Question about Cycling
How to convert a Giant Halfway folding bicycle to electric. I'm sure it can be done. Rear rack for battery. Single sided hubs?
5 Suggested Answers
ptebigdave
  • 4 Answers
SOURCE: squeaky Urban Mover rear brushless motor hub
lube the ball bearings or change them out compleatly
Posted on Jan 16, 2009
Coachphil
  • 347 Answers
SOURCE: I have an AVANTI Blade
This is a solution I strongly recommend you take into a bicycle shop. It will either be a problem they can fix (needs to be seen to properly diagnose) or a possible warranty issue which they would be the ones to take care of anyway.
The problem could be anything from an adjustment, which is far to complicated to explain with those hubs up to a broken part.
Posted on Jan 06, 2011
dunnbiker
  • 8546 Answers
SOURCE: How do I mount a
Google "bicycle rack adapter"
Posted on Jun 04, 2011
  • 20 Answers
SOURCE: removal of rear wheel with internal geared 3-speed and coaster brake hub
Find the joiner link on the chain, remove the retainer clip followed by the link. Remove the chain. Remove the bolt holding the brake arm to the frame. Loosen the axle bolts on the wheel enough to be able to slide the rear wheel out of its slots on the frame.
Posted on Feb 24, 2012
Needto lubricate rear wheel bearings on a huffy single speed bike
as most bikes do not have seals on the wheel axles , it is possible to lay the bike on the side , use machine oil on the hub and axle area and spin the wheel while allowing drops of oil onto the axle bearing hub area
or you can take the hub apart and fill with a very light grease
Jul 23, 2015 | Huffy Cycling
Creaking noise
I know, this can be extremely frustrating...
First and easiest, check that your rear wheel is tightened completely, this can also sound like suspension noises.
Next, a bit more effort, unscrew your pedals, clean out the gunk, put some grease on the thread and replace, tighten securely.
You might also have to check your wheel bearings, mine is in the shop at the moment because of this, bearing issues...
I would also check the BB (bottom bearing) where your crank goes through, before the last step. This can also cause a lot of noise.
Lastly, if it is your suspension, you will have to take it apart, every link and check every bearing, they so have a limited life, clean out all dust and grit that gathered inside, replace and grease all bearings and links, but don't over tighten the links.
Here is a full service manual for you:
https://www.giant-bicycles.com/_upload_it/bikes/models/manual/Anthem%20Service%20Manual.pdf
For a full suspension service, you will have to look at every single point that hinges on your frame, I count at least five on one side.
Hope this helps.
Dec 30, 2013 | Giant Anthem X2
This is the first time i switched from riding a MTB to a bike with internal hub. I can't help but noticed that whenever I switch to number "3" on the internal hub which corresponds to the...
Other than the ticking sound is there any problem? The gearing is planetary and has its own 'normal' sounds depending on what ratio is selected.
Maybe it needs specific tweaking.
http://www.parktool.com/blog/repair-help/internal-gear-hubs
Sep 21, 2011 | Dahon 09 Mu P24 Folding Bicycle
Trying to install Sunlite HD tourer rear carrier #45772. on a Rand 18 speed. There are no holes for front brackets in frame. Do you just drill the holes?
Never drill holes in a bike frame unless you have a death wish. "Rand 18-speed" doesn't tell us much. Most cheapo bike frames have a 'brake bridge' with a hole on the center for mounting accessories like fenders. Many racks can mount with a single rather than double front supports.. Lacking that, call a bike shop or web search for "bicycle seatstay rack clamps" to adapt the rack to attach to the seat stays.
Sunlite also makes a seatpost rack mount http://www.bikebagshop.com/sunlite-rack-mount-seat-post-clamp-p-1146.html?gdftrk=gdfV22203_a_7c1316_a_7c5544_a_7c11461678151 which looks like a more elegant way to solve the problem.
Sep 13, 2011 | Cycling
I have some space between the rear axle and the bearing hub on my Raleigh M40. Can you tell me if you have both an axle and the the bearings hubs for each side?
We don't supply parts. Advice. Take the wheel to a bicycle shop for an assessment as the parts are not universal among the different hub makers.
Aug 20, 2011 | Stickers Raleigh Mountain Road Tri Race...
My pedal has somehow broken inside and now it spins freely without moving the chain
Being a mechanical problem that we can't see you will need to define it better to us or yourself.
I'm sure if you looked at it closer you would see that the pedal itself is supposed to spin freely while it turns on the crank which turns the chainring which transfers motion through the chain to the gear(s) on the right side of the rear wheel which drive the wheel forward.
Now, where do you think the breakdown really is?
Any search engine would then offer definitions and solutions to a well-crafted query like "bicycle chain slipping" or "bicycle gear slipping".
Aug 15, 2011 | Giant Boulder Se Mountain Bike 19"...
(giant brass sx) its not so much as a problem as it is a question iwas wondering if i could convert it to a single speed
Any bike can be converted to single speed.
Any search engine answers how "convert to single speed mountain bike"
Aug 13, 2011 | Giant 09 Brass Sx Dirt Jump Freeride...
My daughter has a Schwinn Sidewinder 26" mountain bike. The chain keeps jumping from the rear sprockets to a smaller sprocket under power. I have noticed that the rear sprocket set "wobbles"...
It's loose on the hub. Special tools are required to tighten them. Bike Shops have them and will possibly perform the repair for less than the cost of the tools.
http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service
Then check the shifting...
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Word to the wise: don't buy bicycles from anywhere but a professional bicycle shop. Box stores don't usually have the skills for proper assembly, setup or follow-up.
May 24, 2011 | Schwinn Cycling
Cycling Logo
56 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
