Question about Tools & Hardware - Others
TROUBLE STARTING A 14 HP VANGUARD ENGINEWITH TWIN OHC
Engine will not turn over[start].I tried removing both spark plugs and spraying a very small amount of starting fluid...Engine starts to turn over,then it stops.This happens every time I spray with starting fluid.Can anyone help..The plugs are new,all wires seem to be connected,and new gas.I removed the clamp on the fuel line near the pump,and ir is fowing.Thank you. Also,the electric does not work...someone told me it needs to be remagnetized
  • 3,498 Answers
Hey Steve,
Sounds like the carburetor needs a professional cleaning and setting,, check the battery for COLD CRANKING AMPS<<< toy might find out its bad..
Posted on Jul 05, 2017
  • 2712 Answers
SOURCE: fuel pump
Can you hear the pump when you turn the key on normally? When the pump on my old FJ starts up with the key, it makes enough racket to let you know. Your bike is alot smarter than mine, it might be able to tell that the lines are unhooked and preventing the pump from working as a safety thing. Is the fuel line made of or contain any metal? It may need to see continuity in the fuel system to allow the pump to operate. Or some other parameter is not being met with the lines disconnected. Have you tried thumbing the starter with the lines off? The bike might only pressurize the system when the engine is starting or running.... actually, this is my best guess now that I think of it.
Posted on Nov 20, 2008
  • 1118 Answers
SOURCE: engine turns over fine , car will not start.
well the first part of your question i was all ready to tell you to put a new fuel pump in, now not so sure, there is a relay for fuel pump, can you hear pump cycle and relay click? relay under hood you will have to listen close they don't run long maybe a couple secounds, if you don't relay bad. if you do pump could be bad, do fuel pressure test pump could be weak. don't think sunroof and turn signals are related, but stranger things have happend.
Posted on Jan 25, 2009
  • 40 Answers
SOURCE: 95 chrysler lebaron gtc 3.0 starts for a second and then stalls out
What is the fuel pressure reading at the fuel rail?
Posted on Mar 19, 2009
  • 130 Answers
SOURCE: Tecumseh 17.5 hp ohv engine won't start
check valve clearance. if ok you going have change carb.sometimes i rebuild a carb everthing seam ok but carb wont work right so i have get a new carb and it works fine evertime
Posted on Jul 21, 2009
czaa
  • 4888 Answers
SOURCE: i'm having trouble starting my
i dont want u to be a partz replacer like those dealership boyz-it could be that the fuel pressure regulator is bad-thats why repair manuals r so good-see u r gettin spark but the petrol not there-hopefully the pump was installed rite-now the regulator is in engine area n thats where to concentrate
Posted on Aug 16, 2009
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
How do you remove the starter on Briggs & stratton V-twin 23 hp
You may need to remove the engine top cover to get at it maybe not...It is attached at the top of your engine where the fly wheel and fan are located..it spins the flywheel..if your engine is vertical it will be vertical if horizontal likewise.it normally has only two mounting bolts and a small wire or two..just remember where the small ones go..pretty much a easy job make sure you disconnect the battery or you will get sparks at the starter...good luck
Jul 23, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
23 hp engine will start great when cold, but after it run a short it will not start Brfiggs&Stratton vanguard V-Twin Vertical Ohv Engine start.
it sounds like a fuel starvation problem it is very possible theres a blocked vent in the carb. the carb will probably will need rebuilding not very difficult
Apr 09, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Have a 23 Vanguard on a mud boat and when engine damp from dew or fog, engine turns over but will not start. When engine dries, starts right up.
Your coil may be getting damp or wet..try using a plastic bag over the coil..or use some spray that will keep the damness out..good luck..
Jan 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Running a Vanguard 23 Hp on my Mud Motor.\r\nQ1: developing a hard starting problem, seems like starting on 1 cylinder, after the first tank of fuel this fall. Fuel filter, spark, and plug OK. Looking at...
It sounds like your valves are out of adjustment. Your starter will bog down if it is out of adjustment and stop at the compression release.
So just take your valve covers off and set your valve lash to
.006 intake
.008 exhaust
Oct 04, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Starting problem after setting for ten days or more
Take the spark plugs out when this occurs and try to pull it through--does it expel fuel or oil? This should tell you whether you have a flooding fuel problem, or maybe the crankcase is overfull of oil causing it to leak into the combustion chamber through worn valve seals or piston rings. Hope this helps!
May 27, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
How to change electric starter on vanguard 14 hp v twin vertical shaft.
Please, help me to regulate valves on Vanguard B&S 14HP OHV model:294446 tip:1141-a1. I don't know how. Thenks. My adress kolya-kolyanof@rambler.ru
Mar 31, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine won't start unless you us starting fluid then it runs fine
Starting fluid is REALLY bad on this engine.
Try WD 40 before ever using starting fluid.
Time to change the plugs. and look at the choke for proper adjustment,
Next start using a fuel inhibitor along with some gas treatment with your fuel, this should clear this little V Twin up.
This motor has a history of bending push rods, make sure you change your oil every 30 hours.
Hope some of the tips help.
R.
David
Jan 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Our Vanguard 14 hp was idling and stopped. It
If this engine has been sitting for awhile I would guess the carb. is gummed up and need a good cleaning. First thing I would do is try a fresh spark plug. Just because the plug looks good doesn't mean it is. If you have a fuel filter check this also. If it is getting fuel into the carb and has spark and compression I would remove the carb and clean it.
Hope this helps
Bob
Oct 23, 2009 | Briggs & Stratton Tools & Hardware -...
Tools & Hardware - Others Logo
225 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
