Behringer x1222usb mixer main mix sliders crackling
  • 110 Answers
You need a good slider lubricant. I use CRC 2-26. Does a great job.
Posted on Jan 14, 2013
Graphic equalizer
You connected your dvd player to WHAT mixer?
Connect your DVD to any one of your LINE IN jacks and your equalizer to one of the TAPE IN-TAPE OUT loops.
Apr 20, 2014 | Audio Players & Recorders
Behringer service manual
Go to http://behringer.com/ the sequence is this: home>products>small format mixers>xenix x1222usb then you will find a section tha says "downloads" a little down at the left side of the screen. You click on it and it will appear a list to select the language in pdf. Just click and start downloading the whole manual.
Jan 15, 2014 | Audio Players & Recorders
We are having issues just getting our sound to come out right. We have cords for Main speakers and Monitor speakers. Not able to control Main Mix for Main speakers. I can not find anything in the manaul...
Look at page 6 and see if it helps. There are so many routing capabilities with this unit it can get confusing. The buttons are important and you must have the Main button pressed for each channel you want to go to the main mix.
http://www.behringer.com/assets/SX3282_WebBrochure.pdf
Apr 26, 2013 | Behringer EURODESK SX3282 32 Ch...
Why does the left channel of mixer randomly crackle, distort, and/or cut-out?
left channel control pot dirty most likely. is there a slider type pot on channel? this would have to be cleaned with dustoff spray.
May 06, 2012 | Behringer Music
How to connect floor monitor to mixer
You need to connect the speakers using an XLR cable into the Main output jack on the back of the mixer. If they are powered speakers you will need to connect them into a power source and turn them on AFTER connecting them. Once powered on you can control the signal going to the mixer with the Main Mix fader.
  1. Turn mixer on
  2. Ensure Main Mix level is at zero
  3. Connect from Main Output to Monitors
  4. Turn Monitors on
  5. Turn up Main mix to desired level
Sep 14, 2011 | Behringer XENYX 2442FX Mixer
I have the Behringer Eurorack MX 2642A. Over 6 years old. The right main mix output sometimes works great and sometimes gets very quiet and distorted. Is it time for a new mixer or is there possibly a...
It sounds like one of the output devices is going bad, ie., output transistor, capacitor, resistor or maybe just a bad connection on one of the above menitoned items. One other problem which causes this would be the main or sub volume slider or pot is wearing out and needs to be replaced.It would definately be worth your while to have a technician trace down and fix the problem on this board. Hope this helps.
Feb 10, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
I have purchased a beheringer 1832fx usb mixer and I have connected my computer to my mixer that has a usb interface on the back in order to play my backing tracks, music, via my computer, and when I turn...
The main mix controls ALL outputs simultaneously.
The mic channels are controlled individually by the sliders.
It sounds like you are on the verge of feedback where the mics are picking up the PA speakers.
Make sure you have loaded the support SW and make sure you have disabled ECHO as the mics may be looping back through the computer causing the rattle.
Sep 06, 2010 | Behringer Xenyx 1832fx Mixer 18 Input 32...
Hello; I have a used Behringer pmp5000 mixer. The
Without knowing how you have your monitors configured it is hard to analyze what you have posted.
In brief, SW3 on the schematic that selects MAIN L and MAIN R in the upper position, MAIN and MONITOR in the middle, and bridged in the lower is used to configure the internal amps.
In the upper position, the amp power outputs come from the mixed stereo bus and are simultaneously controlled as a stereo signal by the MAIN slider.
In the middle position MAIN and MONITOR, the left amp receives the signal from the mix bus and is controlled by the MAIN slider. The MONITOR output from the other side of the power amp is controlled ONLY by possibly the "MONO" slider.
The schematics are hard to decode and what is needed is a signal flow diagram.
For my uses, I don't try to use splitting the power amps between mains and monitor but prefer to use the mains together with SW3 in the upper position (Note your 27 may be refering to the user manual designation for same switch). I then use another small amp from the 1/4 inch MONITOR jacks whcih are under control of the MONITOR sliders.
Please note that the MIX for these two MONITOR channels is controlled by the MON1 and MON2 knobs for each channel.
May 23, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
How to send at same time main mix and alt 3-4 outputs signals
The subwoofer MAY only have a single channel. If so, you would just use either 3 or 4 to the subwoofer.
Normally you would just tap off the main mix. The only reason I can see for using the alts is to have seperate sliders for level control.
Oct 10, 2009 | Behringer Music
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
