Question about Shinko S2145 High Speed 6" Digital Photo Printer, 6.8 Sec 4 x 6 Print Speed, USB 2.0 Connection
Shinko s2145 incorrect ribbon 2
What does the 2 mean when a shinko s2145 says incorrect ribbon2?
What tire replaces Dunlop K555?
Hi Jason, Shinko SR734R Rear Cruiser Tire
for more information about your question please visit the website below. Good luck and have a nice day.
http://www.motorcycle-superstore.com/18729/i/shinko-sr734r-rear-cruiser-tire
Nov 05, 2015 | Motorcycles
Can I network Shinco printer s2145
with one of these
http://www.dx.com/p/network-usb-2-0-lpr-printer-server-10-100mbps-ethernet-31570?tc=AUD&gclid=CP-1weaL9MICFRUIvAodEpYAZA#.VKXrgHs_zLk
Only thing is I did not find windows 8 drivers for this printer as standard so you may run into trouble with computers running windows 8 as each computer has to have the exact operating system printer driver designed for its exact operating system .
Unless you can find windows 8 drivers somewhere on the internet
Jan 01, 2015 | Office Equipment & Supplies
About Race Bike Riders
I guess maybe it is probably to retain the matching look of the tires. If for instance your sponsors were the Shinko company, they would certainly want their front and rear Shinko Tires appear uniform to also add onto the bike's aesthetic value
Mar 21, 2013 | Motorcycles
My datamax thermal is not heating up
These printers do not "heat up" as such. Possible causes are:
1. Incorrect ribbon type for fitted ribbon spools. Look at back plate and see which way arrows are pointing. If arrows point Anti-clockwise, then you require inside wound ribbon (i.e. standard datamax) If pointing clockwise then you require outside wound (i.e. Zebra type ribbon). Check ribbons by touching sticky side of label to ribbon (it will transfer ink to label on print side).
2. Could also be faulty printhead, Logic board or Power supply. These will require an engineer to check properly.
Jul 05, 2011 | Datamax M-Class Thermal Printer
I have a Fargo DTC550 Printer and laminator which i just got yesterday and after setting it up by carefully following every instruction in the manual it keeps displaying "Wrong Ribbon Installed" "An...
in windows 7 go to start>Devices and Printers> Right click on DTC550 and go to printing preferences then click the Device Options tab and click auto ribbon select
Oct 20, 2010 | Office Equipment & Supplies
My zebra card p330 dont recognize the colour ribbon, only detect the mono riboon
Try to send the command !SA from the driver. And run the Ribbon calibration
Sep 04, 2010 | Zebra P330i Thermal Card Printer
Pl. send the prinetr driver of Shinko CHC 445-2 printer which is compatible with Windows Xp. Thanks. (D.S. Tomar)
This is available for you to access and download from this URL, you may need to register.
http://list.driverguide.com/list/company1689/index.html
Please do inform me if this resolve your issue,
Thank you for your patience
Mar 12, 2010 | Shinco Televison & Video
Problem with Konica Minolta Di1610
Incorrect T/C type means that toner cartridge have not good contact with toner chip, is good to clean this chip, or contact inside magine is not good. Change toner cartridge and if that problem remain, its needed replace contact unit on machine
Sep 21, 2007 | Konica Minolta Di1610 Copier
Shinko S2145 High Speed 6" Digital Photo Printer, 6.8 Sec 4 x 6 Print Speed, USB 2.0 Connection Logo
489 people viewed this question
Top Shinko Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Shinko Office Equipment and Supply Expert? Answer questions, earn points and help others
