Question about Dell Studio 15 Laptop
Will not accept disc
Goes in and ejects quickly
    Guru:
  • 571 Answers
Have you tried using different known good disc to make sure that it's not disc that's having a problem? When did the last time that you use the dvd?
Posted on Dec 05, 2012
The Wii will not read my disc
Situation:
The Wii console will not accept game discs or the discs are ejecting immediately
What To Do:
Press the eject button on the front of the console. The console will not accept any discs if there is already a disc inserted, and it is common to forget that a disc was already inserted.
If the system still won't accept discs, or if the discs are immediately ejected, this indicates a problem with the mechanism that pulls the discs into the system and the Wii will need to be repaired. To begin the repair process, click here.
Nov 15, 2012 | Nintendo Wii Console
My dvd wont eject. when i press open it blinks for a minute then goes to loading! then dvd will then play. I can hear it running but it will not eject the dvd.
unplug it for 10 - 15 mins... when you plug it back press the stop/eject quickly (player will automatic try to load disc)
Aug 09, 2011 | Toshiba SD-6000
Will not eject disk.
Almost always, your described problem could be caused by:
  • stuck disc;
  • fault in the load/eject mechanism.
It it were a stuck disc, the correct fix would be to open the unit and manually extract the erring disc. However, there may be possible workarounds:
  • unplug the unit for an hour or so;
  • press and hold the eject button while plugging in; or
  • invert the unit (bottom side up);
  • plug back the Apex and quickly unplug soon as you hear the mechanical noise start;
  • revert to normal position and try ejecting; or
  • while still in the inverted position, press and hold the eject button while plugging in but must unplug quickly even before the tray starts to move out.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 15, 2010 | Apex Digital AD-1225 DVD Player
Brand new ps3 right out the box won't accept a disc. pressed eject there is nothing in there. should i take it back or is there a quick fix?
the problem is the lazer is broken or out off allignment can be solved witha replcement lazer len unit it a common fault
Oct 07, 2010 | Sony Playstation 3 (PS3) Console
Playstation wont take any disc it'l eject but not insert
i have seen this before... there is a little eye inside the ps3 bluray drive that senses when a disc enters and starts turning wheels with rubber feet on them to pull the disc in. when that eye goes bad for what ever reason the only way to get it to accept discs is to force it in slightly and it will spread the acceptance arms and pull it in. if it will not eject the disc correctly then the drive has been disassembled and needs to be reseated until it function right.
the acceptance eye is fairly cheap to buy online but can be a pain to replace if you dont know what you are doing.
Mar 07, 2010 | Sony Playstation 3 (PS3) Console
My westinghouse tv/dvd will not accept disc. It shows ''open'' when I push eject and I do not believe there is a disc in there already. When I put a disc in, it sent it right back out and now it will not...
It sounds like the DVD mechanism is out, if you are interested in purchasing one you can do so by emailing your request for pricing and availability to parts@wde.com, they normally run at about $135.00 plus shipping and handling and they are not to hard to install yourself.
Nov 29, 2009 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
My wii is not accepting any disc. I push the disc
I have just finished fixing a wii system that did the exact same thing. It had 2 pennies jammed into it. After i removed them it was perfect. I am a game sytem technician and a special type of screwdriver is required to open the unit. It can be purchased on ebay.Good Luck
Nov 23, 2009 | Nintendo Wii Console
Wont accept disc
Try this....after a lot of frustration and research, what i found on the internet for this problem was usless. I tried holding down the eject button for 15 seconds to reset the disc drive, still it would'nt accept the disc. As i literally picked up the phone to ring sony, as the ps3 was on standby i pressed the eject button multiple times and heard 2 beeps each time, still the system stayed on standby. After that i then tried just putting the disc in as normal as its on standby and the system booted automatically and accepted my disc. I hope this helps others, as mine now works perfectly.
(PSN ID is Burnsy333)
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
LCD TV/DVD PLAYER COMBO - DVD WON'T ACCEPT A DISC
Turns out my suspicions wre correct about the DVD player being "sluggish" from lack of use. By continuing to exercise the drive motor by hitting play and eject while simutaneously attempting to insert a disc finally paid off. Now it readily accepts the disc and everything is functioning as designed. Trust me, I'm not going to let it sit idle for anymore extended periods...................baltogas
May 28, 2008 | Akai LCT3201TD 32 in. LCD Television
Jensen vm9311ts problem
The player thiinks the CD is still in the player. you have a shorted or open sensor. Usually thee players have 3 phto sensors to tell the controller that a Disc is inserted , or ejected or present. Sometimes a wire or piece of lint covers a sensor and makes the controller think the CD is still there. Get you a can of Air from Radio Shack and blow out the DVD drive You might get lucky and this do the job.
Nov 30, 2007 | Jensen VM9510 Car DVD Player
Dell Studio 15 Laptop Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
