Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door wont close in cold weather
On really cold days, 25 degrees or less, the garage door refuses to close. It will go down about a foot then reverse Most of the time if you hit the opener four or five times it will finally close. When it gets really stubborn, I have to pull down on the door while commanding it to go down and that will get it to go down. Opening is never an issue, only closing.
  • Anonymous Jan 25, 2009
    I have the same problem, kinda... Mine is the opposite, however. I can't get mine to go up. It goes down just fine. I have to stand at the door, hit the button, and then help by pulling/pushing. If at anytime I stop helping, the door stops moving. As cold as it is here in Minnesota, I sure wish I didn't have to get out of the car to help my door opener!
  • Cid09 Jan 25, 2009
    I've had the same problem with my garage door during very cold weather. What worked for me was to hold the open button down until the door is closed and then let go. This worked for me - hope it will for you too!
    Champion:
  • 244 Answers
Find force adjustment on logic board and turn clockwise A LITTLE to increase down force. Try to stop door. You do not want TOO MUCH FORCE as that is a SAFETY HAZARD.
Posted on Jan 15, 2009
On down door reverses in cold weather
A garage door guy says that in colder weather the weather stripping can become stiffer, less pliable, causing more drag or friction on the door. You may need to increase the down pressure a bit. If it's set in the normal range, try increasing it a little bit at a time, but don't max it out.
Dec 26, 2012 | liftmaster Chamberlain Garage Door Opener...
The garage door closes and then opens up again, I have to close it several times before it secures. There are no obstructions. Is this a sensitivity problem?
More than one thing can cause this type problem.
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is not flickering ever so slightly.
If the door reverses when it hits the floor it is a sign that the door is traveling a bit to far. The adjustment for this is on the side of the motor unit. Turn the 'down limit' in the opposite direction of the arrow printed on the cover. Some tweaking will probably be necessary.
Jul 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door: on calm day panels are weather tight
Garage door work like a wedge. As it goes down the door get closer to the jam. So if you moove the weather stips closer to the door that probebly solve your problem. Do that whith the door complitely close.
Good day Paul
Feb 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
When you push either the remote or the switch at the door, the garage door will go down almost to the bottom and then come back up and the light will blink several times. This does not happen all the time....
Your safety reversing sensors must be connected and aligned correctly before the garage door opener will close. An obstruction in the path of the sensor will also cause your door to not close.
This sensor is an electronic beam, which is sent between two sending and receiving “eyes”. These eyes face each other and are located just inside your garage door. They may need to be adjusted so the beam from the sending eye is properly detected by the receiving eye. Once the receiving eye “sees” the beam from the sending eye, a green indicator light will glow on the top of the eye.
Jan 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsmen belt drive opens but doesn't close properly. It will travel a foot to three feet and then reverse. If the door is disengaged, and in the up position, the belt will do the same thing. If the...
Is the belt or part of the opener hitting on the door as it trys to go down? Since if the door is down the opener goes all the way down, it seems that it might be hitting / binding on the door somewhere and then reverses.
Dec 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
When the temperature drops below 30 degrees F my garage door opener will not close the door. I tried adjusting the downforce but it still does not close. Craftsman 41A4315-7C
Put the down force adjustment back where it was as it affects the safety reversing. If the main light flashes 10 times when you try to close the door it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a bit if necessary. It could be an electronic component that is sensitive to cold and quits when the temperature drops. This is not uncommon.
Dec 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Sears Craftman garage door opener closes about 1/3,stops,and reverses.When I activate the remote again it stops rising,starts down again, comes down another foot or so,stops,reverses etc.,etc,etc It...
If the main light is flashing 10 times when the door reverses it is a door sensor problem. One may have been bumped so that they no longer point at one another. Make sure the small light on each sensor is lit and not flickering. If this isn't the case you might need to increase the down force a little. The control is on the back panel near where all those white wires go. Increase it about 1/4 turn and try.
Dec 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain garage door wont stay closed. It
well the there are lots of possabilities but the most likly one is that there are shadows or pieces of debris that are on a laser detector or the chain that pulls the garage door is being heated while it is frozen which could change the signal on the closer. or you need a theremal cover on ur opperator system for the opening and closing on the door.... google always helps
Dec 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Same as this from syaremko Cold weather came in and now the garage door closes about 6 inches then goes back up.....It is minus 30 degrees celcius outside but not nearly that cold in the garage which is...
Try increasing the 'down force'. You will find the control on the rear of the motor unit near where all those white wires go. Increase it about 1/4 turn and try.
Dec 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cold weather came in and now the garage door closes about 6 inches then goes back up. I have sprayed penetrant on all moving parts and the door closes fine manually. It is minus 30 degrees celcius outside...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
685 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
