Question about Emerson MW8107WA Microwave Oven
How do i change lite bulb in my microwave
I have an emersonmw8107wa 1.1 and the lite has gone out
i cannot locate the lite compartment and need to change bulb
can you help me please
  • Anonymous Apr 14, 2009
    how to chage light bulb on my sharp microwave oven models R-330F
  • Emerson Master
  • 9,086 Answers
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Jan 12, 2009
1.Remove two back screws with phillips.
2.Then one side screw with phillips.
3.Use pliers to remove other two bottom rear screws. (i used my leatherman and it worked like a champ.)
4. Bulb is located behind black cover on right side behing number pad, then just twist off.
5. Just reverse directions to replace.
Posted on Oct 17, 2009
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
The light has gone out on my oven.. Is it the bulb?.. Or is there a battery compartment?
The bulb needs to be replaced, or if the bulb is good, then the circuit needs to be checked.
Jun 03, 2015 | Microwave Ovens
Light bulb has gone, can't see where it is located or how to change the bulb
Do as follows. Do not connect the microwave oven to mains while doing the following activities. Even the accidental switching ON will harm you from the microwaves. Open the top cover by unscrewing side screws & the screws at the back. Lift the top cover by tilting upwards from rear end. Remove the wave guide of magnetron & there you will find the bulb. Wave guide is rectangular small ducting (pipe enclosure) to guide the microwaves from the magnetron.
Sep 17, 2011 | Microwave Ovens
Light has burnt out
R-820BK/BW Microwave Operation Manual
Due to the risks of death or serious injury the above owners manual suggests that a burnt out light demands a service call by a qualified technician.
That said, if you have a basic level of competence and read the safety hazards involved with microwaves (see a good resource on microwave safety and repair at:
http://www.kellerstudio.de/repairfaq/sam/micfaq.htm
Often, the microwave is divided into two main compartments, the electronics compartment(usually immediately behind the front control panel), and the high voltage compartment(usually behind the electronics compartment). The light bulb is likely in one of these two primary compartments. If it is in the high voltage compartment with the HV Capacitor and magnetron, changing the bulb becomes much more dangerous.
Please be very careful if you do decide to do this on your own... unlike most electronics microwaves can remain lethal, even when unplugged. Hope this helps.
Oct 21, 2010 | Sharp R820BK 900 Watts Convection ...
The bulb has gone on my microwave. How do I change
take the screws out of the cover take it off can now access the light-check appliance store or hardware for the bulb.
Dec 22, 2009 | LG LRMM1430 Microwave Oven
WHERE IS THE LITE BLB COMPARTMENT
You should be able to see the bulb, if not, then you have to unsrew the top and change the bulb by unswrewing it, then just buy a new one and put it on.
Jan 12, 2009 | Emerson MW8107WA Microwave Oven
Bulb gone in microwave oven compartment
Most models have a slide plat that covers the lamp. Other require you to remove approximately four screws and slide the entire panel out. Your owners manual will sometimes tell you how to replace a lamp for a microwave cabinet.
Jan 06, 2009 | Sanyo Microwave Ovens
How to change a light bulb in a emerson mircowave model mw8115ss
If this is freestanding m/w:
1. disconnect from outlet
2. take the cover off.
3. light bulb located on right upper corner.
Nov 30, 2008 | Emerson Black Microwave Oven
Sharp Microwave R-206 800W
open the housing, look where the bulb is located, unscrew the holder of the bulb and if the b.ulb is screwed at the holder, replace it. if the bulb is attached to the holder then replace the whole bulb assembly. i hope i was able to answer your problem
Feb 18, 2008 | Microwave Ovens
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Emerson MW8107WA Microwave Oven Logo
300 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
