Question about Samsung PCN5425R 54" Rear Projection Television
Can't figure out the model of my Samsung Rear Projection TV
Hi, I have a problem. I believe that I need to replace my convergence board because everything is double. It's worse on the outside edges. Anyway, I can't find my Model #. I searched everywhere but to no avail. I even got into the service mode by MUTE-182-Power and searched there. Can somebody offer a suggestion?
Thanks
  • nburke91 Feb 07, 2009
    samsung 52in. color distorted red and green.Bought a new remote. Need to know how to get the cross.Do I need a new convergance board?
  • 43 Answers
Most of these issues can be solved by resoldering the convergence ICs. Resolder the convergence ICs first and if it still doesn't work then look for a board. I bet you fix it...
Posted on Jan 12, 2009
  • dhurt Feb 12, 2009
    No need for a new board, but you may not be able to adjust fdrom remote. If the convergence setting is on the main menu, then you can follow the instructions, otherwise, the control is done by the front of the television
Samsung rear projector tv Model SP42Q2HL HDTV ready 1080i Looks like i should b wearing 3D glasses when watching tv, Is it game over?
No,is it not.It a repairable tv.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 12, 2010 | Samsung HCP4252W 42" Rear Projection...
I have a Samsung Model PCN5425R Rear Projection TV. When I try to set the convergence, the red will not move whatever I do, but the blue works fine.
If it is rear projection set it uses either two of the STK-392-020 OR STK-392-040 CHIPS FOR CONVERGENCE OUTPUT.
BOTH WILL HAVE TO BE REPLACED; NOTE THAT THESE SETS ALSO HAVE "PICO" FUSES ON THE BOARD FOR EACH CHIP--no movement means one of the fuses is blown because the chip shorted.
This can be a do it yourself repair if you are handy; total parts cost if the parts purchased on Ebay is under 30 dollars.
Let me know if I can assist you and if you have any questions reply to the posting here.
REGARDS, SD TECH
Aug 10, 2010 | Samsung PCN5425R 54" Rear Projection...
I have a big screen samsung it plays red and green and the imaged are doubled looks like 3d any ideas
Your question shows its Samsung rear projection TV that has 3 tubes to project picture.
Symptom shows TV got problem in convergence board that will be replaced.
Model number or TV would help me to provide you more info.
Thanks.
Jan 15, 2010 | Sony KP-57WV700 57" Rear Projection HDTV
Convergence is off and wont adjust with remote control adjustment
Convergence control will disappear / inactive in TV menu when Convergence out section got failure.
Please replace convergence out board in TV to solve this problem.
Is it Samsung HC-N473W model?
Thanks.
Nov 02, 2009 | Samsung HCN473W 47" Rear Projection...
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
May 23, 2009 | Samsung Televison & Video
Hi, this TV is repairable and you will have to replace two devices. the first is the Convergence board. this device regulates the convergence of the RGB stream so it can be projected evenly. it works in conjunction with the CRT's and deflection assembly and the Focus pack(module). The second device that will need to be replaced is the Focus pack(module). This module is malfunctioning and is causing the smudges and warped look at this time.
Replace these two devices and it will fix this set. i will post the Part numbers below along with there respective prices as well.
Focus Pack(module).--- Part Number-- BP59-00005A--- $38.95
Convergence Board assembly--Part Number---BP94-00383A---- $165.95
Please rate and god bless:)
May 07, 2009 | Samsung HCM4215W 42" Rear Projection...
How to remove back of Samsung HCL4715W 47 in rear projection TV
the screws are identified by little arrows pointing to the screw holes. However I would be surprised if its the convergence board most times its the Convergence ICs located on the sub board
Apr 22, 2008 | Samsung HCL4715W 47" Rear Projection...
PCL542r convergence
Samsung part number AA95-00706C its available at www.partsstore.com
Mar 13, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung HCL5515W red convergence problem
sounds like your convergence IC's have fail and possibly a bad dcm. Some of there models have a small board with the ic's them. It may be cheaper to replace the board. But you can repair it if you have proper equipment
Jan 20, 2008 | Samsung PCN5425R 54" Rear Projection...
AUSTRALIAN PARTS
the convergence board has nothing to do with tuning of tv, the convergence board put three colour gun (red, green, blue) to work with each other, else you get three image, of red , green,  blue or mixture of all as seperate image, the convergence board for american tv and Australian tv is possibly the same what you check to see the board  part number is the same you possibly need to see if the convergence board has got the memory i.c. if that is the case, you need to tune you t.v reset the channel etc good luck.
need more help let me know.
Oct 09, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
81 people viewed this question
Henry  Thomas
Henry Thomas
