Question about Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Canon EFS 18-55mm lens not working in AF mood
My lens now is not working can you help me how to fix my 18 to 55mm im from manila philippines
Posted on Dec 27, 2012
2 Suggested Answers
SOURCE: Hi,My Canon EFS 18-55mm lens
Hello had the same problem and have it solved!!!
Posted on Sep 25, 2011
Camera displays flashing green light and will not take photo
If you flip the M/AF switch on the side of the lens and the then the camera takes a photo, Then the focus drive gears are damaged in the lens and needs repair,
Feb 12, 2014 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Quantaray lens
You did not mention which lens. Some Canon digital cameras will only take EFS lens, others take both EF and EFS. Also there are other types of lens mounts made by Canon.
Cordially,
Jan 01, 2014 | Canon EOS Rebel XS 35mm SLR Camera
Canon efs 18-55mm lens will not take pictures with af on
Hi
this is because flex cable damage. Lens does not know exact position of focusing lens, so it fails to work in AF mode. Problem is fixable but not DIY. Should cost around 40USD (35Eur).
Regards
Dec 11, 2013 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Dropped Canon EFS lens now makes clicking sound when zooming in and out
Take it to a repair facility, but it may be expensive
May 26, 2017 | Canon Cameras
New Canon EFS 18-135mm IS lens failed to auto focus on EOS Rebel XTI and shutter won't release to take photo. Lens over a few months has worked without a problem. What is the problem?
Make sure both the lens and the camera are switched to af (auto focus). If that doesn't work remove the lens and replace it to make sure it is mounted properly. You can also check the camera with a different lens to make sure it isn't a problem with the settings on the camera. If all of that fails take it to a camera or electronics store that does service work to make sure it hasn't been damaged.
Jul 30, 2011 | Canon Cameras
I have a Canon Rebel T2i; when I bought the camera, it came with a Canon EFS 18-55mm lens. This lens had worked perfectly for me for a year; though one day when I removed this lens to use a telephoto lens...
Sorry, but there's nothing you can do as that's a professional repair only.
Your fix options are to replace the lens, or to send it to Canon for a repair (usually fixed cost) or to simply learn to live with manual focus until you can afford one of the first two options.
You might even prefer MF as you always focus upon what you want rather than on what the camera thinks you want. The extra few moments it takes to capture an image often result in more thought and better compositions as well and you get a far longer battery life.. Personally, I very rarely ever use AF.
Jul 18, 2011 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
I am using a canon 350d camera. when I use my efs 18-55mm lense there is an Error 99. Is there a problem with my camera or lense and how can I correct it myself or i need to get professional help. Thank...
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
Sep 02, 2010 | Canon Cameras
My Canon EFS 17-85 MM is locked at the 17 MM position (although it doesn't have a "locked" feature. What is the problem?
Try taking the lens off AF mode and manually turning it and trying to focus. If that doesn't help then it sound like you have an internal fault.
Jan 11, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon EFS Lens question- please help!!
Make sure that the switch on the lens is set to AF. If that doesn't work, you may have a faulty lens. The EFS 18-55 is not a high quality lens.
Mar 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon EF-S 18-55mm f/3.5-5.6 USN Lens Logo
105 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
