Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
5 beeps when turn on key - Pride Go-Go Ultra X 3-Wheel Travel Scooter
  • Pride Master
  • 1,271 Answers
5 Bleeps -> The manual freewheel lever is in the(forward) freewheel position.Remove the key from the keyswitch, then push the manualfreewheel lever to the drive(rearward) position and restart yourTravel Scooter.
I strongly advise you to check the freewheel lever microswitch located on the side of the motor, also check the connection from the axle connection to the actual body were it comes apart. keep me updated please. regards GeWiz.
Posted on Dec 06, 2012
    New Friend:
  • 4 Answers
For other searchers, when the yellow lever is halfway through its travel, the unit will NOT beep, but the electric motor will constantly cut out, resulting in a very jerky ride.
Posted on Feb 05, 2013
2 short beeps pause 3 short beeps
NUMBER LOCK
You have press the NumLk key (number lock) and this changesthe right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock).it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicatethis function has been selected.Press the NumLkkey again to turn off the Number Lock.
Jul 11, 2012 | Toshiba Satellite Computers & Internet
Walkie talkies model gmr325-2 ic;513C-UT914 HOW DO I GET THESE TO TRANSMIT, MY HUSBAND HAS CANCER AND WE NEED THEM IN OUR BEDROOMS AND WHEN I AM OUTSIDE, TK U, TK U
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
KEYLOCK ON/OFF
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
ROGER BEEP
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
Jun 21, 2011 | Motorola Walkie Talkies 2-Way Radio
Scooter just beeps when key turned
Hi. That fault is the speed lever. It can also be the small dial that alters your top speed. It pays to replace both of these at the same time. Some of these machines also develope the same fault from a faulty controller. Good luck. Neil.
May 18, 2010 | Health & Beauty
My son's acer 5738 laptop has a rapid beeping noise when turned on and the keyboard is locked? Can you recommend something? thx
Rapid beeping sometimes indicates a stuck key on the keyboard. check all the keys to see if something is jammed, or if a certain key is not as responsive as the others.
I the keys are not stuck or jammed, and if you are brave enough, remove the bottom pannel and see if you are able to remove the ram. Turn the system on without any ram installed and see if the rapid beeping still occurs.
If the rapid beeping stops with the ram removed, you may need to purchase a replacement.
Jan 17, 2010 | Computers & Internet
How do I reset
Hi!
Press the Set button to turn on the unit (once programmed, tapping a Personal
Key turns on the unit.) The unit will beep to confirm activation, the Personal Key
numbers (1,2,3,4) will be displayed, and the display will flash.
If you don’t operate the unit for sixty seconds after the unit has been turned on, the unit
will turn off automatically.
If you make a mistake or want to turn the unit off before you have finished
programming it, press the Weight-Only Key to force quit.
Press the Up/Down buttons to select a Personal Key. Once you reach the
Personal Key number you wish to use, press the Set button.
The unit will beep once to confirm.
An arrow icon appears on the left side to indicate age setting.
Use the Up/Down buttons to scroll through numbers.
When you reach your age -press the Set button.
Use the Up/Down buttons to scroll through female or male,
Female/Athlete and Male/Athlete settings, then press the Set button.
Use the Up/Down buttons to specify Height and
The unit will beep twice and the display will flash all data three times to confirm the programming.
The power will shut down automatically.
Good Luck! :)
Cathy
Oct 21, 2009 | Tanita BC 554 Ironman Innerscan Body...
Video output settings
You might have to reset your display settings. You will need to turn off your PS3, Holding down the power soft key, turn the unit on in the back. Keep holding the soft key until the unit turns back off. Wait for about 15 seconds. Press the power soft key again. You will hear one beep, then a second beep. Then you will hear 2 quick beeps, as SOON as you hear those two consecutive beeps, let off the power soft key and a screen should come up to reset your display settings. Good luck!
Aug 04, 2009 | Ubi Soft Entertainment Blazing Angels:...
Cant get the beep sound off when keying it
i helded the {+} at the same time i turned it on and it seems to take the beep off i guess will see if it happens agian , thank you for your help maybe i"ll be calling you again. kenstoy67.
Nov 15, 2008 | Motorola Talkabout T5950 (7 Channels)...
Vw cabrio key remote programming
First, you will need two keys. Put one key in the ignition and turn the ignition to the "on" position (instrument cluster lights come on). Make sure the hood, trunk lid, and both doors are closed. Take the other key and stick in the driver's door lock. Turn the key counter clockwise and hold it in this position until you hear three beeps. Release key but don't remove it. Press the lock or the unlock button on the remote until you hear a beep. Once you hear the beep from the remote, turn the key in the door counter clockwise again until you hear three more beeps. The three beeps are the signal that you are entering/exiting program mode. The one beep from the remote lets you know that the remote has been programmed.
Dec 12, 2007 | Compaq HP Easy Access P/S2 Carbon/Silver...
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
405 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
