Question about Sharp El-1801v Printing Calculator
Sharp EL-1081V error on display
Cannot perform any functions. Display keeps showing 0 and then E. The tape doesn't display the correct numbers that are being keyed in.
  • 359 Answers
SOURCE: Sharp EL-2630GII Error on display
Unable to locate a manual for this specific model, but if you go to http://www.sharp.ca/manuals/, you will find one for an EL2630-P, PII, and PIII. The functions are very similar and should give you the detail that you need. Generally there will be a reset button (likely on the bottom of the machine), which often must be pushed in using a ballpoint pen or similar implement, if no other routine clear or reset procedure (such as turning off and back on) is working.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Posted on Jun 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp 1100 w Microwave Model R-420BK - Clock display not working correctly
This is a problem with the control panel assembly, and we repair these for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 18, 2008
  • 990 Answers
SOURCE: Sharp H4 Error message
Hello sir; The code need to reset;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 then press start.
3, if machine work, please don't forget to give me a good rating.
THANK YOU !!!
Posted on Feb 12, 2009
  • 8016 Answers
SOURCE: Nothing happens when I press a number??
There is no lock button. Calculator may be configured to be in computational mode you are not familiar with: It may be set to do base calculation on base 5, hence the p (pental). Press the reset button on the back, and the default configuraion will be restored.
You should give some time to learn the different mode of calculations.
Hope it helps.
Posted on Sep 20, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: error code on display, L1 or 1L flashing. What is
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Posted on Jul 16, 2010
How do i use the percentage function?
If you want to find 25% of 500
ENTER....
500 X 25 [2ndF] % will display 125.
If you want to know what % a number is of another number like for instance...
What percentage is 120 of 400?
ENTER...
120 [DIV] 400 [2ndF] % will display 30.
If you want to increase a number by some percentage like
Increase 500 by 25%
ENTER...
500 + 25 [2ndF] % will display 625.
If you want to decrease a number by a percentage like
Decrease 400 by 30%
ENTER...
400 - 30 [2ndF] % will Display 280.
NOTE [2ndF] is the 2ndF button. Do not enter the brackets [ and ].
NOTE [DIV] is the divide button. The text editor would not let me enter the divide symbol
Jul 18, 2014 | Sharp El-w535x Writeview Scientific...
Tip
Sharp ELW516: Changing the default display to decimal
<span><b>Getting Decimal Answers by Disabling WriteView<img src="elw516.gif" /> on the Sharp EL-W516 Calculator<br /><br /></b>The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors. <br /><br />At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers. <br />If you prefer to always get decimal results you need to <b>disable</b> <b>the WriteView display mode</b>. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.<br /><b>Disabling WriteView<br /></b><br />Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.<br /><br />There are now two options: 0: W-VIEW, and 1: LINE<br /><br />Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.<br /><br />To return to the WriteView display, go through the steps above but press 0 for W-VIEW.<br /><br /><b>NOTE</b>: It is not possible to have decimals as the default answer form when in WriteView mode. <br /></span>
on Mar 04, 2011 | Sharp ELW516 Scientific Calculator
Why does the lcd display goes bad
Faulty electronics. It may be time to look for another calculator. Try pressing the 8 key enough times to fill the LCD 88888888888. If
Apr 03, 2012 | Sharp EL-512H Calculator
IR 2016i Black and White Copier i got this proble .Turn the main power .switch (on the main unit's side) OFF & OnNagain . error code no is :E000007-0000
E007 0000 Fixing film sensor failure
Main Cause/Symptom : The fixing film sensor is faulty
Countermeasure :
- Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Nov 07, 2011 | Canon iR 2016i Black and White Copier
I need to increase the decimal places displayed on my sharp el 738 calculator. Please help......
From the manual PDF http://www.yorku.ca/ntahani/ADMS3530/EL738_OM.pdf
(page 8 and 9)
decimal places:
set up - 0 - 0 - (tab) displays DIG(0-9) select a number from 0 to 9 decimal places
significant digit:
setup - 0 - 0 - (SCI) displays SIG(0-9) again select a number from 0 to 9 to set...0 sets a 10 digit display
the floating point FLO_A and FLO_B is a nice little chart so i'd advise downloading the PDF if you need to set those :)
Sep 21, 2011 | Computers & Internet
I want to set the decimal place without using the decimal key--example: hit the 1234 keys and the shows $12.34
You can select the A (K . A) and then the # of decimal places (F 6 3 2 1 0) you want. So if you want to enter 1234 & it calculates 12.34, this will work.
Jul 22, 2011 | Sharp EL-2630P Calculator
I have a problem with my Sharp EL-531WH Scientific Calculator. It rounds off the answer. In my Chemistry class, we need exact answers. For example, an answer of 0.234 must be the answer if that's the...
Press the [SET UP] key, followed by the 0 key to bring up the display menu. You can select "FIX" followed by the number of digits to the right of the decimal point, or press cursor-down and select one of the NORM modes. Press [ON/C] to exit the menu.
Be aware that some numbers cannot be displayed exactly. For example, 1/3 is a 0.3 followed by an infinite number of 3s.
Jun 25, 2011 | Office Equipment & Supplies
My calculator will show fractions instead of decimals when doing division. How do I change that? There is a N1 displayed in the lower left corner also...I think that may be the problem
Getting Decimal Answers by Disabling WriteViewelw516.gif on the Sharp EL-W516 Calculator
If you prefer to always get decimal results you need to disable the WriteView display mode. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.
Disabling WriteView
NOTE: It is not possible to have decimals as the default answer form when in WriteView mode.
Feb 07, 2011 | Sharp ELW516 Scientific Calculator
EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Sep 02, 2008 | Sharp EL-1801P Calculator
Sharp El-1801v Printing Calculator Logo
85 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
