Question about Refrigerators
Compressor wont start - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 05, 2012
COMPRESSOR WONT STAY ON
You replaced the compressor? Sea Breeze
May 30, 2013 | Refrigerators
PACE ARROW AC COMPRESSORS WONT START FANS RUN
Check power to compressor relay and start capacitor. Also check not low on gas
Apr 19, 2012 | Coleman Heating & Cooling
17 cu fridgeidaire freezer wont freeze
More than likely the compressor is bad. A lot of times technicians will change the start device on the compressor and if it runs for a minute they are satisfied its fixed. The proper way would have been to monitor the amperage drawn by the compressor and then there would be no doubr if it was start device or compressor.
Mar 31, 2012 | Avanti Freezers
Air compressor wont start
For air compressor not working,click the link below :---http://repairhelpcenter.blogspot.com/2012/01/air-compressor-wont-start.html
-----------Thanks.
Jan 20, 2012 | Air Tools & Compressors
New copeland compressor wont start
Hello,By all means install a hard start kit on the cap.Your wiring is correct.A scroll compressor usally doesn't need a start kit but I have seen 5 ton units that take one.Check the compressor tag and make sure the compressor is not a 3 phase motor!
Apr 21, 2010 | Heating & Cooling
Compressor comes on for a few minutes then relays start clicking and compressor shuts off. refrigerator not cooling.
And it wont get cool as long as your compressor keeps failing to start. You will need to have this tested by a professional to at least find out if its the compressor itself, or the starting kit needed to start the compressor has failed.
Without proper test equipment, you wont be able to find out yourself if its one or the other, but a house call is a small price to pay to know for sure.
www.FixMyFridge.net
Mar 08, 2010 | Refrigerators
Compresser wont start
Buy you one of those starting capacitor and load protection assembly. Available in your local ac supply. They are easy to install and reasonably cheap( about 20 bucks or less). The compressor should start. We use them when installing new compressor of if the compressor wont kick in. They work almost all the time.
Mar 06, 2010 | Samsung RM255LASH Side by Side...
My Mach3 coleman ac compressor hums but wont start. trips breaker. I replaced the start capacitor with a hard start. still wont run?
unfortunaletly the hartd start is a "last resort" and you will probably need to replace the compressor/unit... (however I have had luck physically jarring the compressor during the instant I applied power to the compressor.. sounds silly, but I have had it work more than once..) hope this helps
Aug 15, 2009 | Heating & Cooling
Please help our ac compressor wont come on
Hi, did you change, capacitor for compressor too. check compressor overload switch,(relay) normally located on compressor terminals, (where you connect wires to compressor) that's the device that goes klix when compressor goes to start, could be faulty, or maybe low voltage from your mains(house panel) check line voltage, with digital volt meter, some compressor won't start if voltage drops to low, yes fan will work, could also be, your compressor has a lock rotor, (hard start), you can buy a compressor hard start kit, from appliance store, and try to start compressor, or maybe compressor internal winding, are damage, especially now in summer, when you got a lots of voltage drops, check compressor winding, check compressor winding for short circuit, remove cover on compressor, remove 3 wires from compressor terminal, use ohm meter, put one tester lead on copper tubing that's connected to compressor, and next lead to compressor terminal, one by one, if you get beep (continuity) from anyone of those compressor terminal, you got a short- circuit in compressor, you will have to replace compressor, but if there's no short, them try hard- start kit, replace overload relay, you will see it at compressor terminal location, after you remove cover. good luck.
Aug 10, 2009 | Heating & Cooling
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
