Samsing 50 inch Plasma- Main Board BN94-01658A Problem
I have been trying to troubleshoot the clicking sound and distorted picture during the startup which eventually goes away after a few minutes and TV works fine after. I tested out the power supply board and the voltages its outputting are fine. I singled out the problem to be with the main board (board with all the inputs). Moreover, I noticed that if I heat up the black heatsink sink on the main board (BN94-01658A) with a hand dryer, TV turns on just fine. I am stuck at this point and dont know how to fix it. Any input? Replacing the main board is an option but I cannot find one for less than $200.
  • Ibadat Dec 05, 2012
    I was able to fix the problem by reflowing the main board. Those who have similar problem, before you replace the main board try to reflow it .There are tutorial on youtube on how to use kitchen oven to reflow motherboard of laptops. You can use the same procedure. I heated it for about 8 mins at 385 degrees F / 200 C and allowed it to naturaly cool.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Its either bit the bullet or buy a new set here--you are going to have to try that board to see if it cures it or not.
Where did you price the board?
The main board should have a number of large flatpack chips so that price may be ok, where did you get the price?
Posted on Dec 04, 2012
  • 1 more comment
    http://www.tvserviceparts.com/ has one for $190. Its out of stock everywhere else. I only want to replace it after exhausting all my options of fixing the current board. What I do not understand is why does heating up the chip solve the problem? Are they are any bad circuits inside the chip? Would it help to reflow the chip?
  • SD Tech
    SD Tech Dec 05, 2012
    The explanation is rather simple---not enough heat sink to keep the part cool or the issue is pins on the chip lifting a bit with heat and cold--I had a different set with same issue and a mini fan installed kept it working--heat or cold
    I reflowed the board using kitchen oven and its fixed now.
2 Suggested Answers
SOURCE: Removed all inputs to main
http://www.retrevo.com/support/Zenith-P42W34-TVs-manual/id/277ci358/t/2/
http://www.zenithservice.com/index_b2c.jsp
You did not indicate what the "Problem" is?
Hi, well I applaud you for starting in the right place, The power supply, as, if, that isn't right nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins.
Posted on Apr 01, 2010
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
Small picture size on Zenith 50 inch plasma
you should be able to zoom, and stretch the picture with the remote control. Since you replaced the main board you lost the settings that were in memory. Simply re do them once more.
Dec 29, 2013 | Zenith Televison & Video
Insignia 50 inch 1080 plasma - Picture only shows about 3 inches at the top of the screen
Several possible suspects include: power board, main board--first step is test voltages coming out of power board--------remotely possible also is the display itself (panel which is screen unit) if it turns out to be that it is fatal.
Jun 10, 2012 | Insignia NSPDP50 50 in. HD-Ready Plasma TV
Have 50 inch samsung plasma tv.have sound but no picture.
If the sound is still going and you can change the channels then the problem is most certainly the ysus or zsus board.
May 20, 2010 | Televison & Video
LG 50 inch plasma has trouble powering up. have
Power supply board have dead capcitors.Know how to solders?These capacitors usally bulge or pop open,replaced these capacitors will solved this problem.Or tries websites Shopjimmy.com,Ebay.com to buy a Whole reburbish power supply board for the replacement.
Mar 04, 2010 | LG 50PX5D 50 in. Plasma HDTV
42 inch LG Plasma TV - Lost picture
This is almost certainly the device that sends electricity to the the plasma in the panel after failing. Bring to your local repair shop and expect to pay 300-400 parts and 100-200 labour.
Cheers,
Stephen
Apr 28, 2009 | LG 50PC1DRA 50 in. Plasma Television
Clicking when turn on
The TV is trying to power up the screen during this problem.
The problem maybe a bad backlight inverter board not working or ta bad power supply.
Is it still under warranty?
Apr 20, 2009 | Philips 50PFP5332D 50 in. Plasma...
Ysus board number for a sanyo 50'' plasma model dp50747
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is www.sanyoctv.com and the phone number is 1-800-877-5032
Mar 16, 2009 | Sanyo DP50747 50 in. Plasma TV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Hdmi port
I have a 50 inch and recently had to have the main board replaced d/t the IR receiver was failing intermittently. Since they replaced the main board, one of the two HDMI is doing the same thing (picture, no sound). When I spoke to service they felt the issue was related to the replacement board and will be replacing. The weird thing is the picture is not quite right + no sound. Usually with HDMI it's either all OK or not OK at all. In any event, my problem seems to be the main board.
Aug 20, 2008 | LG 42PC3D 42 in. Plasma Television
Televison & Video Logo
518 people viewed this question
Top Televison & Video Experts
Electro Med Services...
