My cpu wont turn on. light flashes then goes right out
Used computer one nite w/o problems and the next morning nothing
  • 2 more comments
  • max carson
    max carson Dec 05, 2012
    Let us know how it goes. Did you "Jiggle" the cord/charger and the AC jack plug, it may be a bad connection and I just like to say "JIGGLE".
  • max carson
    I thought this was a laptop. It's a desktop a Compaq SR5254 , right? You have a few miles on it right? That changes things the first thing that comes to mind is the PSU. Also It's hard to tell from the pics I found of the Mobo, there may be a power fuse on the board, replace if blown, ALSO change the CMOS battery, while your in there. I had a old HP Compaq SR1120 and the PSU went out. It would try to start and in a few seconds would shut down, again and again. Here is a power troubleshooting procedure :http://h10025.www1.hp.com/ewfrf/wc/docum... A power Supply Unit is a easy fix and not that expensive..
  • Judy Griffith Dec 05, 2012
    yes it is a desktop,being new to the site i must have clicked on the wrong thing.Thanks 4 your input.I'll drop some of these terms when i take it 4 service so i don't look like a mark! :)
  • max carson
    Replacing a PSU is easy, My replacement was less that $50.00 and one hour of my time.
  • 7,627 Answers
Have you tried without battery? Different cord/charger? That's sort of what happens , "one day your here, the next day your gone". Without knowing the age of the machine, it's difficult to say. Machines break. If you have a multimeter you can troubleshoot the circuit, if not, it may need a ride to a Qualified Computer Tech.
Posted on Dec 05, 2012
Testimonial: "Thanks,it is almost 5 yo and I'm not computer saavy was just hopeful:)"
    Problem Solver:
  • 10 Answers
You may need to get your PCs motherboard checked.
2 Suggested Answers
SOURCE: ispiron b130 wont turn on
Hi!
Im sorry to inform you that the motherboard on your computer needs to be replaced. If the ac adapter light turns on if not plugged into the system and when you do plug it in, it dims or flashes, that's a right out symptom that the motherboard needs to be replaced. Do you still have warranty for that system? if you do, call Dell Tech Support and have them replace it. If the warranty is already expired, please call Dell at 1-800-2884410 for an estimate on how much it would cost you to have the motherboard replaced. Usually would be around $400 - $500 and 5-8 business days. Unfortunately, you have to ship the system back to Dell for that repair.
Hope you find this solution helpful and informative.
Thanks,
Karlox™ :)
Posted on Jul 29, 2008
Turned toshiba C55t-A off last nite turned it on this morning, it says configuring windows updates, i waited several hours, now says update failed reverting changes. But wont stop doing only that. Took...
In most cases if you are running Windows 8 you have to reinstall the system again. Try to learn to select updates manually cause not all Automatic Updates are needed for personal computer use.
Nov 07, 2014 | Computers & Internet
Wont power up
there is may be 2 problems
1. check your CMOS battery. may be that battery is discharge. if yes you have to replace it.
2. may be your processor is not seance by your motherboard. in that condition you have to repair your motherboard.
Jan 03, 2013 | HEWLETT-PACKARD HP G72261US Notebook
Wont start
Sounds like a wiring problem at the gas tank.
I would check for voltage and ground for the fuel pump and the sending unit for the gauge.
Aug 17, 2012 | 1995 Ford Contour
Dell Optiplex 775 Power light, is flashing, wont turn on. I have recently replaced the PSU with a brand new dell one, as i was getting booting problems, since putting the new one in, i just get the...
could also be a ram stick that ate it. Also some of the older mother boards dont have a 12 volt supply that new cpu chips need might check that as well. Make sure the power supply is turning as well as cpu
Sep 03, 2011 | Dell Optiplex 755 Minitower Desktop...
Ran fine last nite, today engine wont attempt to turn over, tried relays and fuses
These are very common to have ignition switch problems. First observe the lights and gauges on the dash for normal operation.Checking for security light flashing [this will indicate if the lock housing transponder failed] I would test the starter next.
Nov 25, 2010 | 1999 Chevrolet Venture
Light Status on Netgear WGR614
Access router. What does it say? did you set up the wireless network yourself? Is the cable modem working properly? Rebooted it? Is there a problem with the internet provider?
Dec 14, 2008 | NetGear WGR614 Router
Sony ericsson w910i
remove Battery and then try again
Oct 05, 2008 | Cell Phones
Flashing red charge is that right
it was flashing red ,now it is a stead red, I have not seen it go green it's just that a few weeks ago i charged it all nite and bam the next morning nothing! so i was panicked as i am leaving for vacation tomorrow and need it!! so maybe since it is a constant red it's okay now?
Apr 29, 2008 | Cameras
Does it stay on with no RAM and/or CPU
Laptop will def not power up without ram or cpu.
Can you test the hard drive in another pc?
Jan 05, 2008 | Toshiba Satellite M45-S265 Notebook
Can't turn on Computer
Have you attached the CPU power cable from the PSU to the CPU power terminal next to the CPU. Double check you have the power and reset connectors tthe correct way around.
Jan 28, 2007 | NZXT GUARDIAN ATX Mid-Tower Case
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
