Question about BMW 1995 740 i
Overheats.car runs rough,fuel smell in antifreeze and oil.1995 bmw 740 i
Put kw block seal in,no help.fuel regulator?
Your thermostat might be faulty,,thus playing up with your cooling and heating system,,replace thermostat
Posted on Dec 04, 2012
Chevy lumina overheat
engines overheat with no thermostats. Very simply put the water circulation is too fast for the heat to transfer to the air. Water pumps fail from bad bearings and pump seal but for no other reason. So back to basics Refit with a new thermostat put in properly. Have a flow test done on the radiator for blocked cores. have a coolant system pressure test done for leaks and cap failure.. have a compression test done to check for head gasket or cracks.. Check for correct ignition timing and air/ fuel ratio mixture. Run fault codes . when refilling with coolant ensure that all air locks are removed
Dec 29, 2013 | Cars & Trucks
Water not staying in radiator no sign of leaks in my 2000 bmw
does the car seem to run roughly? sounds like a possible head gasket or a cracked cylinder. is there an unusual amount of moisture coming out of the exhaust pipe, would smell like antifreeze gaseous sweet smell. a crack will fill either the top of a given cylinder but only when the engine is not running. head gasket will dump water into the oil giving it a milky look also will be prone to overheating
Oct 20, 2012 | 2000 BMW 323i
1995 mazda millenia s 2.3 it overheats it has new water pump and timing belt and when i put antifreeze in the tank it wont go into the engine please help
Have you tried filling at the motor, header tank or radiator. You may need a new cap or you could have grass or something block the airflow at the front of the radiator, possible head gasket, does it run rough when first started then clear up?
Jun 26, 2012 | 1995 Mazda Millenia
Have a 2003 jeep liberty, 3.7L 6 cyl, had a misfire on spark plug #2 , replaced it, no codes appear, says passed. But still seem to sense a misfire, runs like there is a misfire, and when first starting...
Hello, sounds like you should get a compression test for the bank with number 2 cylinder. I am going by your statement about the Antifreeze smell. You could also do a fuel quality check and replace the fuel filter while doing this. Put the fuel in a glass jar and wait a day if necessary to see if the fuel separates. Bad fuel would also account for a rough idle and the smell.
The newer fuels we have today can separate and also attract water from the atmosphere. The Evap may have been a sign that the system was open to the atmosphere. Before doing major motor work, you may want to "smoke test" the Evap system. This requires a special machine some shops have.
I am curious to the condition of the old number 2 plug and if it looked corroded from the antifreeze. An alternative would be to remove the sparkplugs and crank the engine when it is cold from sitting overnight. Then observe if antifreeze or water was blown out the sparkplug holes.
I hope my solution is very helpful to you.
Mar 26, 2011 | 2003 Jeep Liberty
Lots of smoke coming from the exhaust
What color is the smoke? White, Gray, Black. Big differences between the 3. Let me know and I can try to help you. Thanks.
Feb 25, 2011 | Nissan Minivan Cars & Trucks
Low oil pressure readout and engine runs rough it is a 740 IL 1995 I dont know what models below are 740 IL
Hi it could just be the oil pressure switch get that checked first.
Is the car putting out any smoke? if so then it may be the head gasket starting to go, leaking oil into the pots. give it a hard rev and check, also the valve stem oil seals could be going. this would cause the engine to run rough if the spark plugs are getting oil on them. remove each plug and check for deposits of oil or very dark carbon
there is a few possibilities but your better checking these first.
if no joy get back to me
Regards
Dan
Feb 17, 2010 | BMW M5 Cars & Trucks
Driving down road and it quit lifted hood and rad cap was on the battery must of blown off antifreeze under hood now it runs rough and no power
May of blown head gasket.Check for light colored smoke that smells sweet out of the exhaust.Also check oil (dipstick,under oil filler cap or by draining oil) for antifreeze deposits mixed in w/oil
Sep 15, 2009 | 1995 GMC Jimmy
95 bmw 740 il
Probably not the filter, the Fuel Pump is located under the Back Seat.
Sep 08, 2009 | 2001 BMW 325
Running
Have you checked your oil to see if there is antifreeze/water in the oil?  With the fact that it is running rough makes me think that you might have a head gasket leak and your coolant is running into your oil (and this would explain why you can't find a leak).  I would start with checking the oil to see if water is beading up in it.  Hope this helps and let me know if you have other questions.  Thanks for an honest rating and for using FixYa.
May 21, 2009 | 1998 Buick Century
BMW 1995 740 i Logo
Top BMW Heating & Cooling Experts
cwradio73
richie46
Gil Shultz
Are you a BMW Heating and Cooling Expert? Answer questions, earn points and help others
