Question about Intel PRO/Wireless 2011 LAN Access Point
Intel PRO/Wireless 2011 LAN Access Point (WEAP2011EU)
Need to set back to factory default. already tried jumping 2,3 on serial
Shayna, that particular access point does not have a paperclip sized hole for resetting. You have to bridge pins 2 and 3 on the db9 connector at the rear of the access point. After doing so, convert the last 6 digits of the serial number (in pairs) to hex. example, if your last six digits are 052161, the ip of the access point is 10.5.21.61. It always starts with 10 and the subnet mask is 255.255.0.0.
Posted on Jan 23, 2008
  • 64 Answers
Usually there is a paper clip sized hole in the back of the WAP that you insert a pin or paper clip into for 10 seconds.
Posted on Jun 09, 2007
Unable to login to WAP4410N using web based administration utility after factory reset. it's reporting as invalid username or password
Please see the Reset the Default Factory Setting please read it the Detail I have a WAP4410n wireless access point, I have reset it to factory default by pressing the reset button for 30 seconds. I am able to ping its default ip 192.168.1.245 through its default ssid "ciscosb" if I configure my static ip was solved by connecting through the lan cable, and setting manually the ip to 192.168.1.0/24 network, and accessing 192.168.1.245 through web, the reason why the connecting through WiFi was working because the management web access through wireless is disabled by default
Thanks
Apr 21, 2015 | Cisco Small Business WAP4410N WirelessN...
I enabled mac filtering on my tl-wa521og, and i cannot connect to my router's lan and even wifi.... its so hard for me reset the router because it was already installed in the tower, is there any way to...
Yes you can.
1-Login the Web-based Interface ( 192.168.1.1 or 192.168.1.254 or 192.168.0.254) of your wireless access point or extender.
2-go to the settings windows and find the reset tab (usually "reset to factory default)
3-Your are done
Mar 11, 2014 | TP-LINK Computers & Internet
How do I reset WAP4410N router back to factory defaults ?
There should be a reset button to the right (the back facing you) of the antennas on the back, press that for 10 seconds to restore back to factory default. You may also go into the the web based control panel of the router and set it back to default.
Dec 06, 2010 | Linksys Cisco Small Business WAP4410N...
NOT ABLE TO LOGIN WIITH DEFAULT USER AND PASSWORD
If there is a reset button then reset it and then try with default user name and password.
Jun 05, 2010 | Intel PRO/Wireless 5000 LAN Access Point...
HOW TO RESET BACK TO FACTORY DEFAULT SETTINGS FOR CWA-854
You need to login to the router and go to the save/reload settings section.
You can reset this Wireless Access Point back to its default settings by clicking on Reset button, and then press OK button to confirm your decision. Note: you can also hold down the reset button on this Wireless Access Point’s panel for more than 10 seconds to reset its default settings back to factory default.
Please don't forget to rate me!
Thanks
Jul 08, 2009 | Cnet CWA-854 (CWA854) 802.11b/g Wireless...
Changing the password
  1. Select Configuration|Security from the Access Point menu tree.
  2. Select Modify System Password.
  3. Configure the AP password settings as required:
    System Password Select any alphanumeric, case-sensitive entry of up to 13 characters. The characters selected are displayed as asterisks. Changing this passowrd changes the Read/Write Community password found in the SNMP Configuration screen. The default password is Intel. Confirm System Password Select the same alphanumeric, case-sensitive entry of up to 13 characters as System Password. The characters selected are displayed as asterisks.
  4. Select Save Settings at the bottom of the page.
Jul 02, 2009 | Intel PRO/Wireless 2011B LAN Enterprise...
DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Here are the steps to reset the access point from D-Link's website:
Please visit http://support.dlink.com/faq/view.asp?prod_id=1600 for complete FAQ and screen shot.
The following reset procedure will completely restore the default settings on the access point including your password.
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the access point powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The device is now at factory defaults.
You can find the complete manual for your wireless access point here:
http://support.dlink.com/products/view.asp?productid=DWL-2100AP
Mar 15, 2009 | D-Link Computers & Internet
I have forgotten my password for my wireless internet connection.
Connect to Wireless router using LAN cable.
Open Router admin page using the gateway address you get from your network status window from Systray (Support tab in XP).
Follow router instruction to set new WLAN protocol and Password (WPA-PSK for better protection) and use new passphrase (or Key) to set PC client network card protocol.
If Router is Password protected and you missed it: reset to factory settings to reconfigure.
Dec 27, 2008 | Intel PRO/Wireless 2011B LAN Enterprise...
Wireless device problem
For virtually any router, wireless access point, or modem, you will find a tiny round hole just big enough for an unbent paper clip to be inserted. The word reset may be next to that hole, but not always.
Pushing the unbent paperclip into that hole firmly for 10 to 30 seconds will reset the device to the original factory settings.
If you have the quick-start guide or manual for the device, you can use that to set it up. If not, visit the web page for the company and look for tech-support or downloads to find the manual for that particular device. You can also Google the actual device and part number information along with the words 'manual' or 'setup' and find the page that way.
Sep 05, 2017 | Intel PRO/Wireless 2011B LAN Enterprise...
Intel PRO/Wireless 2011 LAN Access Point Logo
512 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
