Question about Whirlpool Kitchen Ranges
I Have A whirlpool model WFE364LVS oven all of the controls and the top burners all work fine, the problem i am having is the oven will not heat up at all.what can i try?
I have tried turning off the power and turning back on to reset it it didnt work,it all happened when the power went out at my house and when power came back on the oven would not work
  • Jeremy Casteel Dec 04, 2012
    thanks for the suggestions guys but it dont seem to help joe my oven is eletric as far as i am understood there is no ignitor, and ron i thought the same thing but after puting an amp metter on the wires everything is putting out the power that is required.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
You have a faulty sensor in the oven that needs to be replaced. Here is the part to order.
Posted on Dec 05, 2012
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Whirlpool supercapacity 465 range won't heat up
hoops, it almost sounds like you lost a leg of power, L2. L1 is sending power to the board but but it's not making the loop. Too much of a coencidence that the burners and oven are not working. Check the cord connection to the oven. You should have 220V across the 2 outer terminals. 120V from each end to center terminal. Let me know what you find. Catriver.
Posted on Dec 16, 2007
  • 146 Answers
SOURCE: Oven not heating KitchenAid KERC506HWH3
It could be the sensor. Remove the sensor and check for 1 to 1.1K ohms. at room temp. If that's not the problem it may be the oven solenoid on the burner. You can also have a problem with the door lock making when it shouldn't check that also.
Posted on Dec 29, 2007
  • 145 Answers
SOURCE: burners and oven not heating tappan range 560s111po1
You need to check the connection at the back of the unit that hooks to the house power. Turn off breakers or pull fuses before checking. It sounds like you only have half of the voltage you need. One of the wire connectors may be burnt or you may have a problem with the house wiring.
Posted on Apr 23, 2008
SOURCE: Kenmore Elite Electric Convection Oven Not Working
The control panel of Kenmore oven doesn't work. I bought it just one month ago. What should I do?
Posted on Sep 14, 2008
Why does the control panel on my Whirlpool electric range get too hot to touch when oven is operating at 350 degrees?
heat transference and radiated heat at that temp is normal
the stove should have an air gap between unit and wall
not pushed up against the wall
and internally insulated
check to see if your whirlpool model oven ever had a safety recall 26301150-vpuqtjtdvoowntuyvcl35auo-4-0.jpg
Oct 04, 2016 | Whirlpool Kitchen Ranges
Whirlpool oven wont light
The igniter has to heat the thermocouple to turn on the gas valve so if the igniter is glowing brightly either (or both) of those components could be at fault.
Mar 11, 2014 | Whirlpool Kitchen Ranges
Whirlpool RF302BXYW Ser# FD1227461 oven quit working (surface burners are okay)
Several possibilities:
1: Fuses blew under the top cover. Oven fuses will not affect top burners.
2: Element has burned out. Top element only heats when you try to warm the oven.
3: controller has burned out. A controller can cost $150 - $600 for digital. You might want a tech to confirm before you change this one.
Apr 17, 2010 | Whirlpool RF302 Electric Kitchen Range
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Oven not heating
The temp control is not telling the ignition system to engage....have a service company look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
May 27, 2009 | Whirlpool GS445LELS Gas Kitchen Range
Model # JKS06bof4bb wall oven has a fault f-7 dc Tried cycling power on/off didnt work still have fault
I have a whirlpool accubake oven model WFE364LVS. The screen is saying d79b. What does that mean? The oven door doesn't open either. My husband did the self clean and it worked fine for alittle while after and then I went to bake a cake and the door wouldn't open. Can anyone please help me?
Aug 20, 2008 | GE Kitchen Ranges
Kitchen Ranges Logo
105 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
