Question about Whirlpool WFG114SV Gas Range
F2 shows up in the display area, what does that mean?
F2 and beeping is in the electronic display area, what does that mean?
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
F2 is a faulty oven sensor and it will need to be replaced. Here is the part to order.
Posted on Dec 05, 2012
2 Suggested Answers
battlesmith
  • 382 Answers
SOURCE: display reads F2
The error code F2 is for Shorted Keypad Replace Keypad ..SO Try unplugging the range for 5 minutes. Then plug back in and try the door. It could also be a bad keypad or stuck button..Hope it helps you..please rate the solution..thank you!!..
Posted on Jul 10, 2008
I tried to reset the time on my stove and it started beeping and flashing F2. why
The error code "F2" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses a runaway heat condition during the "cook" or the "clean" modes. It could be caused by the oven temperature sensor, by the ERC or by the wire harness between the oven temperature sensor and the ERC. If the error code "F2" is displayed in the "cook" or "clean" modes only, then the problem is a bad oven temperature sensor or its wire harness. If the error code "F2" is displayed in the time of the day mode also, then most likely a problem is the bad ERC.To get the right replacement part just click on the link AppliancePartsPros,
Aug 03, 2016 | Optics
Display reads F2
have you tried a hard reset and left unit powered off for few hours?
Jul 10, 2008 | Whirlpool Kitchen Ranges
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
F3e2 error
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html How to Get GE Oven to Stop Beeping eHow
Jan 03, 2014 | Whirlpool Ovens
Error Code F@ on GE XL$$ Range
usually f02 means you have a shorted keypad. does it randomly beep at you if so this is a symptom. you need to replace your keypad
May 29, 2009 | GE Spectra JGBP35 Gas Kitchen Range
EO F2 code
hi, this appears to be a fault caused by a short in your keypad - electronic range control (ERC)
this needs to be replaced unfortunatly.
To assist you finding the proper part your model numbel means that the oven is manufactured by Whirlpool for Sears/kenmore.
Oct 24, 2008 | Kitchen Ranges
Model WHIRLPOOL WEP54800 Stove starts to beep at differnt times of the day.After four beeps F2 showes up and continues to beep when it feels it should. The control board has been checked twice and A new...
Hello fairglen,
welcome,
You said, model WHIRLPOOL WEP54800 Stove starts to beep at different times of the day.After four beeps F2 shows up and continues to beep when it feels it should. The control board has been checked twice and A new oven sensor installed. EVERY thing works perfect.This all started after water was brought to A boil on the back burner
But something is wrong!!??
Check your model number.
It is not showing up anywhere in the repair manuals or error codes.
Not even Canada.
What country did you buy it in?
How old is this range?
These are the only F2 codes I found in whirlpool so far!
F2 - Oven temperature sensor shorted = Replace oven temperature sensor
F2-Oven temperature above specifications = 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Waiting your response or correction!!!!!!!!!!!
Huuum
Oct 17, 2008 | Whirlpool Kitchen Ranges
Whirlpool WFG114SV Gas Range Logo
232 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
