Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover stamvac has hair trapped in it
I hoover steamvac with dog hair trapped under the hood. How do I disassemble to get to the dog hair?
  • 294 Answers
Hoover makes a neat tool for cleaning the hair and dirt out, its called a "nozzle cleanout tool". You can contact hoover and locate a store near you.
Posted on Jan 13, 2009
  • Monique Swanson
    Monique Swanson Jun 24, 2011
    There's got to be a way to take it apart - I think that was what the previous writer was asking, and also what I need to know.
  • Robert Pagliaroli Jun 25, 2011
    To remove the hood assembly, there are two screws under the bottom and one at the top center. There may be 2 more screws behind the brush assembly, so you will need to remove the brush block as well. Also remove the speed knob for the brushes. If the speed knob does not remove easily, it may be glued on, do not force it. Pull the hood off. Be careful when you remove the front 2 screws that hold the clear or smoke color lens on the bottom of the hood they cab crack the lens. You will now have access to clean the hood in a sink.
I CANNOT BELIEVE WHAT I DID !!! I DECIDED TO CLEAN 5 YEARS WORTH OF DOG HAIR OUT OF IT.ONE SCREW AT A TIME.ITS ALMOST DISASSEMBLED.NOW I CANT REMEMBER HOW TO PUT IT BACK TOGETHER.I'M SO SCREWED, ITS MY...
First, find a new place to live before you tell her.
If you have good eyes, this URL might be of help to you. It provides an exploded view of the unit but lacks detail and is hard to see. However, you do sound desperate.
http://www.vacpartswarehouse.com/Hoover-F6020-s/766.htm
Let me know if this is of any help to you. There are a number of pages for the parts listings, but I think the views might be what you want.
If this solution keeps you from being disowned, I would appreciate a Thumbs Up rating from you!
Be well and good luck! Paul
Oct 06, 2010 | Hoover F6020-900 SteamVac Upright Vacuum
How do you remove brushes and clean under the cover?
I too have this machine. On this particular model the brushes are not removable like on the newer versions. You can either purchase a "cleaning wand" from Hoover OR create your own as follows: Simply obtain a pendaflex hanging file folder (legal size) and remove the metal rods. These rods work exactly like the Hoover wand they try to sell you. They are quite flexible and easily slide thru the clear plastic openings at base of cover. The hooked ends work wonders in removing furballs, hair and other debris that gets trapped under the cover.
Jun 19, 2010 | Hoover F6020-900 SteamVac Upright Vacuum
Dog hair has clogged my steamvac spinscrub nozzle
disassemble it carefully until you can access the clogged area and pull that muck out...
Apr 06, 2010 | Hoover F5858-910 SteamVac Vacuum
Why did the brushes stop rotating?
Please check two things:
(1) The shutoff switch on the hood is NOT set to OFF for brush speed.
(2) Remove the red filter panel from under the cleaner, behind the brushes, and clean the hair/debris from the screen filter. Squeeze the two panels together, and pull down to remove from the pocket.
Sep 29, 2009 | Hoover SteamVac F5914-900 SpinScrub...
The spin scrubs quit working all of a sudden while i was steam vaccuming my carpet, there is a little dog hair in there but it doesnt look like enough to completely clog it, how do i get them to spin...
(1) Assure the Brush Control on the hood is NOT set to the OFF position.
(2) Remove the brush assembly by pulling/unlatching it from base on each side.
(3) Does one of the brushes have the drive pin present? It should be about ¼ inch square, and two inches long. It attaches the brushes to the drive mechanism.
(4) Remove and clean the intake filter. One the base of the cleaner, behind the brushes, squeeze the two red abs together and pull the panel down to access the screen. Clean the hair/debris off the screen and reassemble.
Sep 20, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover steamvac w/spin scrub F5914-900 will not **** up water. I can not find my manual. How can I fix it?
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Aug 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steamscrubber
I had the same problem. Fixed it by taking the machine apart and lubricating the bearing inside the turo tunnell. It's a pain, but not impossible if I could do you can. You must start by taking off the cover. Don't forget the scvrews on the front by the water vacuum. I used WD-49 and white grease so far so good. The turbo tunnel will come out by itself.
Dec 30, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
210 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
