can only give a general answer.
When your machine is starting up, look for a message that says "Press F2 to enter BIOS" or something like that. Your machine may have a different F key assigned to enter BIOS.
There should be a setting in there that allows you to change the values for waking the monitor. It should say something like "Use keyboard and Mouse to wake up computer", it won't say those exact words, but something like that. If the value is set to disabled, then enable it. Then save your changes and exit (Usually by pressing F10)
Be careful when in BIOS. Changing settings you do not understand can make your computer behave erratically or stop functioning altogether.
Sep 23, 2017 | Sylvania CL972B (Black) 19 in. Flat Panel...
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
Microsoft Windows XP Professional Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
