Majestic 33bdvtrn will not allow a spark when the pilot light knob is depressed.
When I depress the pilot light knob and press the igniter, there is no spark. If I do not depress the pilot light knob i can press the igniter and it will spark. Do I have a bad control valve or there a problem somewhere else?
  • Jack Dean Dec 07, 2012
    The issue suggested by melee5 was correct. The fireplace had been turned off for a long period of time and I needed to wait for the gas to begin to flow.
  • Heating & Co... Master
  • 2,602 Answers
Sounds like it is shorting out on the pilot knob
Posted on Dec 05, 2012
2 Suggested Answers
  • 48 Answers
SOURCE: Pilot light won't ignite on a Rinnai 2000 1
The trick is that it may take a long time for the flammable portion of the gas to reach the pilot light orifice where the flame lives. This happens a lot when the pilot flame has been out for some time. There won't be a clicking sound as YOU are supposed to provide the flame - it's not like a cooking stove with such conveniences, because the pilot light is only an occasional thing to light it's rare to find an ignition source built in. I'd hate to see you spend good money when all you need to apply here is time and a flame.
Posted on Sep 06, 2009
Testimonial: "thanks - much appreciated Mark"
Pilot light blew out by a fan..I turned the control off..How do I Ignite Please
First locate where to light pilot. You can do this by following thin aluminum colored tubing from control valve to inside heater.In general on top of your gas control valve is a knob. Turn indicator of this knob to pilot and depress knob. This will start gas flow to pilot at end of thin tube. Hold this knob in the depressed position and light pilot. DO NOT release knob for 30 -45 seconds. Then release knob and pilot will remain lit. Then turn knob to on position. If pilot will not stay lit you may need a new thermo coupler, which senses heat from flame to keep pilot gas flow open.
Good luck
Mar 10, 2015 | Heating & Cooling
Pilot light is lit but mAinburner will not
If it is a standing pilot, the knob that you had to depress to get pilot gas to flow has to be turned to the 'on' position from the 'pilot' position before main gas will flow.
If is a "spark to pilot" ignition the knob has no 'pilot' position on the main gas valve and the problem is elsewhere. There are many variations of ignition sequence and a little more input from what you have would be helpful.
Nov 18, 2014 | Heating & Cooling
My pilot light is out and I don't know how to light it please help
Most gas heating appliances have a knob on the gas valve marked on - off and pilot. Turn the knob to pilot this should allow the knob to be depressed which will allow gas to flow to the pilot. Some units also have a peizo ignitor which is a button that when pushed creates a spark to light the pilot this button must be push several times to light the pilot. If there is no peizo ignitor a lighter or match must be used to light the pilot. A fireplace lighter is best for this because the flame needs to be close to the pilot to light it. Have the flame source at the pilot before you depress the pilot knob to avoid a build up of gas which can be dangerous. Make sure to follow all instructions on the unit. Hope this helps
Dec 23, 2013 | Heating & Cooling
Lighting pilot light
Pilot assembly is located inside the bottom compartment, between the the two middle burners while the gas valve is located under the burner manifold. Make sure that the gas line where the unit is connected is open. You need to turn the gas valve knob to "Pilot" position and depress it (to allow the gas to flow on pilot) then light the pilot assembly using a lighter with extended nozzle ( burner igniter). Once the flame is present at the pilot assembly, wait for about 15 seconds (allowing thermopile to heat up) the gradually release the gas valve knob. If the pilot flame is stable, turn the gas valve knob to "ON" position and set the thermostat to desired temperature setting. This will ignite the burners and heat up the oil to set temperature. Just remember, do not do this if there is no oil on fry tank.
Feb 18, 2011 | Pitco Frialator 35CS Deep Fryer
We have a fairly new heater. went to turn on the pilot light and it won't ignite. what do you think is wrong? gas has been turned on before igniting
Sometimes it takes a few seconds for gas to reach the pilot. When you place the thermostat knob/gas control in the pilot position you must then depress it (push it down and hold it down). Wait a few seconds while holding it down, then press the ignitor button with your other hand while continuing to keep the thermostat knob depressed. You may have to hold the knob down and press the ignitor several times. You should see a spark at the pilot if the ignitor is working properly. Continue to hold the knob down for 30 seconds after the pilot lights, then release the knob, it will pop up & you can then rotate it to lo/med/hi and the heater will come on.,
Dec 02, 2010 | Procom (177653) Utility Heater
My Majestic DVR36RN gas-log fireplace insert will not start. No ignition when striker is depressed, no flame lit at all. Gas inlet line open, pilot switch to "pilot" as directed. Maybe...
Majestic DVR36RN: Here's what you need to do: Verify gas line is open. (You said you already have done that). Next turn the switch to pilot (you said you did that too). Make sure wall switch is on also. Now press and hold the pilot switch and hit the ignitor. Once it lights you need to continue to hold the pilot switch for roughly 1 minute. Release the knob and the flame should stay lighted. Now, turn the knob to on. You should be all set now.
Nov 09, 2010 | Heating & Cooling
After depressing the control knob to ignite the pilot comes on but after i turn the depress control loose the pilot light goes out.
The thermocouple heats from the pilot and causes a mini voltage which opens the gas valve.
If bad this will not happen.
Nov 05, 2010 | Heating & Cooling
Need to light pilot cozy brand gas wall heater
Is there a "Pilot" marking on the knob? Try moving the knob 1/2 way between on and off and depress the knob. If you are in the correct location, the knob should depress in about 3/8 of an inch. Once you find the location where you can depress the knob, there should be a red sparker button that you can snap to light the pilot. Depress the pilot knob and snap the button a few times. There may be a small viewing port at the pilot. It may be covered by a small metal shield held on by a thumb screw. You can remove the shield to view the flame. OK so now you can depress the pilot knob, snap the sparker, look for the flame while still holding down the pilot knob and count to 30. Slowly release the pilot knob and check to see if the pilot is still on. Once it stays lit, rotate the knob to the "ON" position.
Jan 04, 2010 | Cozy Heating & Cooling
Re Williams 3003622 Heater Please advise how to ignite pilot light.
You will first need to turn the control knob to pilot. Then depress the control knob button and hold it. Then press the push button piezo igniter several times until pilot lights or open pilot inspection cover and manually light pilot with match/lighter. You may need to hold the control knob for at least a minute. Then release the control knob and if the pilot stays lit then turn the control knob to on. If it does not light then repeat the process again.
Oct 27, 2009 | Williams 3003622 Ceramic Wall Mounted...
Can no light up a new Rheem 22V40FN water heater
Air in system. Make sure there is no sources of ignition and loosen the supply line at the heater and purge all air. Mske sure your source valve is open. then turn off yje heater after tightening the line. Let sit in off position for 15 minutes. Then turn therm knob to on slowly and then over to pilot, depress pilot button and hold a ffew seconds. Pilot should light. If so, hold for a few and then release and turn ti on position. Good Luck.
Jun 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
