Question about Refrigerators
We have a one-year old SAMSUNG REFRIGERATOR which became inoperational due to the effects of flood last "Habagat". Our neighbor-technician said we have to replace the thermostat. Where can we buy it
Refrigerator Model No. RA19PTMU Gross Capacity 186Lt(Fre:32Lt.Ref:154Lt) Net Capacity 178Lt(Fre:26Lt.ref:152Lt) Dimension(WXDHX)540mmx1204mm Symbol of Nature Supply: ac(-) Rated Voltage: 230V Rated Frequency: 60Hz Rated Input:100W Rated Current: 1.OA. Climatic Class of the Appliance: T Regulator Class of Motor Compressor Winding: B Rated Maximum Input of Lamp: 15W Name of Refrigerant: R-134a Mass of Refrigerant: 130g Insulation Blowing Gass: Cyclopentane Net Weight: 35.74kg MADE IN THAILAND: DA99-03485C
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
Here is the temperature thermostat for that unit.
Posted on Dec 05, 2012
dididsaythat
  • 291 Answers
SOURCE: Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Posted on Oct 14, 2007
SOURCE: Maytag stopped getting cold, buzzing noise every now and then after pwr outage
Frig requires either compressor relay or the compressor itself...should have some warranty still, so call an authorized servicer. Ray
Posted on May 30, 2008
Illeagle
  • 525 Answers
SOURCE: the replacement compressor for a TECUMSEH COMPRESSOR S/NO : TP103JR007B5
This link will take you to a parts suppliers compressor page where you can look up the part number and order information. Their toll-free number is at the top of the page.
http://70.168.42.43/servall_wda.htm
If this doesn't help, post me back and I will do some more research to help resolve your issue.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 26, 2008
  • 116 Answers
SOURCE: Maytag MSD2756DE refrigerator start relay
An interruption in the power supply would usually show in other electrical fixtures in the house. A UPS is not recommended for a power back up on a refrigerator.
The condition you describe usually indicates that either the compressor is working too hard and drawing too much current or the start relay is gone bad. The starting and stopping that you hear is a safety shut-off within the relay. A good place to start is changing start relay for the factory recommended one.
If the standard relay does not correct the problem, there is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system. Outside of this may require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a refrigerant leak.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor if needed.
Posted on Aug 05, 2008
Krazytech
  • 725 Answers
SOURCE: Capillary tube replacement
The True TSSU-60-16 uses an oversized (134A) refrigeration system with air flow directed at the pans.... if the capillary tube is plugged it will NOT cool at all.. most of the time a restriction (plug) is at the drier where the capillary tube goes into it.. as it is smallest passage in the system...hope it helps
Posted on Sep 02, 2008
We have an 84e error on Samsung refrigerator RFHMEDBSR/AA I looked it up and it tells me what I already knew. Our refrigerator is only 1.5 years old and NOTHING is working.
Your refrigerant compressor rotor (it is what make the fridge cold) is locked up most likely. Read on please. I see way too many Samsung high end units like yours fail very early. My last Whirlpool lasted 25 years and only replaced it (with another Whirlpool) to lower electrical cost.
This is actually a very bad error code on these refrigerators. It means the rotor is locked up inside the compressor and the only way to solve this issue is to actually replace the compressor. Unfortunately this means a basic rebuild of the sealed system of the refrigerator. It's a pretty big job to do this. You not only need special tools you also need a special license to recover the freon from the refrigerators sealed system.
I have however been able to solve this problem twice out of the 7 or 8 times I've seen this error by simply replacing the inverter control board on the back of the unit by the compressor. The inverter board on the back is usually flashing four times which means again locked rotor.
Fortunately for every one of these that I've seen they have been covered under first year warranty. Now I know that doesn't say a lot for Samsung but remember no matter which brand appliance you buy it will have issues eventually. Things just aren't made like they used to be. I hear it everyday my old refrigerator lasted 2o years.. You'll never buy another one that last that long..
May 19, 2017 | Samsung Refrigerators
Samsung refrigerator RFG238AARS isn't making ice or dispensing water. How do I reset from the back?
Check your manual for resetting the unit electronics. It should be mentioned.
Dec 28, 2016 | Samsung Refrigerators
Model #rb215lash
I know nothing about your model, but in my experience with refrigerators over the last 40 years, they can make a whole range of different noises at different times. There's even a note in the manual of my GE side by side something to the effect that strange noises are to be expected. I'm amazed at the range of different sounds that comes from our 10 year old GE. It's hard to say ignore noises because I never ignore a new noise from my car, but unless the same noise repeats under similar conditions, I'd not rush into trying to 'fix; it.
Apr 14, 2014 | Samsung Refrigerators
I have a Goodman A/C cplj36-1B that's making a loud rattling noise; however, it is still working. a back yard ac guy came out took the cover off and said it was the compressor going bad. my electric...
Hello, the rattling sound very well may be the compressor as the internal parts are wearing out or liquid refrigerant flooding the compressor. Best thing is to have a technician attach gauges to the unit and observe the operating pressures, this will determine the cause. Also the electric bill will be higher if the compressor is drawing more amps due to it going bad.
Sep 30, 2011 | Heating & Cooling
Dear sir, two year back i have puchases a samsung reg 185 ltr, but due to some accident the front door is not working properly & now last night the door fall down with hinges ... now the fridge is in...
Replacing door only not possible by manufacturer.Better call tinker man. He could do rectify if any bending or dental It's economical and advisable.
Jan 22, 2011 | Refrigerators
I have a ten yr. old Sub Zero model 642. The
maybe a re-gas will last another ten years...if the leak is that small a re-gas will probably last it days out....ask the service man to re-gas it so the food does not spoil until you can save up for replacement...then just see how it goes.
Jul 21, 2010 | Sub-Zero 690 Side by Side Refrigerator
Lose picture became dark
look to solve this problemthree suggestions 1st check cables if they r properly connected 2nd check mak sure that its ont he right channel 3rd last if my fist two steps didnt work call tech support
Jul 23, 2008 | Samsung LNT3242H Television
Kenmore Refrigerator making loud sounds at shutdown
the compressor has a loose or broken spring inside the compressor, unfortunatly it can not be repaired without replacing the compressor, it could last many more years and it could quit as we speak.
best thing is to let the neighbor know of the problem and what is the repair that way they won't think you are ponning off the machine to them, it may outlast your new one, time will tell
Apr 15, 2008 | Refrigerators
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
