Integrated circuit on power supply.
The value of integrated circuit on the power supply.
    Sergeant:
  • 256 Answers
$90 to $200
Posted on Dec 05, 2012
Hi when i turn on my 47ln5700 flashes for a second and then goes black. I have sound and see images with flash light. I am not sure if its the led power board or some leds in the led pannel gone bad.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 11, 2017 | LG 47LN5700 47" 1080p Smart TV 120Hz Dual...
What is wrong with my TV? No picture but has sound. picture shows with flashlight.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
Jan 08, 2017 | Televison & Video
Is the Backlight inverter and the power supply unit in the same board for this tv?
May 18, 2016 | Televison & Video
No picture on tv but does have sound
May 11, 2016 | LG 47LN5700 47" 1080p Smart TV 120Hz Dual...
Is there a feedback circuit that is shutting down the high voltage power supply?
May 11, 2016 | Samsung LN46C630 TV
On my Samsung HCM5525W the television turned off but the red light is on the timer, we do not have the remote control. How do we get it to turn on ?
if you unplug your tv for a minuet more or less this will reset the TV to default values , timers off, otherwise this my also indicate a unit internal fault and requires technical attention
projection TV`s have integrated protection circuits
built into the circuit design, these circuits turn the
power off automatically when a fault has bin detected this
is in order to prevent a more costly repair, these circuits monitor
power supply , vertical and horizontal deflection
over voltage, or x ray, and also faults with convergence circuits.
Diagnosing these faults require test equipment and a good knowledge of
electronic repair techniques, and also a repair manual.
Apr 28, 2010 | Samsung HCM5525W 55" Rear Projection...
No power
Was check 12-5v power supply?
Use other power supply for check it.
The power circuit in mother board is microswitching with integrated circuit, it is off commercial supply, no body sale it.
Mar 10, 2010 | ASUS P5V800-MX Motherboard
Sharp LC-37SB24U will not turn on
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Feb 19, 2009 | Sharp LC-32SB21U 32 in. LCD TV
Shuts off
Jan 25, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
20 people viewed this question
 Grubhead
Grubhead
