Question about Refrigerators
Water dispenser on fridge not working - water pressure fine, could the line be frozen and why would that start happening all of a sudden?
Model Superba KSRA22F - about seven years old. At first water was coming out slowly, then I changed out the pipe from the water source to the fridge which increased the velocity of water. Then it started intermittently not dispensing water (you could hear the pump trying to dispense it but no water). Then it stopped all together. So, I just defrosted the fridge/freezer and sure enough, the dispenser now works. Which leads me to believe that the water is freezing somewhere in the line in the door (the water line runs up thru the freezer door to the dispenser). So, has anyone heard about KitchenAid having these problems and why would it start to happen all of a sudden? tx.
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Check to see if the water reservoir in the bottom of the frig is frozen. If it is, you will need to turn the frig temp down.
Posted on Dec 05, 2012
fridgetech
  • 473 Answers
SOURCE: KItchenaid Superba KSRB25QABL water dispenser
Chances are is a bad water valve.  The water valve is on the back of the fridge at the bottom.  You will see the water line going into it.
Posted on Oct 12, 2007
  • 23 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Posted on Dec 08, 2007
MNTECH
  • 1543 Answers
Water dispenser works fine eliminates some potential probems, so disconnect the water line at the outlet of the water valve leading to the icemaker. Blow into the tube (with the freezer door open so the air has an escape route.) If you can't blow through the tube, check where the tube passes into the freezer section for an ice blockage. This would result from a water valve not shutting off 100 %, allowing a little water to dribble in and freeze the inlet shut. If you can blow through the tube, most likely the electric solenoid coil on the water valve supplying the ice maker water is bad. In either case, replace the valve. (it is a dual solenoid valve, part # 2315533)
Posted on Sep 08, 2008
tech master
  • 120 Answers
SOURCE: kitchenaid superba 42 side by sside water dispenser
usually when i get a kitchen side by side i trouble shoot the wtr valve first by using a cheat cord that applying volatge directly to the vlave to see if it opens but usually the wire harnes under frezeer breaks the wires so my money is on the wires under the frezerr door cut the sleve off and chec the wires one by one the one to the water is broken
Posted on Nov 03, 2008
Sea Breeze
  • 4654 Answers
SOURCE: My water dispenser stopped working. When I try
That can only be a blockage from the valve or crimped water line or a defective solenoied on the dispenser side of the water control valve part number WR57X10032
Sea Breeze
Posted on Oct 23, 2009
Everything normal on my GE Profile Model PFSF6PKWBBB French door bottom freezer refridgerator except the water dispenser just quit dispensing water. Is it frozen? How do I fix it?
The paddle that you push the glass against to dispense water activates a microswitch. Sometimes this switch can break off it's mount and drop away from it's intended position. The microswitch operates a solenoid valve near where the water line enters the back of the fridge. Then there's the wiring in between them. The water line doesn't go through the freezer. It runs through the refrigerator in a coil of tubing then into the door of the dispenser. Check the paddle switch, the water solenoid and the wiring and you'll find the reason it doesn't work
Mar 05, 2016 | GE Refrigerators
Water line keeps freezing on my GE side by side refigerator
Check to see if the water tank in the bottom of the refrigerator section is frozen. If it is, you will need to turn the refrigerator section temp down.
Dec 05, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Sep 07, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
GE Profile Performance - No water dispensing or ice making
NOT ENOUGH WATER PRESSURE AT WATERLINE OR WATER VALVE IS BAD AND NEEDS REPLACED
Jul 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water drips slowly out of dispenser, ice distribution is fine.
Hi, yes the water line could be starting to ice up; maybe defrosting the fridge will cure the problem. Mine has a coiled tube behind the lower drawer in the fridge, this is where the water line is chilled. Hope this helps if you've not sorted the problem already. Kind regards jb
Jul 02, 2009 | Whirlpool GS5SHAXN Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Water dispenser not working
I am currently experiencing the same problem. It happen when I pressed the rapid cool button on the inside of the fridge and the temperature went down to 36 degree F. I assume that my water line is frozen. As soon as we use up some of the food in the fridge, I'm going to clean out the fridge and let the temperature rise, hopefully thawing the blockage. This is the only thing that I can think of.
Mar 25, 2008 | Refrigerators
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
