Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Abs light is on front brakes lock up on there own and cant move. 1995 chevy k1500
Is fine sometimes but other times slows down and front brakes are engaged
    Scholar:
  • 117 Answers
Sounds like it is possible the some one added the wrong type of fluid to the master cylinder. Check the rubber gasket on the master cyl if it is swollen you have a problem.. If it is soft and swollen, then the rubber cups in the master cyl are also swollen and will need to be replaced
Posted on Nov 02, 2013
3 Suggested Answers
SOURCE: 1995 chevy pickup ignition engages but starter
your starter is slowly dying, have it rebuilt or replace it.
Posted on Jul 09, 2009
  • 108 Answers
SOURCE: chevy starter ignition
This isn't a solution but it should help. Pull the column off and see what color the wires are that go to the ignition switch. Next look under the dash and find the connector that has these wires. Start the truck, reach under the dash and pull the connector apart and see if it dies. If it doesn't then consider the ECM relay is sticking. If it dies when you pull the connector apart, then your ignition switch could be back and is shorting the constant hot to the ignition out allowing the truck to keep running. You can also try pulling the ECM relay when its running and see if it dies. If it does then switch it with another relay, like the headlights if they use the same style relay and turn the headlights on then off and see if they stay on, alone with starting the truck and running it for a period of time then shutting it off and see if it dies or not. Post a comment and let me know if either of these has an effect.
Posted on Jul 15, 2009
How do you rewhy is my brakes locking down while driving?how do i rest the abs system?
You have water in the brake system, it boils and applies the brakes.
Different size tires will set a trouble code, but not apply brakes.
Jun 23, 2014 | 1995 Jeep Grand Cherokee
I have a 2005 Equinox. The abs and tc light are on. Also there is an occaisional sound and vibration when I press on the brakes going at a slow rate of speed. The local Chevy dealer test drove the...
Have a competent mechanic scan the codes in the ABS control. A common fail point of the 2005 Equinox is the wire harness jumper for the drivers front wheel sensor. This is a foot and a half long jumper that connects the wheel sensor to the engine compartment wire harness. It is rigidly held in place by a couple of plastic stays that create a pinch flex point just beneath the lower stay where wheel turn moves the wire against this rigid point. After about 60-80k miles, the wire begins to break down in the insulator and false wheel speed readings are read as false wheel slip indications while the ABS system tries to modulate brake pressure. This modlation creates the grinding feel. After an amount of time, the ABS computer "recognizes" this as a fault and shuts ABS and traction control off since both systems use the wheel spin input, and the dash lights light.
Although this is a pretty pricey part at a dealer, a genuine Delco replacement part can be found online often at a much more reasonable price.
Nov 01, 2011 | 2005 Chevrolet Equinox
Broken brake line on 1990 chevy 4x4 pickup (K1500) broke and drained master cylinder. Front disc brakes/rear drum brakes. ABS system. Once brake line fixed what is the bleeding procedure that must be...
1990 Chevy 4.3 l engine runs rough at idle half the time-- sometimes it's OK, other days it's rough and can smell raw gas, as tho it's running rich... any ideas?
Nov 27, 2010 | 1990 Chevrolet K1500
Front brakes locked up ,brake pads are good,caliper moves when bleeder is out dont know what else to do its a 1995 1500 v6 brake light is on
check the fluid,, sounds like its low and air got into the back brakes..
could also be the master cylinder
Mar 12, 2010 | 1995 Chevrolet K1500
Anti-Locks Growling
There was a recall on the ABS system on your truck. The problem was the ABS sensor on the front wheels were getting dirty and corroded causing a faults signal to the ABS module. The fix was to inspect the ABS sensor and clean them with brake parts cleaner and re-gap the sensor to the speed ring on the hub. The ABS sensor and speed ring is on the inside of the front wheel hub, spry brake parts cleaner and re-gap the sensor to the speed ring with paper folded 5 times. I feeler gauge will work but put a paper between the sensor and gauge cause the sensor is magnetic and the gauge will stick. Look for damages to the lead wire to the abs, but i think that's all fine since you did not mentioned any abs light on. You may be even lucky with just a good spray of the brake parts cleaner. Good luck and keep me posted.
Nov 03, 2009 | 2002 Chevrolet Silverado
1998 chevy silverado brake problem
Sound's like the ABS common problem. Chevy has a recall that say's to remove and clean the front speed sensors mateing surface of rust. I would try that before I started spending money. If you can do you own front brakes you can handle this. Good luck
Aug 03, 2009 | 1998 Chevrolet K1500
My abs light stays on 1995 chevy G20 van and have to replace front brakes every 6 months but rear brakes show no wear and are atleast 3 yrs old. On slick pavement right front brake sometimes locks when...
I'd be checking the sensor (ABS) at that wheel, (right front) and adjusting rear brakes to proper clearance, as well as inspect them for proper operation with wheels off.
Jul 22, 2009 | 1995 Chevrolet G20
Something is locking in when cold out
ABS modules tend to have problems on vehicles.
Do a search for ABS module repair for a place in Russia, IA who rebuilds them. They have a troubleshooting page that you can use to help you figure out the problem, and they also repair modules to include a 5 year warranty.
Jan 26, 2009 | 1995 Chevrolet K1500
1995 LeSabre ABS light
the anti-lock brake system is part and parcel of the traction control system. the abs has a $750.00 valve located in the engine bay on the right side (as you face the car from the front) the driver's side just behind the headlight. i had a mechanic who took it upon himself to remove, dismantle and clean and reassemble the unit, all to no avail but also without expense. the cost of the part was prohibitive since Blue Book on this car is just about $700.00. it will run and brake just fine without the abs or the traction control system either.
Oct 24, 2008 | 1995 Buick LeSabre
Brakes
calipers stiff moving or slide bolts seized in the bore
Jul 12, 2008 | 1990 Chevrolet K1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
53 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
