My celestial ac has the running light flashing but will not work,any clues
My 1999 Ford winstar gauges go crazy when running the a.c. once the ac has been on for about ten mins the gauges will go crazy i lose the power to use any of my lights or turning signals. If i don't run...
Sounds like the main board is going but also check to see if ground on battery is loose also check for corrosion on battery terminals check ground wire on alternator and have your voltage checked at a shop or local advanced auto or similar store have then hook the code reader to the mainbrain as well while ac is running and lights are on then check with car controls off this may give a clue or even solve problem
Feb 14, 2015 | Ford Cars & Trucks
06 Equinox won't run with A/C on. Runs fine with A/C off, but when we turn on the air the engine starts sputtering and dies. Check engine light has not come on. Anyone got a clue to what's wrong?
The ac maybe trying to lock up,if it effects the engine performance at ,lets say a 45 mile a hour run,then the ac compressor maybe trying to lock up,if it does not ,then it is a idle problem with the ac turned on,the computer is not idling up with the ac turned on.
May 12, 2010 | 2006 Chevrolet Equinox
1998 dodge caravan. AC problem. My AC doesnt work, the lights on the dash are blinking. I took the Van to C-Tire to get the AC recharged as the AC clutch was not turn when the van is running. C-tire did a...
do this calibration reset, it will usually rest he lights and the ac will work again, if it doesn't reset you have a part failure and the dealer you need to hook a Chrysler scan tool to diagnose the problem.
CALIBRATION/DIAGNOSTICS TEST ENTRY
TO INITIATE TESTS:
Set Blower motor ON HIGH
Set Mode position to Panel
Set Temperature to Cold (Both slide pots if equipped)
Depress WASH and REAR WIPER button simultaneously for 5 Seconds (Until all LED's light)
RESULTS:
All LED's will turn on for 5 Seconds
Calibration Test is running when REAR WIPER and INTERMITTENT are alternately flashing. Cooldown test is running if A/C and RECIRC are alternately flashing.
Acceptable results is REAR WIPER LED is the only LED flashing. Push Rear Wiper to exit.
After all tests have passed, Calibration Diagnostics and Cooldown can be run separately
Jul 26, 2009 | 1998 Dodge Caravan
91 chevy 1500 ac light flashing
try disconnecting the negative battery cable for ten minutes to reset the computer.
good luck
Jun 24, 2009 | 1991 Chevrolet K1500
Split system Celestial turn off for a while when runnig and then turns back on again head unit continues to run power light has been flashing when this happens.
Turn off while running and then turn back on again, causes electrical control circuit system was malfunctioning due to overload relay trip off and then this will trigger on when the load was cold setting the unit run again.Overload tripping off due to there's a high current flowing in the circuit w/c is higher than the rated current specified in the unit.Several factors may be consider the head unit is developing hi pressure that causes electrical circuit malfunction.or the thermostat is defective or some thermostatic valve is mulfunctioning.
Feb 19, 2009 | Heating & Cooling
Celestial split system air conditioner
I am a repair man and have had this problem quite a few times, check that the remote is set to heat and 30 degrees.usually a symbol like the sun,very similar to cool easy to mix up.If the a/c is set to heat the indoor fan will not start till outdoor unit has heated coil.
Jul 16, 2008 | Heating & Cooling
Celestial tv no remote
We have a Celestial TV and the remote has broken - just keep the tv on standby and when you want to turn it on hit one of the volume buttons.
Any ideas on where i could get a new remote - Do you know who the manufacturers of Celestial are?
Jun 28, 2008 | Televison & Video
The "tank full" light flashing
You can find a user manual at http://www.toyotomiusa.com/products/manuals/TID-2400%20(Type%20A,%20B)%20-%2020456095%20-%20Multi%20Lingual.pdf
Jun 08, 2008 | Toyotomi TID-2400 Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
