Question about Nu Mark Numark Cdn36 Dual CD Player CD Player
My numark cdn90 door opening and closing cd not reading
  • 1,258 Answers
The unit needs service- take to a service center or consult a Technician to see what can be done about the unit. Could be internal switches dirty.
Posted on Dec 11, 2012
3 Suggested Answers
  • 6 Answers
SOURCE: Numark Cd-Mix-2 left side disk problem
Cd drawer and laser assembly are belt driven. Belt needs to be replaced
Posted on Dec 14, 2008
  • 4 Answers
SOURCE: My Numark Cdx and Numark Cdn90 are frozen
Hi Mitchdias,
Have you tried downloading the most recent rom update for the CDN-90? All you need to do is download it from here http://www.numark.com/contentmgr/showdetails.php/id/1493/tt/5 , then burn the download to disc. Once that's done, put the disc into the player, switch the player off and wait 10 seconds, then switch it back on again. the player will read the disc and flash the ROM. this should reset the player for you. Before you ask, you can out the disc into either side of the player. Full instructions are given with the download.
Posted on Feb 15, 2009
Numark cdn450 has tray error message in left well
For all kind of brands cd or dvd players There is in every cd or dvd tray in the front bottom or under the tray so crazy you can not think an microswitch necessary that will be by mechanic close of the tray detect if the tray is closed and give a timed signal (close or open) to focus laser for reading of table of contents if the belt is bad it can take to long by a slipping tray drivebelt for the detection , or the microswitch or brass plate contacts are have a little corrosion on it or even it can be broken by a missing timing.
Dec 23, 2013 | Numark Industries Numark CDN450 Rack Mount...
Numark cdn25 dual cd player when open close the lcd screen gets dim
Are you using the original factory power supply? That sounds like it isn't strong enough. The mA is what I mean.
Feb 28, 2013 | Numark CDn25 Professional DJ CD Player
Numark cdn 90 door opening and closing cd not reading
my numark cdn90 door opening and closing cd not reading
Sep 05, 2011 | Nu Mark Numark Cdn36 Dual CD Player CD...
My numark cdmix2 doors dont open
Both doors? When you press switch (eject) does display change? I doubt you have 2 defective eject switches. Its more likely you need to replace both CD drives, this is quite common.
Apr 06, 2010 | Nu Mark Numark Cd-Mix-2 Dual CD...
Numark CD MIX1 cd won't read.
Look at the optics assembly itself. I believe that Numark uses Sony optics. There should be a small label on the assembly that says KSS-213 or something similar. Please post the markings here and I should be able to locate a source.
Dan
Sep 13, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
I have several NUMARK CDN88 dual cd players with door opening issues. One player set the doors open and close too fast and dislodges the discs. On the other I have to power the unit up and down several...
Going through this problem myself. I've diagnosed that the drive (motor) unit should separate from a magnetic disc that sandwiches the CD between it and the motor. For some reason the mechanism isn't powerful enough to pull it away when the drawer wants to open, so it sticks. It seems to be a mechanical, rather than and electronic issue. I'm looking at replacing both drives rather than a fix, for reliability issues. I've got a number of CDN models and it's only the CDN88 that has this issue !
Apr 29, 2009 | Nu Mark Numark Cdn36 Dual CD Player CD...
Numark Axis 8-Screen says CLOSE, but does not recognize CD
either your set does not recognize the cd or your lens need to be replaced the age of your set has lot to play if it is old satrt shopping for a new set.anyhow have a tech look at your set.a look on the wire ribonthat leads from the body of the lens the pc board will not hurt probably it is damage.good luck.
Apr 10, 2009 | Nu Mark Numark Axis9 Table Top CD Player -...
Hi Mitchdias,
Jan 05, 2009 | Nu Mark Numark Cdx Table Top CD Player CD...
Numark CD mix 3 right cd door seldom opens
Defective load belt or defect in laser assembly
Sep 11, 2008 | Audio Players & Recorders
Sep 08, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Nu Mark Numark Cdn36 Dual CD Player CD Player Logo
65 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
da surgen
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
