Question about Staples Office Equipment & Supplies
Staples SPL-NSC30A Shredder will not shred on automatic
Will not shred have to manual hit the forward button
JayBlair
  • 328 Answers
SOURCE: when on
Make sure there is no paper blocking the sensors. Otherwise you may have a bad sensor or switch.
Posted on Jun 05, 2009
FixinFax
  • 3085 Answers
SOURCE: Staples SPL-X21G shredder won't turn off
Blow canned air down into the feed slot.
Posted on Sep 22, 2009
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
SOURCE: Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Posted on Jun 23, 2010
  • 300 Answers
SOURCE: Automatic switch does not shut off after shredding
These shredders have a "paper in" sensor. This is either optical or mechanical.
Sounds like the sensor is blocked and therefore "thinks" there is still more paper left, and this is why it keeps going.
Before you do anything UNPLUG THE SHREDDER.
The sensor is located about in the middle and at the level of the blades.
If it's mechanical, you should see a little finger, else it is electronic.
Shine a light in the area and you should be able to spot where the blockage is.
A shot with compressed ais usually gets rid of the offending particles.
After you're finished working on it, set it back securely on the basket and plug it in.
Posted on Feb 14, 2011
STAPLES SPL-TMC 12A SHREDDER
There is an optical sensor that needs to be cleaned. It is usually at the middle of the slot where you put paper to be shredded. Use canned air to blow out both holes (one on each side of the slot).
Hope this helps.
Sep 22, 2016 | Staples Office Equipment & Supplies
What lubricant do you use for a Staples SPL-XC240D and where do you lubricate it?
Staples actually sells shredder lubricant. It comes in a small squeeze bottle. You actually are lubricating the shredder teeth themselves to keep them sharp and prolonging their lifetime. You simply take a piece of paper you are about to shred, run a bead of the lubricant across the sheet and feed it into the shredder. Done!
Mar 04, 2015 | Staples Office Equipment & Supplies
Staples shredder parts
You can try cleaning it and maybe limiting shredding to one sheet at a time.
Jan 14, 2014 | Office Equipment & Supplies
Manuals on shredder/spl-xc240p
how to replace a pullery in a spl-xc240p
Sep 17, 2012 | Staples Office Equipment & Supplies
STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES TO RUN WITHOUT STOPPING AFTER PAPER HAS BEEN SHRED. THE FORWARD LIGHT FLASHES.
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
Sep 22, 2009 | Office Equipment & Supplies
Staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
Sep 10, 2009 | Office Equipment & Supplies
When on
Jun 04, 2009 | Office Equipment & Supplies
76 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
