Question about Dell 926 All-In-One InkJet Printer
Dell laser printer doesn't detect paper to print
New Delll laser printer says it is not detecting paper, but there is paper in it. It did not print anything when it was first set up as a test.
Dell is sending me a replacement printer, as the help desk couldn't help.
Posted on Jan 12, 2009
Delll 3150 cyan streks
This could be caused by some of the ink jets on the cyan print head. Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
The cost of a new print head is expensive and it maybe better to buy a new printer.
Oct 10, 2012 | Dell 3130cn Color Laser Printer
Doesn't pick up[ paper
Possible that the intake detect or the pick in rollers are not aligned properly . You need to check the opto-couplers and the roller settings.Remove and check with a paper to see the uniformity of the gap between the rollers.
Jan 20, 2012 | Samsung ML 1610 Laser Printer
Cannon mp530 says load paper when paper is loaded
Paper not loaded error is displayed by the printer when the printer doesn't detect any paper. Here try this one.
  • Make sure that your paper is properly inserted.
  • If properly inserted and still the printer doesn't detect it. Try putting more amount of paper in the tray.
  • Be sure that there are no damaged paper in the tray.
  • Clean the rollers using a cotton buds and a clean water.
  • Now try printing again.
Hope my solution will help. Thanks for using fixya.
Jul 08, 2011 | Canon Office Equipment & Supplies
Lexmark E350 won't detect paper. Have to open and
hi
some printers when cartridge finished do this action
(cartridg has a IC that count prints for example 5000 prints)
Jul 02, 2010 | Lexmark E350d Laser Printer
Dell 3110cn - Load MPF 024-969 letter plain error msg
dell mfp laser 3115cn giving me 024-969 no paper detected
Oct 26, 2009 | Dell 3110cn Laser Printer
Dell laser printer is cutting off about a 2 inch margin. No settings are off
Cutting off at the bottom? It is likely it is detecting the incorrect size paper. There is usually a number of levers against the paper tray - try removing the tray and verifying the paper is in there correctly - the guides are up against the page, and if you are using a4 or letter or whatever, make sure the program is set the same, as is the printer in its menus. Print a menu page, it should show you.
See if that helps.
Apr 26, 2009 | Xerox Phaser 7750GX Laser Printer
Dell 3110cn Laser Printer No paper detected 024 965
remove papaer tray and look for a small black arm which should swing freely it most likely hangs down from the base of the machine or it may be jammed up into the slot it enters to activate the papaer detect switch
LUV
JAFDEE
Jan 29, 2009 | Dell 3110cn Laser Printer
I have a delll laser printer 3100cn and I want to print labels and I insert them and it will not print
You need to specify from your computer that you want to print to the MPF tray.
Jan 04, 2009 | Dell 3100cn Laser Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
61 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
