Question about Samsung DV337 Electric Dryer
When drying it its sounds like shoes bouncing around
Noisey but still drys
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Have it looked at: many use a belt that turns the drum the clothing is in and it may have rubber like wheels that have worn or are flattened on one side--worn wheels if it has it will cause this issue.
Posted on Dec 04, 2012
Clicking noise in rear brakes once pedal brake has depress it going away
Sounds like you have drum brakes in the rear....if so....find a safe place to put your car in reverse and slowly accelerate until traveling about 7 miles per hour...don't try and read you speedometer while driving in reverse...it won't register when traveling backwards...just guess when your at about 7 miles per hour....then slam your brakes on to stop as quick as you can...repeat about 4 or 5 times.
Drum brakes have a self tightening device that is supposed to work it's magic every time you brake while traveling in reverse.
I think your rear drum brakes are lose because you hardly ever drive in reverse, am I right?...I suspect.it is those lose brake shoes rattling, making occasional contact with your brake drums.
If the sound persists after the first 5 back up and stops...try it 5 more times...then test again....if the sound is gone...good...now you know how to fix it when it happens again....
Or... if it sounds like you made an improvement by reducing the noise/sound....repeat the back up and stop thing until it is gone or at a level that seems acceptable....because by being lose and bouncing against the drums...the brake shoes might not immediately be able to be set back to the closest setting....because they were unevenly worn from the bouncing...
In this case....adjust them until no more improvement is being made....then in two weeks....do the back up and stop thing again to set the brake shoes where they should be....now you should hear very little to no noise......but....
If the sound still happens....have a mechanic at a brake shop inspect it....good luck and make sure there isn't any thing laying lose in the car or trunk that will fly when you hit the brakes to adjust the brake shoes....be safe ...find a big open area to do the reverse...then brake hard thing...an open area where no one else is around to get in your way....a place where there are no poles trees or curbs to hit...a place where there is a paved surface to do it on...like a parking lot at an abandoned super market or plaza....chose your place to do it carefully and think about what you could hit or what you could run over before starting....just be safe....
Mar 12, 2015 | Cars & Trucks
Samsung front load dryer
it sounds like the problem may be with the door lock. Having shoes bouncing around in the dryer they are bound to hit the door over and over possible causing damage to the lock. Try pushing on the door and holding it shut while you turn on the unit and see if it works.
May 16, 2014 | Dryers
My Dryer won't stop drying until I open the door.
If it does this in a Timed Dry setting the timer is bad. If it does this in an Auto dry setting it could be a bad moisture sensor or a bad timer.
Aug 21, 2011 | Crosley Dryers
My magic chef dryer dosen;t always heat up. sometimes drys just fine other times when you put on auto dry it will go for hours and not dry.
it sounds like you will need to change the coils on the gas valve. They are working intermittenly.
Oct 11, 2009 | Magic Chef Dryers
GE dry is making a noise like loose change is rolling around
There may be change rolling around in it.
Remove the top. Take the screws out of the drum baffles and remove the coins from inside the dryer drum baffles.
When replacing them, tighten them well to help prevent coins from getting in there.
Mar 23, 2009 | GE Dryers
Dryer won't start
fuse ,,fuse ,, fuse.that has to be replaced.
Mar 02, 2009 | Roper RES7646KQ Electric Dryer
Washing machine noisey on final spin
this isn't a problem usually every washing machine is very noisy on a final dry its normal
Oct 15, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
NOISEY DRYER
The drum is probably hitting the housing or internal structure because of a failed bearing.
Sep 04, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Samsung DV337 Electric Dryer Logo
151 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
