Question about Acer Aspire One Netbook 8.9" Notebook
Cruser keeps blinking.
Wont stop blinking.
  • Acer Master
  • 2,878 Answers
Black screen with blinking curser?
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Posted on Dec 05, 2012
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
It just keeps blinking in stand by and it wont stop kp53hs10 sony 53 inch tv
I have the same problem- please help- no power- just continuous blinking- tv 10 tears old
May 24, 2011 | Sony KP-53HS10 TV
Security light wont stop blinking and car wont start
Keep the door slightly ajar whlie the ignition is in the ON position and the blinking will stop in 5-10 minutes. You'll be able to start after that.
Aug 24, 2010 | 2002 Saturn L-Series
Wont start, security light keeps blinking
Turn the ignition switch to the on position and let the light blink. It should stop in about 10-20 minutes. then you can start the engine. if the light does not stop blinking likely the key switch is bad or, (less likely the module). Make sure your battery is in good condition when doing this or it wii kill the battery before the coding is complete (use a jumper to a good battery if necessary but don't turn the other vehicle on)
Oct 13, 2009 | 2003 Pontiac Grand Am
Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Power light blinking
Modems are not listed with your server.( not registered )
Jan 14, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Headlights blink
This problem is usually associated with the headlight switch. make sure wire plugs are tight and secure or you may need to replace the switch
Nov 29, 2008 | 2001 Chrysler Voyager
Turn tv on green light keeps blinking wont reset
Verify Model # off back of set and mo / yr built......critical for
correct solution....For example, if your # ends with.....13, then
a DM module repair will be needed...replace four capacitors...
1000mf 25v 105 degree.....If different model = different solution
....................................T.
Dec 14, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Acer Aspire One Netbook 8.9" Notebook Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
