Question about Invoice2go
I need to reinstall my invoice 2go on another computer and I am unable to do this without my receipt and or product number How do I proceed without buying another program?
I am unable to email and invoice through quickbooks
If unable to send your mail from QuickBooks to Outlooks so try for this intuit solution step by step because it is most common issue face by users Error QuickBooks is unable to send your email to Outlook and if need any guidance while configuring then follow Intuit Tech Support for more help.
Jan 05, 2014 | Intuit QuickBooks Pro 2008: Windows
Spin scrub will not spin
If its belt driven, the belt had dislodged or broken off completely. If gear driven, the gear teeth had broken, so the gears needs replacement. If you purchased less than a year ago, find the store receipt or look up the purchase history on your bank/ credit card invoice archive and if it shows the product name and model number, then that's sufficient proof of purchase. Some retail stores like Walmart can printout a duplicate receipt if you know the exact date, time of purchase, and which register processed the transaction. When you have proof of purchase receipt, contact the manufacturer for address to return product to file 1-year warranty claim.
Nov 19, 2013 | FH50150 Carpet Cleaner, Power Scrub Deluxe
Product number locations on hp pavvilion dv6000 laptop
Each set or peace of laptop has unique number so it is not possible without your receipt receiving.
Aug 14, 2012 | HP Pavilion Computers & Internet
Friends have purchased a used Restaurant Pro Express system and someone deleted everything and reinstalled the software so I am trying to get it set up for them to use. There are 3 computers, 4 Epson...
The exiting user(cashier) can be corrected by going to OPTIONS, SETUP, SETUP SCREEN, INVOICE SETTINGS tab. Uncheck Prompt for Cashier ID. Then UPDATE.
Your other problems will require someone with knowledge of RPE version 11 because there is no tutorial or even a good user manual. If you need to register software, be fore warned. You will need previous company name, address, phone number and a contact name to get a reset. The software will never be yours unless you officially transfer it and that is costly. Your almost better off buying new. And good luck with printer drivers. Certain versions require the exact driver to be totally functional. You have your work cut out for you. I can help, but not for free.
B Mattern
sysadmin@ccybernet.com
Please return and give me a favorable rating if this helps or is of value to you.
May 12, 2011 | Pc America Restaurant Pro Express
I have a Xantrex 2400-12 two years old, installed off grid in a vacation home in Mexico, a service call is not an option. The inverter quit working, flashes "888" and shuts off. I have a trace...
First off I am not in this for the money. If your not satisfied with the information below simply reject the solution so that you can hear from other experts.
The 888 flashing is telling you that the inverter has lost DC power momentarily. This can be from broken strands in the battery cables or an internal wiring problem in the inverter. Check the battery cables for corrosion. Remove the terminals check for battery post corrosion and visually inspect each bable to terminal connection from the battery connector to the inverter DC Power connections.
Here is something to keep in mind. A DC power cable only needs one tiny strand of wire to indicate voltage on a meter. However, if there is any load on the AC side that tiny strand of wire that is giving you the proper DC reading may in fact drop well below 10.5 V DC and simply cause the unit to automatically shut off even with no load.
Explain your situation to Xantrex using the link below and they may be able to help you due to the fact that you do not have a local "post warranty service provider" in Mexico:
If your product requires troubleshooting or warranty service, contact your
dealer.
If you are unable to contact your dealer, or the dealer is unable to provide
service, contact Xantrex directly at:
Direct returns may be performed according to the Xantrex Return Material
Authorization Policy described in your product manual. For some products,
Xantrex maintains a network of regional Authorized Service Centers. Call
Xantrex or check our website to see if your product can be repaired at one of
these facilities.
What proof of purchase is required? In any warranty claim, dated proof of
purchase must accompany the product and the product must not have been
disassembled or modified without prior written authorization by Xantrex.
Proof of purchase may be in any one of the following forms:
• The dated purchase receipt from the original purchase of the product at
point of sale to the end user, or
• The dated dealer invoice or purchase receipt showing original equipment
manufacturer (OEM) status, or
• The dated invoice or purchase receipt showing the product exchanged
under warranty
Telephone: 1 360-925-5097
Fax: 1 360-925-5143
Web: www.xantrex.com/support
customerservice@xantrex.com
The owner's guide is here:
http://www.xantrex.com/documents/Power-Inverters/Xantrex-Inverters-Digital/XPower_200-400-800_Digital(975-0176-01-01_Rev-B).pdf
Thanks for choosing FixYa,
Kelly
Jan 16, 2011 | Xantrex Technology Trace Series Inverter /...
Can't complete registration of my product without CD Key.
First check your Amazon receipt. They usually put the cd activation key on your invoice when you purchase a digital download. If it is not on the invoice then check your e-mail to see if they mailed it to you. If they did not then contact customer support and give them your order info. They should give you a key at this time. Hope this helps.
Jun 03, 2009 | RTO Chief Architect Better Homes and...
Unable to print receipts after reinstalling software
Usually when you copy from one system to another, you also need to copy credit.pcc and config.pcc. The config holds various settings for hardware and such, and the credit holds the account information and indexing for multiple merchant accounts. If you are using a newer version of pcc, I would also copy over the mds.pcc, as this holds info for cashiers and more importantly, passwords.
Feb 05, 2009 | VeriFone PCCharge Pro Full Version for PC
I want my laptop invoice no.,its serial no is ;cnd7280f9x
Invoice number ? From when you purchased it ? The business where you bought it from should have it, or if you had it shipped to you the shipping company ( UPS, USPS ) may have it. How long ago was it purchased ? If you bought it online, or actually where ever you bought it from may have the records, it's best to keep ALL of your purchasing receipts paperwork etc.so you have it. When done online would have been best to print and/or at least save the transaction. Did you use plastic ( credit/debit card ) ? Should be some numbers on your statement that may serve as an invoice number.
Nov 18, 2008 | HP Computers & Internet
How to reinstall Office
According to Microsofts website you are required to contact your manufacturer of the computer.
See Link for manufacturer's contact numbers:
http://support.microsoft.com/?LN=en-us&scid=gp%3B%5Bln%5D%3Boemphone&x=7&y=10
Other than that you are SOL... without going to your box store and purchasing the full version
Aug 15, 2008 | Microsoft Office Professional 2007 Full...
An extra cut about 1 inch after the invoice is printed
Go into printer friendly setup, then select the receipt printer and choose the option 'Cut at this station'. Make sure it is unchecked. Your problem solved ;)
Aug 10, 2008 | Epson TM T88 Thermal Printer
Computers & Internet Logo
Top Invoice2go Computers & Internet Experts
David Payne
David Payne
Are you an Invoice2go Computer and Internet Expert? Answer questions, earn points and help others
