SOURCE: crankshaft pulley timing marks
the red mark is where the timing is supposed to be after u have bypassed the electronic advance.the first white line on the left is tdc.
thanks for useing fixya
SOURCE: need to find out tdc for the camshaft gear
Align timing pointer on transmission bellhousing with white T.D.C. mark on flexplate or flywheel, make sure up marks on each camshaft pulley at top and align marks on each pulley aligned with the edges of the cyl. head.
SOURCE: camshaft timing mark crankshaft timing mark
Belt covers need to be on. Timing mark on crankshaft (while on compression stroke) should line up with TDC mark on cover. then Camshaft mark, needs to line up by looking through access hole of cover, and align mark on cam sprocket with pointer on inside of belt cover.
SOURCE: need to set marks on timing gears and crankshaft
Click on the following free, direct Link. It has all the Timing Belt Diagrams you will need, complete with Instructional and Directional Diagrams to set your Timing.
Let me know if this helped or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2001/make/daewoo/model/leganza/2001_daewoo_leganza_timing_belt_diagram_marks.htm
SOURCE: where is the timing mark on the crankshaft on a
You have to pull the flywheel off of the crankshaft to see the woodruff key. The key should point up towards the camshaft. there are two marks on the plastic camshaft gear that also must align with the two marks on the housing.
