Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Jenn-air Broil element operates while in Bake mode, until safety shutdown setpoint reached, then oven shuts down with "bake" display flashing, but no fault code.
    Top Expert:
  • Jenn-Air Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 05, 2012
4 Suggested Answers
  • 10865 Answers
SOURCE: My Jenn air SVD48600P heating element dose not heat
Hi. I believe this info. may assist you in getting your bake and broil up and running:
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
Posted on May 31, 2009
SOURCE: Jenn Air Range SVD48600P Oven heating elements not
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=43495&diagram_id=661873#d661873
Above is your parts diagram.
If the element melted then a considerable amount of current must have flowed through all attached Componentry. Including the Element switches which are most likely burnt out too, the contacts evaporate.
You also have Thermistor sensors these too most likely will be Open Circuit, you need to check with a meter, they should be SHORT CIRCUIT.
The sensors cannot be "Reset" they must be replaced.
You simply need to trace out where the wires go BACK to the controller, and see if you have voltage at this point, work back testing as you go, until you find the mains voltage again, the replace any components that are NOT passing the current through.
The circuit is pretty simple, from the mains IN switch, to the Element Control from the element control through the Relay, and onto to the element itself. The relay can also be "Turned Off" via the "Control circuitry" too.
Posted on Nov 12, 2010
  • 842 Answers
SOURCE: bake element burned out on
HI,
You should have 120 to the element when not in bake mode, while in bake mode you should have 220 - 240 volt. Sounds like you lost a relay to send the additional power to the element, or you have a High Limit thermostat which could be open. This is a safety device to protect the unit from over heating, this only goes if temperatures increase higher the safety levels, normally set about 200 degrees or so along the air flow channels. I would trace from the elements to the clock and find the missing source of current.
I hope this helps
Be safe with electricity......
Posted on Jul 26, 2011
Testimonial: "Perfect! it was the high limit thermostat.Thank You for your help"
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 | Ovens
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
Bake element burned out on my Jenn-Air SVE47100 Slide-In Electric Kitchen .I replaced it but oven does not heat ,when i turn oven on and check each terminal of bake element (and broil element)from ground i...
HI,
I hope this helps
Jul 26, 2011 | Jenn-Air SVE47100 Slide-In Electric...
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
Our Jenn-Air double oven is 10 yrs old. Will not
There are 3 things that can cause this:
1. Bake or Broil element faulty. The oven cycles these on and off to reach and maintain the average setpoint temperature. If the elements heat poperly during the time they are ON, then they are OK (may be able to see them glow).
2. The temperature sensor probe is faulty. This can cause the oven to think it's hotter than it actually is.
3. The above two causes can be easily diagnosed by a technician with an ohm-meter. If they are both OK, then the problem is in the controller itself. If this is the case you may want to have us repair the controller. We see this fault quite often.
Hope this helps you out.
Regards,
Bruce
www.fixyourboard.com
Oct 10, 2009 | Jenn-Air JJW8230D Electric Double Oven
GE Oven JTP15BW Broil Element on, Bake Element off during baking.
I have the same problem. Just swap the 2 wires that are marked as 'broil' and 'bake' on the controller board. But sometimes it switches back, then I have to swap the wires again.
You might want to leave the 'broil' post unconnected to prevent burning food..
Nov 21, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn Air Range SCE30600
i would pull unit out adn look for a bad thermostat on back wall wired inline from bake and broil elemnts, probably tripped during a clean cycle or something got to hot, common for oven to shut down because of bad safety thermo, yet stovetop function without interuption
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Whirlpool built-in single oven AKZ451/IX/01
If this is an older oven, check to see if it has a control knob or switch labeled "manual and "hold". Make sure it's set for manual. The hold setting maintains temp at about 140 degrees.
If not the case, is this gas or electric?
Nov 11, 2007 | Ovens
Jenn Air wall oven-Broiler element comes on and will not turn off....
Boone, by the sound of your post it sounds like the power relay board could be bad. If you had a stuck or shorted keypad, you should be getting a different code. The F2 code means an overheated condition. If it's a double oven it could mean a secondary board failure. The way to go on this would be to ohm out the temp sensor first. Should read about 1100 ohms at room temp. Another way to check it is to swap the bake and broil wires on the power relay board. They will be marked BA and BR. Fire the oven up again and if the bake element comes on then you know that the broil relay is stuck or shorted. Without being there to do the tests, I believe that the problem lies in the power relay board. The part number for the board is 71003431. Priced around 116.00. Jenn-Air usually has a 5 year warranty on these parts. Hope this points you in the right direction. Catriver..post back
Apr 10, 2007 | Jenn-Air JJW8527C Expressions Collection...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
74 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
