Question about 3Com (3CRPAG175) 802.11a, 802.11g/b Wireless Adapter
I have a 1EEE 802.11g Wireless Broadband Router
My friends tell me I should have assign a password to this router but I don't have a clue how to do this. I am running Windows XP. How do I setup a password to secure my wireless?
  • John Hong
    John Hong May 11, 2010
    What is the make, model and version of your router?
  • 54 Answers
You really dont have to have a password, unless you want one. But its really not needed for this product.
Posted on Jan 12, 2009
Reset password
You need to factory reset the device using the reset button, then go through the entire setup process again to configure the router and assign passwords.
Sep 24, 2013 | Linksys Wireless-G Broadband Router
How will I change the username and the password of the router? Because my friend is trying to connect to our internet here at home, but she can't connect because the router is asking for a password...
On your computer (the one connected to the router) open in browser http://192.168.1.1 and log into router's configuration page ... there on the "wireless" section you will find "Wireless security" ... there you can set up the password.
If you don't have access to the configuration page or you have problems setting up the password, you can always reset the router to it's factory settings. To do so you have to find a slightly hidden reset button on your router and push it (with a needle or something).
For more details read the manual at: http://homedownloads.cisco.com/downloads/userguide/E1000_V10_UG_USA_NC-WEB.pdf
have fun ;)
May 05, 2011 | Cisco Linksys E1000 WirelessN Broadband...
How can i configure wireless broadband router 2.4
Hi Friend,
In order to configure the wireless settings of a router please follow the steps:
1.Open the router page (192.168.1.1)
2.Enter the username and password(default password is admin and leave the username blank)
3.On the router page click Wireless and fille the sections as mention:
Wireless network Mode-Mixed
Wireless network name-As per your choice
Wireless Channel-6-2.437GHz
Wireless SSID Broadcast-Enable and click Save settings.
4.Click Wireless settings and Select the security mode as WEP
WEP encryption-64 bits 10 hex digits
Key1- enter 10 digit or 10 letter password(like your telephone number) and click save settings.
5.Click Advanced Wireless Settings and fill these sections
Beacon Interval-75
Fragmentation Threshold-2306
RTS Threshold-2307 and click save settings
Turn off the router for 30seconds and then turn it on. Your network is now secured and you can try to connect your wireless devices.
Regards
Chiranjeet
May 19, 2010 | Linksys Wireless-G Broadband Router
I don not remember my password
Are you looking for the wireless password or the
If you want the password of the router, then try
the default password of the router. If the default
password doesn't work then you will need to reset
the router and reconfigure the router.
If you are looking for the wireless network
password, then you will need to open the set up
page of the router. Is there any computer
connected to the router ? If not then you will
need to connect the computer to the router. Or any
other computer which is able to go online using
the router. Check the IP address on that computer.
open the set up page of the router. Set up page of
the router is the page where you will find all the
settings of the router. under the wireless section
you will find the wireless network password
Click here for more information about the routers
and wireless network.
Feb 27, 2010 | Linksys Wireless-G Broadband Router
Internet not working through wireless linksys router but working when directly connected to modem
I think the problem will rely depending on the settings on your router, Follow these step by step solution on resolving the problem.
1. Connect the cable coming from your modem going through the internet/WAN port of your wireless broadband router.
2. I suggest you test your internet connection first by connecting an ethernet cable from your Wireless Router LAN port going to your PC NIC(Network Interface Card).
3. In order for you to setup your router, you should be using a web browser. Go through your router configuration by typing 192.168.0.1 / 192.168.1.1, on your web browser. The ip address depends on the manual of the router which default ip address is assigned to your router.
Illustration:
after enter the ip address, pressEnter and you should see a login box where you can type the username and password of the router.
You should check from your manual what is the default username assigned when you purchase the router. Since some routers have been using standard username and passwords.
You should use "admin" as your username and leave the password blank, press Enter / OK.
If you have a successful login, you should see a router configuration webpage where you can setup your router.
Look for the Internet Setup panel, select what type of connection you are using,
DHCP - for cable modems
PPPoe - for most DSL modems
if you are unsure, just check with your ISP.
Set the SSID to identify your router and assign a WEP (Wireless Encryption Key) under your Wireless Security section to encrypt your routers network to prevent others from connecting to your internet without any permission.
Feb 03, 2010 | Linksys Wireless-G Broadband Router
I have forgotten the password to my wireless router network (linksys wireless-G broadband router, 2.4 GHz). How can I access in order to add an additional computer to my wireless system?
Use an Ethernet cable to connect a computer (desktop/laptop) to one of the "wired' ports on the router.
Connect to the built-in web-server "inside" the router.
Run the "Wireless Networking Setup Wizard", to configure the wireless capabilities of the router; assign an SSID, and assign a password for the wireless network.
Dec 28, 2009 | Computers & Internet
How to change or check the nat settings on my linksys wireless-g broadband router
To check or change the router settings, you need to login to the web interface of the device using a web browser.
The default ip address is 192.168.1.1
The most common default user id is admin and the password is blank (none assigned).
Jul 18, 2009 | Linksys Wireless-G Broadband Router
I need to creat ip from my router for my friend that will have starting time and ending time.
Navigate in your browser to the control panel of your router ( typically http://192.168.1.1 ). Leave user blank and enter your password. Then navigate to tab Access Restrictions, create a policy with the times you want, click the Edit List of PCs button to assign policy to your friends computer, then click Save Settings button.
Jan 22, 2009 | Linksys Wireless-G Broadband Router
3Com (3CRPAG175) 802.11a, 802.11g/b Wireless Adapter Logo
78 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
