Question about Kitchen Ranges
Display is out
The Display is out and none of the Buttons on the display work. However, the oven light will turn on and the stovetop still works.
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 05, 2012
catriver
  • 878 Answers
SOURCE: Oven, Broiler inopperable
Sandwich, is it your bake or broil thats not working? You have two ignitors, one for bake and broil. One of them is your culprit. This is not a hard job. The post header says broil not working so the part number for that is WB13K0003. Bake ignitor is WB13K0004. To get at the bake ignitor you have to remove the oven bottom inside panel, remove the flame spreader (both easy). The click you are hearing is the board relay sending power to the ignitor. The ignitor has to draw so many amps to open the gas valve. The oven is pilotless. Catriver..post back.
Posted on Apr 21, 2007
SOURCE: Electronic Display
Further inspection found that the ribbon got damaged during the re-instalation of the clock board. A new front control board had to be ordered and installed.
Posted on Feb 25, 2008
jyackle5
  • 8197 Answers
SOURCE: kenmore range control panel not working
sounds like the control board blew on you replace it.
Posted on Dec 16, 2008
SOURCE: I was setting the clock
If your code is SaB i just did this myself....i accidentally turned on the sabbath mode. I fixed if (after 2 days of trying) by holding down the cancel button for about 5 seconds, and then the clock button for about the same.
Posted on Mar 05, 2009
shinn8
  • 85 Answers
SOURCE: stovetop works but oven does not.
Most likely your problem is the glowplug aka oven igniter. Even though it comes on it must reach a certain temp for the gas to come on. Occaisionally the valve will be bad but 90% of the time it is the igniter. Part number is 74007498
Posted on May 29, 2009
Why has our oven stopped working whilst cooking - nothing electrical seems to be working?
Did you check your electrical breakers? Maybe it tripped. Reset it by first switching it fully to the off position, then switch it to on.
Feb 29, 2016 | Ovens
JJW8230DDB Jenn Air double oven. Black. Digital display. The only buttons working on the display are the Cancel buttons. Display still shows time, but I can not set the time (the clock button does not work...
When buttons are not working most of the time it is due to a short in the touch pad or the electronic control in a unit you would have to call for service if you did not know how to use a multimeter to perform ohms and continuity testing and measureing of both pieces. Usually though due to the button not working most of the time it is the touch pad though. If you have any further questions message me back Thanks again
Rick
Oct 16, 2011 | Jenn-Air JJW8230D Electric Double Oven
I have a Kenmore 790.9232 electric oven range with digital display. There was a pop as I was cooking today and the circuit breaker in the basement went off. I reset the breaker, and while the stovetop...
some thing has definately blown. were you using the oven at the time? it could be the oven element other wise i think its the circuit board. if you cant trouble shoot those simple things then you will need a technition.
Jul 02, 2017 | Ovens
Gas oven won't light. Stovetop works fine.
I have the same problem with my whirlpool gas oven. The top burners work fine, but when we turn the oven on, the ON sign on the display stays on for about a few seconds and then goes away. The oven doesn't light up. Please help
Aug 23, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The buttons on the front stopped working, no display
It is still under warrantee if under a year. Contact your dealer who you bought it from-it should be repaired or replaced free of charge.
Oct 03, 2009 | Microwave Ovens
Electric went out to the house, it came back on, and the microwave inside light works, the display panel reads just a " : ", and none of the buttons work. I have tried resetting the breaker with same
Hi cschnur,
     It seems that you might need to replace circuit board.
All the above mentioned conditions refers to a faulty circuit board. You might have blown few Ic's.
Take a voltmeter, check the continuity. If you are aware of the Ic's, replace them.
Unless, look for a tech, a used board ( On http;//www.ebay.com ) or purchase a new one.
Thanks for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
Apr 17, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Kenmore range control panel not working
Dec 16, 2008 | Kitchen Ranges
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
