Question about Music
Sesame Street One Key One Note Manual
Childrens Sesame Street Elmo Keyboard Model KSE316
Have a main street keyboard, model mkb-61ts can't get keys to play, do not have the manual.
Try Googling (main street)(mkb-61ts)(manual) without parens.
May 30, 2017 | Music
Roland BK-3 is in Key of D even after factory reset. How do I tune it to C without changing the key setting?
What brand and model Keyboard is it??????
For the sake of brevity, try powering down. Then, power up holding the last note on the keyboard, Some models use this as a factory reset feature, but then again you haven't mentioned the brand or model...
May 26, 2015 | Music
Every is out of tune
There is a POT at the back of the keyboard to tune the keyboard.
Download "AP tuner" to your laptop to help you tune. If you use a desktop PC, you need to connect a good microphone.
May 25, 2012 | Casio WK110 76 Key Portable MIDI Keyboard
Can i tune the privia 130
Refer to page E22 in your user manual. Please note that the default pitch is crystal controlled and quite accurate, but if you need to detune it you can do so as well as changing the temperment.
Jul 03, 2011 | Casio PX 130 Privia 88 Key Digital...
Yamaha W 7 keyboard problem I have a Yamaha W 7 keyboard. Every now and then when I play the note A left of middle C the note keeps replaying or re-hammering while holding the key down. This started a...
under the keyboard there is a switch for each key, try to clean it whit water and a smooth paper. I have Roland keyboards and it happens after playing a lot.
good notes
Feb 07, 2011 | Yamaha Portable Keyboard
Thomas jester 132 organ troubleshooting E-flat below mid c not working correctly on either keyboard or foot pedal all other keys ok volume pedal is scratchy but works ok
Here is where you can get the service manual:http://celedoniaorgan.netfirms.com/cosco/nfoscomm/catalog/product_info.php?products_id=1021&osCsid=3eaaa99d6bfceeaaf9b844687ba58d55 Since the problem is with the foot pedal note and the keyboard note I would suspect that there is a problem with the tone generation circuit for that note. You might try cleaning the key contacts on both for that note first to see if that works. The volume pedal probably just needs the volume pot cleaned with contact cleaner spray. I hope this helps. Let me know if it does.
Nov 26, 2009 | Music
Fredy 2 I am trying to play chords with my fingers, there is no sound, if it is on any other mode the chords work but i need it to be on fingered mode thanks doreen
OK... It wasn't clear from the original.
Sometimes the keyboard has a mode that splits for upper and lower part of the keyboard, usually splitting at the F#/G. Also CERTAIN voices will ONLY sound one note at a time. Piano setting would not have this problem of course.
When you play a single note does that sound? If it doesn't in the fingered mode, then there may be a processor problem in the unit/
If it does, there is probably a problem in the matrix that scans the keyboard electrically. If one of the keys were ELECTRICALLY stuck on, the processor within could not read whole sections of the keyboard.
To troubleshoot the problem, press exactly one key at a time... do they all work for say a piano voice while in the fingered mode.
Next press a key at the high end of the keyboard and try others. See if you can find an octave that fails to work.
The problem is likely imbedded in the electronics and could be anything from a dirty key contact to a cracked circuit board. It is NOT likely you can fix this yourself unless you are experienced in electronics.
Sep 28, 2009 | Casio Music
A really bad 'off key' note
what is make and model? I have owned several keyboards, with 2 of them Korgs in which I would connect a damper pedal. I noticed that when I help down the pedal, after so too much input within the cpu of the keyboard, it would 'short-circuit' and sound like I had played an 'off-key'
If you have been using the damper pedal, and even if you release a little on up on it, but not all the way, the 'off-keys' will still sound. I must always make sure the pedal is placed in a position that my leverage action of my foot will completely 'release' the overtones still being processed by the keyboard (whether they're audible or not)
Jan 11, 2009 | Music
Psr e303 yamaha double sounds
Do you cover the keyboard when not in use as small particles of dust can make their way in between the keys?
You can try blowing any obstruction out with a can of compressed air, may solve your problem.
As I'm not familiar with this Model, does the keyboard have 'touch response' on board? If so there will probably be a 'Contact' strip made out of tubular rubber under the keys and this can sometimes 'burst' especially on a certain key that is played most of the time. For example if you play mostly in the key of 'G' or keys that use that note....
Hope you find this helpful......
Dec 28, 2008 | Yamaha Full-Size Keyboard
Music Logo
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
