Question about Parsons QuickVerse 2005 Expanded Edition (11149)
I have a problem registering Quickverse 6.0
I provide all my information for registering my product it could not be transmitted.
Quickverse deluxe version
First, read the System Requirements of your software. i think Quickverse Deluxe 2009 is compatible with Windows XP/Vista. if need any more guidance on technical specification follow Intuit Tech Support .
Apr 22, 2014 | Intuit Computers & Internet
Code activation
WinZip is a file compression utility that allows users to "zip" files into archives that have significantly smaller file sizes than the original files.
If you purchase WinZip directly from the WinZip website, a registration code is sent to you via email that allows the software to be used as soon as it is installed.
If you purchased the program from a third-party retailer, however, you must use an activation code to activate and register the software. Launch the WinZip program.
A screen will appear, reminding you to register your product and giving you the option to enter your name and registration information.
Enter your name where prompted.
Enter the activation code that came with your WinZip installation disc or in the activation information email you received when you purchased the product.
Click the "Register" button.
Enter all required information when the WinZip Activation Information screen appears.
This screen collects the information that WinZip Computing needs to properly register and activate your software.
Click the "OK" button to submit your information.
The WinZip software will transmit your information to WinZip Computing's activation server, registering your software with the company and receiving a registration number that it will use to activate your copy of WinZip.
Check the email address you entered when activating your copy of WinZip.
A copy of the registration information will be sent to you, including the registration number that was used to activate your software.
If you need to reinstall WinZip in the future, use the registration number instead of the activation code.
or
Its illegal for anyone to provide serial keys for programs that have retail values set on them there are freeware alternatives on the internet.
ZipGenius is a FREEWARE product
http://www.zipgenius.com/index.php?id=33
ZipGenius can handle more than .zip or .rar file
20 compressed archive types.
http://securezip-express-for-windows.soft32.com/
Free zip
http://www.all-freeware.com/details/154438/1-click-unzip-.html
http://en.softonic.com/s/winzip-8-freeware
Sep 26, 2013 | WinZip 12.0 - Windows for PC
Registration code
or use freeware
Free zip
I cannot get my software to install and function
NOTE: QuickVerse Smart Tags will only work with Microsoft products that support the technology. (Your version of Microsoft Word must be 2002 or newer.)
during the installation of QuickVerse. However, if a Microsoft document was open during installation, you may have to walk through the following steps manually.
Phase 1 - Manually register the QV13SmartTags.dll file
  1. Download and extract this ZIP file to your desktop
  2. Windows XP: Right-Click and select Open
    Windows Vista: Right-Click and select Run as Administrator
Phase 2A - Turn ON Smart Tags in Microsoft Word 2007
  1. Start Microsoft Office Word 2007.
  2. Click the Microsoft Office Button, and then click Word Options.
  3. Click the Proofing tab, and then click AutoCorrect Options.
  4. Click the Smart Tags tab.
  5. Verify that the Label text with smart tags check box is selected and that your smart tag is both listed and selected in the Recognizers list.
Phase 2B - Turn ON Smart Tags in Microsoft Word 2002 or 2003
  1. Start Microsoft Office Word 2002 or Microsoft Office Word 2003.
  2. On the Tools menu, click AutoCorrect Options.
  3. Click the Smart Tags tab.
  4. Verify that the Label text with smart tags check box is selected and that your smart tag is both listed and selected in the Recognizers list.
click on this link directly for more troubleshooting
http://www.quickverse.com/shopfiles/Faq.asp?ID=41221
This will help. Thanks please keep updated. please do rate the solution positively .thank you for using fixya.
Nov 28, 2009 | Findex QuickVerse Bible Suite 2008
Want to install Quick verse 7 on Vista
the Quick verse 7 was made only for 95 98 2000 and XP but you can try this method on how to install the QV 7 on winXP sp3
"Install QuickVerse Essentials version 7 on WinXP w/sp3
Place the QuickVerse version 7 Essentials CD into optical drive & close tray. This begins the auto run / install process. (Please do not remove CD until right at the end!)
Installation menus appear. Accept the defaults and choose “Typical Installation” (85Mb)
Message box appears at the end of the installation: “QuickVerse installation has encountered a problem and needs to close” Choose “Don’t Send” The installation program exits.
Navigate to: Start Button / All Programs / Parsons / QuickVerse 7 / (from drop down list) find “QuickVerse 7.0” and right click on it. Select “Send To Desktop”
Click on the new QuickVerse 7.0 desktop icon to run the program.
Dialog Box appears, “The librarian datafile library.mdb not found etc…” Select “New” / "Open Book" dialog box appears click on “Close”
Now with QuickVerse 7.0 running go to File / Add Books. “Registration Guide – Introduction” box appears. Choose “Next” The path to the new collection to register should identify the optical drive (with the QuickVerse CD already inserted) Choose “Next”, “Next” and “Finish” ("Registering STEP Books" msg box appears)
Customize Option: select “No” (default) then “OK”
Go to File / Library management. “Library Management – Maintenance” box appears
The Left Hand (LH) pane shows:
Default Drive
Highlight QV Essentials in the LH pane. The RH pane shows all the books present on the CD. I chose to install only the NRSV w/Apocrypha book. Drag and drop this book to the LH pane i.e. Default Drive.
“Transferring Book Files” msg box appears whilst the book is being copied from the CD to the hd.
Close the dialog, exit the program, remove the CD and you’re away…"
hope this helps./
Nov 04, 2008 | Computers & Internet
Quick verse 7
Default Drive
Jul 11, 2008 | Parsons QuickVerse 7 Essentials (fe11044)...
QV ver6 (Win 95/98/NT) compatible with Vista?
If you right click on the shortcut and go to the Compatibility tab you can check the Run this program as an Administrator option. This worked for me.
Jun 23, 2008 | Parsons QuickVerse 2005 Expanded Edition...
Quickverse 5.0
I had the same problem [Quickverse 7 on a Vista OS] but my fix was a little longer. On my right click on the icon I didn't get a Compaibility tab. I went down to "properties" then in properties the tab for compatibility shows up. Click on "Run this program as an administrator." This worked fine for me. And this site rocks with so much great information - thanks everyone for your input and for sharing!
Nov 12, 2007 | Parsons QuickVerse 2005 Expanded Edition...
Cannot install Quickverse 7 version from year 2000 because of Microsoft DAO.
Hi, I had the same problem and fixed it, (loaded my quick verse bible software by loading the software in SAFE-MODE. This mode stops the dao that is running. (probably micorsoft office at start up). This solution worked perfect....God bless
Sep 06, 2006 | Parsons QuickVerse 7 Essentials (fe11044)...
Computers & Internet Logo
53 people viewed this question
Top Parsons Computers & Internet Experts
Neil
Level 1 Expert
tdk1988
Are you a Parsons Computer and Internet Expert? Answer questions, earn points and help others
