Question about Delta Woodworking Delta Rockwell 14 Inch Wood/metal Band Saw Manual
I HAVE A DELTA BAND SAW SERIAL# 102-3033 AND NEED PARTS
NEEDE BLADE BEARINGS AND LOWER 8 INCH CAST IRON PULLEY BY BROWNING WITH 3/4 INCH SHAFT
    Sergeant:
  • 468 Answers
Find time to check www.bandsawparts.com . or give them a call perhaps.
Posted on Dec 05, 2012
efs_perpends
  • 1996 Answers
SOURCE: Rubber on wheels is shot. Where can I get new rubber?
Here are a few links to new tires for your bandsaw, available here and here and here. If you google "bandsaw tires", you'll find they are pretty widely available and may be able to come up with a better price...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 15, 2009
efs_perpends
  • 1996 Answers
SOURCE: manual or info on a rockwell 28380 14" band saw
I can't find one for the exact model number you have, but there are a lot of manuals for the same era bandsaws available as PDF downloads at this site. Perhaps another manual for a similar machine will help answer most of your questions, in lieu of the correct one...
Have a look around there, though, at both the Delta and Rockwell listings, as I just made a quick look to find yours and there might be something there somewhere.
efs_perpends
  • 1996 Answers
SOURCE: I need a manual for the Delta band saw model number 28-207
Go to this link, Right click on the underlined PDF below the Publication Preview, and you'll be able to save target as a pdf file onto your system.
Posted on Aug 05, 2009
efs_perpends
  • 1996 Answers
SOURCE: I need a manual for an old Sears Band Saw Model #534.01120
Does it look like this? Unfortunately, they don't have a manual that I could find. But you might like to post your request in the forums there, as they get some traffic from aficionados of old tools with wile and know how.
It might help you also to google Dunlap & PowerKing for the manual.
As far as tuning it up goes...
Check each of the wheels' "bearings" to begin with, to ensure they are running smoothly and as true as possible, without end play or wobble. Then use straightedges and flat jointed boards to line up the three pulleys as much in a single flat plane as possible, by shifting shims, etc. (It may behoove you to remove the table out of the picture to begin with, if possible, so you can get the wheels lined up well with one another, then replace the table once the blade will track.)
The adjustments on a three wheel system can be a little more delicate and temperamental than on a standard 14" bandsaw, so be moderate in your tracking adjustments, and crank the wheels by hand to begin with as you work the tension up on the blade, checking constantly to keep the blade running as close to the center of all three tires as possible. Don't worry about the blade guides at all until you get the blade running on the wheels well. Then move the backed off guide blocks and backing bearings into place. They are meant, after all, to keep the blade from deflecting, not to force it into position.
That's my quick advice for how to tune it up.
Good luck. It looks like a beaut!
Posted on Sep 03, 2009
  • 37 Answers
SOURCE: I have a 14
From information over at http://www.deltaportercable.com/ServiceAndSupport/OwnersManuals.aspx
"You can locate your product's model number on the warning/caution label on the product itself."
It's often a two letter code followed by a dash then a 3 or 4 digit number. some examples are PM-1886 or BS-3A or 28-701. Hope that helps!
Posted on Jul 31, 2010
Wood chipper problems
Unplug the band saw. Open it, clean everything up , from inside of the motor, switches , wheels to guides. It could be also a motor problem. Good luck!
Aug 17, 2014 | Delta 28-061 56-1/8 Inch x 3/16 Inch x 10...
The blade on my delta 28-276 keeps riding off the bottom tire
The blade on a band saw stays on the wheels because they are aligned in a way to keep it there. Several things can be wrong to make the alignment off enough that the blade won't stay on. Check the condition of the tire and that the wheel isn't bent. Then check that the bearings and lower drive shaft are not damaged. Another remote possibility is a bent frame that throws the alignment out of wack.
Oct 08, 2012 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
I have an older 14 inch Delta, The blade runs on the outside of the pully's, I have tried adjusting the screw to the point the pulley rubs against the back of the machine, Replaced the tires also.
I had the same problem with a band saw I own (not a Delta) I removed the pulley and used a washer of the appropriat size to act as a spacer. It moved the pulley out for enough to stop the rubbing - not sure if this will work in your case.
Nov 23, 2010 | Delta Rockwelldelta 14" Hinged Wood Band...
My fence is square to the table. How do I set the blade so it is square to the table? There is a 1\8" difference in the distance between the front and back of the blade in relation to the groove the miter...
I'm betting that the table isn't square to the blade. My Cabinet Makers Table Saw does the same thing - the top plate (the big heavy cast iron plate that weighs about 50 pounds) sits on top of the sheet metal box that houses the motor and motor lift. This cast iron plate is held onto the sheet metal box by 3 screws (usually).
Loosen the 3 screws and the cast iron plate can move around on top of the sheet metal box (the holes for the screws are large enough to allow 1/8 inch movement). Looking down from the top, you can rotate the cast iron plate clockwise and it will move the front of the blade closer to the fence and the back of the blade away from the fence. Counter-clockwise does the opposite.
For the best adjustment, use a dial indicator mounted to something that slides in the track of the table top. Position the dial indicator agains the blade and slide it back and forth in the track of the table top. This will accurately set the table top to the blad (so they are parallel within 0.0005 inches).
Then check the accuracy of your fence (sounds like this is good). Don't forget to check the alignment of your riving knife/guard & splitter to the blade (if it's off you can't feed wood because it will hit the splitter).
Oct 07, 2010 | Delta Machinery 3 HP Left Tilt Unisaw with...
Will Delta Belt fit Mastercraft Band Saw
If you still have the old belt, take it to a well equipped hardware or auto parts store for a replacement. If the previous belt is missing, you will need to measure the pulley 'V' width at the top of the 'V', the center to center measurement of the two shafts, and the outer diameters of the two pulleys. Hope this helps!
Apr 15, 2010 | Delta BS100 Shopmaster 9 Inch Bench Top...
I have a 14" delta bandsaw ser. no. 6-5560 It is a 2 speed it has a 6 sided guide post and a 4 part cast iron base that comes apart with thumb screws I am looking for the model number
Dec 16, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
8 inch delta band saw that cant keep the band in place in use
The rubber bands on the metal wheels are called tires, and if they are cracked, they may very well be crowned and causing the problem with the band coming off.
To test, remove the back guide (as opposed to the side guides) on the top and bottom guide sets (above and below the table.). Put a blade on, and see if it will stay on. If it doesn't, replace the tires. If it does, reinstall the back guides and make sure they do not touch the back of the blade when the saw is running. There should by about 1/32" between the guide and the blade.
Dec 11, 2009 | Saws
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
Band saw blades keep coming off the reels and
if it is a Delta (as it is listed) this site should help.
-->click here<--
please take the time to give this solution a fixya rating.
Any questions, just ask.
clarkco
Mar 31, 2009 | Delta 28 168 Bench Band Saw Blade 56 1/8...
Wood like to clean & update my rockwell model 14 band saw need a download of this saw
try there web sight, if I'm not mistaken, Delta bought out rockwell and they should be able to help. I had an old rockwell table saw and the man shaft that the blade attached to was missing.I contacted delta with the model number of the saw and they faxed me a blue print of the shaft and we machined a new one and the saw still works great.
Jan 18, 2009 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Delta Woodworking Delta Rockwell 14 Inch Wood/metal Band Saw Manual Logo
105 people viewed this question
Top Delta Woodworking Saws Experts
Paul Sikkema
Paul Sikkema
Terry Weaver
Terry Weaver
Are you a Delta Woodworking Saw Expert? Answer questions, earn points and help others
