White spots how do I get to the dlp chip
  • barry993
    barry993 Dec 07, 2012
    Optoma HD66 I know it is just dust on the chip but I can't seem to figure out how to get to it. I have all the tools to clean it properly as I am both an electronics tech and professional photgrapher. Used to cleaning Cmos an CCcd in digital cameras.
    Champion:
  • 225 Answers
Depends on the model?
Posted on Dec 06, 2012
  • gmontgome595
    gmontgome595 Dec 07, 2012
    In my experience the chip is normally bad. The mirrors quit moving and it makes white or black pixels. I've only wokreded on mitsubishis. They are deep in the machine below the main board with a heat sink holding them in.
  • gmontgome595
    I've only done Mitsubishi and the chips had to be replaced as the mirrors were bad they were located under the main board right by the back of the lens behind a heat sink.
Vivtek d510 projector has black and white spots covering 1/3 of projected image
The DLP Chip is failing .The DLP or Digital Light Projection Chip contains up to 8 million tiny microscopic mirrors that tilt to project a digital image onto the screen. These mirrors are failing causing light and dark spots to appear.Unfortunately fixing this projector is probably going to cost more than buying a new one. Hope this helps.
Jan 02, 2014 | Vivitek Office Equipment & Supplies
How to fix my 65" toshiba white pixel problem
Thats caused by the DLP chip. Unfortunately most Toshiba models will end up having to have both the DLP chip and the formatter board replaced at the same time to fix the issue where as other models only require replacing the DLP chip alone to fix the white dots issue
Apr 06, 2013 | Toshiba 65HM167 65" Projection Television
Mitsubishi wd60735 white spots apperaing
Thats a very coomon problem which is caused by a failed DLP chip. The mirrors get stuck and thats what causes the white spots they will keep multiplying untill the entire screen is filled. You will need to replace the DLP chip. You can get the replacement DLP chip and illustrated instructions on how to do the repair from www.tvrepairworld.com
Oct 29, 2012 | Mitsubishi WD-65833 65" HDTV
White spots
Replace the DLP chip at cost between $160-$300 for the part and about two hours of your own time to do it.
http://www.shopjimmy.com/samsung-mitsubishi-toshiba-4719-001997-dlp-chip.htm/
Jan 24, 2012 | Mitsubishi WD-65C9 65" DLP HDTV
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
Spotty tv
DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.
Jul 27, 2010 | Samsung DLP HL-P5663W 56" TV
White spots on samsung DLP tv
Apr 27, 2010 | Samsung HL-R4264W 42" DLP HDTV
White spots on TV Screen
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.</span>
Apr 20, 2010 | Televison & Video
Had one last week and now there are 6. they are
You get white spots inside the samsung DLP tv due to bad Digital Micromiror Device , or bad DMD board .
What is actually the problem is the DMV chip connected to this board . Inside this chip are 3 million tiny mirrors ,and when they physically get stuck , they either show black or white instead of a color
This is well know problem with SAMSUNG DLP...
The DMD chip is failing.If not under warranty expect to pay a few hundred to several hundred to get it fixed
The mirrors on the DLP chip are slowly sticking either fully open (white) or fully closed (black). The part that contains the DLP chip is the Light Engine. It is the most expensive part of the TV.Only the Samsung TVs has this issue.
Replacing the DLP chip and the micro mirror would solve this issue...
Pleaserate this solution,
Rnj VINODKUMAR
Nov 11, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White spots on screen and growing every day
If these spots are small, they are likely the visual effect of a failing DLP chip. When some of the tiny mirrored surfaces on the chip stop moving, this is the result. This is not something you can fix yourself. A Samsung authorized service center will charge $400-$500 to replace it for you.
michtech
Feb 18, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
jasbo
jasbo
