Question about Thermador PRG304US Gas Kitchen Range
How to change spark module in thermador PRG304
None of the burners are igniting since a power outage on my Thermador PRG304 natural gas range since a power outage. Oven works fine. I need to get to the spark module under the left burners but can't get the burners out because I can't turn the nut in the middle of the burner base. any idea how to free these up? Heat, WD 40, vise grips won't work Thanks
5 Suggested Answers
  • 1314 Answers
SOURCE: Thermador oven/broiler turns off after 5-8 seconds
two things come to mind a faulty safty valve thats the device that the ignighters connect to the other maybe trash stopping the screen on the pressure regulater are any codes displayed on the clock
Posted on Jan 30, 2008
SOURCE: LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Posted on Feb 27, 2008
SOURCE: oven shuts off
Sounds like the spark module has been shorted out and quite possibly the main control board. Apptech.
Posted on Oct 19, 2008
  • 11800 Answers
SOURCE: Thermador PD36 dual fuel range
There is no PD36 model. There are several PRD36 models of electric/gas ovens and in all of them the gas supply is common to all the top burners - all the control valves connect directly into a manifold/main gas tube.
If you can't lit those 2 burners with an external flame it means that the supply of gas to them has been cut by a blockage on the manifold - it's extremely unlikely that 2 valves have failed at the same time or that the 2 safety wires to them have failed simultaneously . The oven will have to be dismantled and the case of the blockage found and removed - if necessary the entire manifold will have to be replaced. This is a very complicated job that requires extensive experience - most likely you will have to call a repairman .
Posted on Jun 01, 2011
Our Thermador Pro-Harmony gas range just started to make clicking noises and it will not stop. Nobody turned the stove on. It started clicking on its own. How do we shut it off?
Usually a clicking sound from a gas range is the gas ignitor/igniter sparking to light one of the gas burners
...Check to make sure all functions are turned off. If all are off
could be a defective switch..check to see if you see a spark at any of the gas burners
Sep 09, 2017 | Thermador Kitchen Ranges
Have a thermador psc364gdzs the spark does not work for the gridle
The spark module is in the ignition circuit for the gas burners. When a burner control knob is turned to the Lite position, it provides voltage to the spark electrodes on the gas burners. If the spark module fails to provide the electrodes with voltage, then it should be replaced.
Aug 29, 2017 | Thermador Cooktops
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
When Thermador oven is on and the simmer burner on low-low and the igniter sparks, the oven shuts off and the clock blinks (as if there were a power outage).
Check your earthing, all the way back to the earth stake too for safetys' sake!
Otherwise, try lighting the burner with a gas match instead of the peizeo ignition module >> check ignition module
Oct 16, 2013 | Thermador Ovens
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador rdss30rs xlo burners don't light and right side burners don't light either. can light right side with lighter. while burners are on igniter spark continously.
IF THE BURNERS DO NOT IGNITE
• Are the burner caps properly aligned and seated in the burner bases?
• Are the burner ports clogged?
• Is a fuse blown or is the circuit breaker tripped?
• Is the manual shut-off valve closed, preventing the flow of gas?
Jun 29, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Oven shuts off
Oct 19, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Thermador PRG304US Gas Kitchen Range Logo
133 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
