Question about Refrigerators
Nucool 1.7 cu. ft. Bottom vent will not blow cold air but will spin.
    New Friend:
    Problem Solver:
  • 7 Answers
You have lack of refrigerant or incorrect fan cycling,also check your compressor if running
Posted on Dec 05, 2012
  • 6 Answers
SOURCE: (1.7 cu) Chefmate Fridge Doesn't Get Cold
The Chefmate 1.7 fridge uses a thermalelectric device (TED) to provide cold air. There are no moving parts there. The problem is usually in the power supply. That is the PCB on the left side behind the back cover. If the fans are running then your thermostat is bad or the TED is cracked. You can buy these ebay or other places on line. To change one you must carefully remove the large heat sink. The TED itself is only about two inches square. If you decide to replace this unit be sure to get a supply of heat sink glue. Otherwise you will end up with a hot (or cold) spot on the TED possitly causing another crack.
Posted on May 27, 2009
docjohn174
  • 943 Answers
SOURCE: Frost build up in freezer/ very little cold air is blowing down to the bottom
HI thanks for your question. look to see if you can hear the fan motor running. if it is check for frost build up. if frost build up. its not going into the defrost cycle. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GE profile refrigerator line freezes, fan blows but no cold air?
OK, I think I understand. Thing is we need to do a few things to see if your control board is the problem or if the fan or a freon leak is the answer. You need to tell me if this began suddenly or if over a period of time. I have been having trouble lately from Fixya if the customer (YOU) responds to my solutions. Let me know if you want my help and I will see if I get a email letting me know of your response, Thanks, Sea Breeze
Posted on Jul 12, 2009
  • 219 Answers
SOURCE: AMANA BG21VL REFRIGERATOR ISN'T COLD,
check in frezzerto see if your evap fan is blowing if not need to replace it if its is u will have a defrost problem u can unplug for 4 or 5 hrs with doors open to defrost itsself . plug back in will work fine till u can replasce heater and tsat.
Posted on Mar 21, 2009
heatman101
  • 43501 Answers
SOURCE: fridge/freezer not getting cold
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 27, 2010
Heat will start for a few minutes then stop and dryer will continue to spin with cold air.
You must have a blockage in your vent line between back of dryer to the outside or a kinked vent hose or a blockage in your blower wheel cover.
Jul 16, 2015 | Samsung DV448AGP 7.4 Cu. Ft. Gas Dryer -...
Mini fridge wont get cold
How old is it? You proablaly need REFRIGERANT!!!
Jul 21, 2012 | Haier C-RNU1708B 1.7 Cu. Ft. NuCool...
Freezer working but no cold air to refrig.
check the damper vent door located behind a plastic cover between the freezer and refrige compartments,also make sure the evaporator fan is operating to blow cold air through this door,if the door isnt open,then either its frozen shut due to moisture or the motor that controls it is bad
May 13, 2011 | Jenn-Air Jenn Air Side-By-Side...
Refrigerator side is not cold
Sounds like a problem with the damper control. Some fridges gets humid air causing frost on the damper and causing this to fail. It may need to be replaced or check if the damper (the vent were the cold air comes out from the freezer) is open.
Jun 07, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Bottom frezzer is working but fridge is not blowing cold air
Refrigerator gets cold air from freezer compartment. Either the air flow is blocked by food items or ice, or the recirculating fan is not working.
The most common failure is that the freezer coils get all iced up becuase the defroster timer, defroster thermostat, or heater has stopped working.
When it's running, you should feel cold air blowing out of the vents that are in the fridge, otherwise, the 'air tower' (air vent) is blocked with ice.
If you manually defrost the whole thing, and it runs fine for a day or so, then it's not defrosting properly. If you manually turn the defroster timer, and you don't hear the scorching/hissing/gurgling of the defroster working, then that would confirm a fault in the defroster circuits.
Based on the following thread, it's probably a bad defrost thermostat.
http://www.applianceblog.com/mainforums/sears-kenmore/13766-kenmore-elite-22-bottom-freezer-refrigerator-fridge-not-cooling.html
Nov 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator is not cold on top, but still cold on bottom.
Sounds as if you have a bad evep. Fan motor. It souldnt by over $40.00. And if the unit still look and works good other than this problem. It's located behind the inside back freezer panel. Diffaculty level in my opinion is a 5 out of a scale of 1 to 10. 10
Aug 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
1,771 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
